Trivia - Routes With Genuine Shared Traffic Between TOCs
Deepgreen
12 Jun 2013
Betchworth, Surrey
I live near Dorking, Surrey. This weekend there are no trains on the radial Epsom to Dorking route and the replacement buses are needlessly complicated, apparently because two TOCs share the route. It set me wondering where there are other routes that are more or less equally shared by different TOCs with very similar service patterns and provision. In the Dorking case SWR and Southern operate what are essentially similar suburban services along the corridor, so neither offers a fast vs. slow service, etc. I can't think of anywhere else in the UK where this situation exists, but I'd be surprised if I've not missed examples.
alangla
11 Apr 2018
North of Preston, I suspect most passengers aren’t overly bothered if they’re travelling on an Avanti or TransPennine service.
NSE
3 Mar 2010
I guess you have examples where Thameslink runs. I know TSGN is all one, but from somewhere like Gravesend/London Bridge is similar. I know the Thameslink one carries on further north. But SE offer a virtually identical service in terms of both being localish/metro-y services with similar journey times.
CBlue
30 Mar 2020
East Angular
Thameslink and Great Northern offer a more or less identical semi-fast service between Cambridge and London. The only big difference is that the Thameslink terminus is St Pancras.
johnnychips
19 Nov 2011
Sheffield
(Manchester)-Sheffield- Meadowhall-Doncaster-(Cleethorpes) TPE hourly
Sheffield - Meadowhall - Doncaster - (Hull and Scarborough) Northern hourly
and also pre-CV
Sheffield-Doncaster (Terminates/Adwick) Stopper, Northern half-hourly
(Birmingham and beyond)-Sheffield - Doncaster- (Newcastle) XC hourly
If there are rail replacement buses, I have no idea who organises them. XC have diversion options; but there is generally a ‘stopper’ bus, and a direct Sheffield to Doncaster bus if there are no trains. This is what happened in the floods just under a year ago.
Mojo
7 Aug 2005
Between Birmingham New Street and Birmingham International / Coventry. Whilst some trains take substantially longer than the other, you might as well catch the first departure whenever you arrive at the station because the timetable (during the daytimes at least, not sure about the extremes of the day) doesn't have trains being overtaken.
If you also count the city as a whole, the service options between Birmingham and Leamington Spa / Banbury are fairly equal between Chiltern Railways and CrossCountry Trains with fast trains operating twice per hour (pre-Covid timetable).
Dr Day
16 Oct 2018
Bristol
Cardiff-Newport - TfW vGWR plus XC . Plus others on South Wales main line. Needs 3 different poster boards at Newport for each operator’s engineering changes.
sheff1
24 Dec 2009
Sheffield
In normal times:
- two trains per hour Sheffield - Derby from both XC & EMR
- one per hour Sheffield - Nottingham from both Northern & EMR
- one fast per hour Sheffield - Manchester from both TPE & EMR
In the Derby case regular travellers might aim for EMR due to the frequent overcrowding on XC but most people will just turn up and go as the journey times are almost identical, as they are on the other two routes.
Mag_seven
1 Sep 2014
here to eternity
Queens Park to Harrow and Wealdstone - operated by both London Underground and London Overground
thenorthern
27 May 2013
Wolverhampton to Birmingham I think is a big one given how close it it most people won't care which operator they travel on. Same with Stockport to Piccadilly.
York to Edinburgh I think as well is one as there are an option of 3 "Fast" operators.
waverley47
17 Apr 2015
The most obvious for me is Edinburgh - York. The three are broadly similar journey times, stopping patterns, speed and tbh, broadly similar comfort levels. The only difference is really capacity and onward journeys, but along the 220 miles they're more or less similar.
Edit, beaten to it
NoMorePacers
18 Feb 2016
Humberside
The Northern fast services and the Hull Trains/LNER services between Doncaster and Hull take about the same length of time - although the former is much more frequent than the latter, especially right now.
johnnychips
19 Nov 2011
Sheffield
Who actually has to organise rail replacement buses for engineering? Is it Network Rail because they have caused the ‘problem’ or is it the train companies? With @sheff1 in post#9 I wonder who would be responsible if it were between, say, Dore and Chesterfield?
thenorthern
27 May 2013
Derby to Sheffield has two operators taking about the same time. Nottingham to Sheffield is the same.
Glenn1969
22 Jan 2019
Halifax, Yorks
Leeds to Wakefield. Four operators. Northern, XC, LNER, EMR (few)
Leeds to York also has 4 operators Northern, XC, TPE, LNER (few)
MarlowDonkey
4 Apr 2013
The off peak outer end of the Paddington to Reading service between Maidenhead and Reading. Two Tfl trains per hour, two GWR, all calling at Maidenhead, Twyford and Reading.
Between Paddington and Maidenhead, the GWR trains have far fewer stops.
Yindee8191
16 Mar 2019
Arguably I’d say SWR and GWR between Reading and Wokingham. Admittedly, SWR stop at all stations, while GWR do a bit more of an express service, but they’re both more or less outer-suburban commuter trains.
Train companies. In multi-TOC areas they will decide between them who takes the lead
daodao
6 Feb 2016
Dunham/Bowdon
There are 3 TOCs operating between Manchester and Stoke via Macclesfield, and between Manchester and Crewe via Wilmslow.
Scotrail314209
1 Feb 2017
Edinburgh
Ive noticed a lot of people do pick between Avanti and TPE. Avanti are a bit more frequent in a normal timetable and slightly faster.
When I’ve travelled on TPE, I’ve noticed it’s seemed rather slow going up the WCML.
This is all one TOC though.
There are loads of examples that match the criteria posted, for example from York I have a choice of similar operator of I go towards Edinburgh, Leeds or Doncaster.
norbitonflyer
24 Mar 2020
SW London
Between Reading and Oxford, Cross Country and GWR. Also Basingstoke - Southampton - Bournemouth - Cross Country and SWR. Both Basingstoke and Reading are major interchange points, particularly for passengers travelling to/from SW London and Surrey. (Indeed, Surbiton to Oxford via Basingstoke is a valid route my family have used several times)
Horizon22
Jobs & Careers
8 Sep 2019
Between New Cross Gate and Norwood Junction / Crystal Palace, London Overground and Southern share route with the same (all stations) calling patterns. They divert off at either end of course.
