Spartacus
- Joined
- 25 Aug 2009
- Messages
- 3,319
Could count the Class 25 ETHELs.
Wow, that's fascinating, and I had no idea it was so radically different. The DEMUs also had 7-notch controllers instead of 4-notch ones, which was another compatibility issue.They're on the RSSB website, document reference GMGN2590. But as I have a copy downloaded....
This is what it says for Classes 205/207:
And for the EMUs:
Wires 22/23/24/27 were allocated for those purposes on Classes 421-423, but never used, obviously!
The Tadpoles used ex-Hastings unit DEMU power cars with ex-EPB driving trailers. The latter retained the original 4-notch EMU power controllers.Wow, that's fascinating, and I had no idea it was so radically different. The DEMUs also had 7-notch controllers instead of 4-notch ones, which was another compatibility issue.
When unit 1111 (later 205 101 and then 205 205, now resident at the Epping - Ongar Railway) was refurbished, it was fitted with 4-notch controllers and a switch to allow EMU multiple working, but I doubt it was ever used.
Yup, notches 2, 4 and 6 were skipped when driven from the driving trailer, which must have made driving them a different business.The Tadpoles used ex-Hastings unit DEMU power cars with ex-EPB driving trailers. The latter retained the original 4-notch EMU power controllers.
I've read it that it made power application more jerky but I'd imagine that rather like the DBSOs with 47/7s it wouldn't be so much an issue driving from the driving trailer cab per se but just by having less fine control of power it would've made controlling speed a bit more awkwardYup, notches 2, 4 and 6 were skipped when driven from the driving trailer, which must have made driving them a different business.
Presumably a bit harder on slippery rails as well.I've read it that it made power application more jerky but I'd imagine that rather like the DBSOs with 47/7s it wouldn't be so much an issue driving from the driving trailer cab per se but just by having less fine control of power it would've made controlling speed a bit more awkward
I'd imagine so, particularly the jump between Notch 3 and 5 might be enough to cause a slip with the Thumper's mere two driven axles given the right (or perhaps that should be 'wrong') conditions.Presumably a bit harder on slippery rails as well.
