UK Rail Map
23 Dec 2008
Where/How can I obtain a copy of the full UK passenger rail map?
A similar size to that which was available with the full timetable.
Are there none on there that meet your needs? If so, what are your requirements exactly?
What size paper are you looking to print on?
takno
janb
16 Jul 2008
It's probably just me, but I've always found the Project Mapping maps to be almost unbelievably ugly. Essentially I think I'd rather be lost than spend time looking at one.
No its not just you, they are ugly. I much prefer the traditional NR version. (Geoff Marshall of All The Stations fame is also using pdf of the old version on his phone rather than Project Mapping).
U-Bahnfreund
6 Feb 2015
Germany
I prefer the Project Mapping version, as it shows all stations on one map and depicts the different TOCs and also trams and metros. Of course, it's not probably not working as a printed map, but on the phone it's quite good and - in my opinion - much better than the 2013 NR map. I think it's much easier to get an overview of the network and find connections on Project Mapping's map.
Shinkansenfan
3 Aug 2009
I second that thought!
I prefer the classic BR map that used to accompany the Great British Timetable.
There used to be a pdf version of the more aesthetically pleasing BR inspired map on the National Rail Enquiries website, however ATOC in their wisdom appear to have removed it.
berneyarms
26 Nov 2013
Dublin
Thanks for that ! I must admit, it's not immediately obvious where it is from the map page on the website.
It has been taken off the map index page, as it's out of date at this stage (it hasn't been updated since the 2013-14 timetable).
But it's still there in spirit!
Shinkansenfan
3 Aug 2009
Thanks for posting (I did recognize that map in Post #8). It's a pity it hasn't been updated.
Let's see if I can list some of the updates that would be needed to that map:
- Line to Tweedbank
- Extension to the Ebbw Vale branch
- North Cambridge station
- Some new stations near Exeter
- First bit of the East-West rail
- Opening of the north-south line in Dublin
- Opening of Dublin Dockyard Station.
berneyarms
26 Nov 2013
Dublin
No worries
It doesn't go into the level of segregating lines in Dublin so they're kinda moot points.
I'm assuming you're referring to the re-opening of the Phoenix Park Tunnel to scheduled passenger services.
And the station name is Docklands Station! ;)
19 May 2010
West Drayton
GWR did a network map which featured a National Rail map on the reverse a while ago. I have it at home but can't remember how big it is and whether it was updated for the above.
Shinkansenfan
3 Aug 2009
No worries
Yes, Phoenix Park Tunnel--that's the one I'm referring to. Thanks for correcting me on the name of Docklands Station (not sure why I thought it was Dockyards Station). The Luas LRT makes it easier to access that station.
TheNewNo2
31 Mar 2015
Canary Wharf
Looking at that NR map, I just think that looks awful. It gives no detail about what journeys might be possible, and if you want to go anywhere near London, Cardiff, Birmingham or the North you're pretty much out of luck. Project Mapping any day.
Plus Project Mapping actually gets updated and makes changes when errors are noticed...
To be fair, the original versions came with diagrams of the more complicated parts of the country. Plus there's no reason why they can'tupdate the traditional map (they must have done so before 2013.
I like the fact that it is more to scale reflects the shape of the country.
Doctor Fegg
9 Nov 2010
Right. I think we can fix that.
I've fired up Illustrator and added the (UK) changes you mentioned. All completely unofficial, of course, and NR and the very talented cartographers at Pindar bear no responsibility for my hacking it about. Still, here's the result:
http://www.systemed.net/carto/network_rail_national_map.pdf
Let me know of any I've missed.
(For a downloadable map I do prefer the New Adlestrop Railway Atlas, but I may be biased. ;) )
