Good morning
Any allocation for 170512 today?
Thanks in advance
Location | Mileage | Arr | Dep | WTT ID | Position / others |
Shrewsbury Abbey | 04:53 | 5G51 | 1 | ||
Shrewsbury Abbey | 04:56 | 05:00 | 5G51 | 1 | |
Shrewsbury | 1 | 05:03 | 05:24 | 2G51 | 1 |
Wellington | 11 | 05:37 | 05:38 | 2G51 | 1 |
Wolverhampton | 30 | 06:14 | 06:15 | 2G51 | 1 |
Birmingham N St | 43 | 06:40 | 07:00 | 2J04 | 1 with 170535 |
Wolverhampton | 56 | 07:19 | 07:20 | 2J04 | 1 with 170535 |
Wellington | 76 | 07:55 | 07:55 | 2J04 | 1 with 170535 |
Shrewsbury | 86 | 08:08 | 08:13 | 1G10 | 2 with 170535 |
Wellington | 96 | 08:25 | 08:26 | 1G10 | 2 with 170535 |
Wolverhampton | 115 | 08:57 | 08:59 | 1G10 | 2 with 170535 |
Birmingham N St | 128 | 09:18 | 09:34 | 1J52 | 1 with 170535 |
Wolverhampton | 141 | 09:52 | 09:53 | 1J52 | 1 with 170535 |
Wellington | 161 | 10:21 | 10:21 | 1J52 | 1 with 170535 |
Shrewsbury | 171 | 10:36 | 10:43 | 2G13 | 2 with 170535 |
Wellington | 181 | 10:55 | 10:55 | 2G13 | 2 with 170535 |
Wolverhampton | 201 | 11:30 | 11:35 | 2G13 | 2 with 170535 |
Birmingham N St | 213 | 11:54 | 12:00 | 2J14 | 1 with 170535 |
Wolverhampton | 226 | 12:18 | 12:19 | 2J14 | 1 with 170535 |
Wellington | 246 | 12:55 | 12:55 | 2J14 | 1 with 170535 |
Shrewsbury | 256 | 13:08 | 13:41 | 2G19 | 2 with 170535 |
Wellington | 266 | 13:53 | 13:53 | 2G19 | 2 with 170535 |
Wolverhampton | 286 | 14:32 | 14:34 | 2G19 | 2 with 170535 |
Birmingham N St | 299 | 14:54 | 15:00 | 2J20 | 1 with 170535 |
Wolverhampton | 311 | 15:18 | 15:19 | 2J20 | 1 with 170535 |
Wellington | 331 | 15:55 | 15:55 | 2J20 | 1 with 170535 |
Shrewsbury | 341 | 16:08 | 16:13 | 1G49 | 2 with 170535 |
Wellington | 351 | 16:25 | 16:25 | 1G49 | 2 with 170535 |
Wolverhampton | 371 | 16:54 | 16:56 | 1G49 | 2 with 170535 |
Birmingham N St | 384 | 17:17 | 17:34 | 2J25 | 1 with 170535 |
Wolverhampton | 397 | 17:53 | 17:53 | 2J25 | 1 with 170535 |
Wellington | 416 | 18:27 | 18:28 | 2J25 | 1 with 170535 |
Shrewsbury | 426 | 18:41 | 18:47 | 2G29 | 2 with 170535 |
Wellington | 436 | 18:59 | 18:59 | 2G29 | 2 with 170535 |
Wolverhampton | 456 | 19:37 | 19:37 | 2G29 | 2 with 170535 |
Birmingham N St | 469 | 19:55 | 20:03 | 2J30 | 1 with 170535 |
Wolverhampton | 482 | 20:21 | 20:25 | 2J30 | 1 with 170535 |
Wellington | 501 | 20:59 | 21:00 | 2J30 | 1 with 170535 |
Shrewsbury | 511 | 21:13 | 21:46 | 2G78 | 2 with 170535 |
Wellington | 522 | 21:58 | 21:58 | 2G78 | 2 with 170535 |
Wolverhampton | 541 | 22:37 | 22:37 | 2G78 | 2 with 170535 |
Birmingham N St | 554 | 22:57 | 23:03 | 5H78 | 2 with 170535 |
Tyseley LMD | 558 | 23:22 |
Looks like Merchants Park, thanksView attachment 103048
Don't know if that helps!
Please can you let me know the allocation of these two South Eastern units today:
375301
Thanks in advance.
Just wanted to bump this in case anyone can help.I’d be grateful for any workings for the following through Cheltenham after 6pm this evening:
800034
800318
802009
802018
802020
802102
802103
802111
802112
802114
Thanks
Thanks
Suspect 60044 and 66082Good afternoon can anyone please advise which 60 and 66 is on the 635F Lackenby to Scunthorpe service. Just saw it sneaking on to the ECML after Gascoigne Wood junction. MTIA
Thank youSuspect 60044 and 66082
I’ve no problem with that at all, I’ve also no problem with someone only checking a few and saying they don’t have time to do the rest.I would like to recommend that ideally, that no more than five or six requirements are posted at a time.
I believe the very kind people who have access to the TOPS system/TRUST etc, all kindly do it in their own time, and may be busy with other things. Also, I am almost certain that the various systems cannot be accessed from home.
The 60 was fine, the 66 may well have been wrong. they were Paired earlier in Tees Yard But 82 may have stayed up thereThank you
Is that Newton Aycliffe? ThxLooks like Merchants Park, thanks
Yes, the Hitachi Factory. Although it didn’t show on TOPS it actually worked 5q60 0821 to Darlington yesterday and back to the factory with a unit. Then showing on RTT it worked light back to Darlington before heading north to Tyne Yard. It then worked 0s40 to Millerhill where it is now!Is that Newton Aycliffe? Thx
Now on one of the many engineering trains in the Innerwick area on ECMLYes, the Hitachi Factory. Although it didn’t show on TOPS it actually worked 5q60 0821 to Darlington yesterday and back to the factory with a unit. Then showing on RTT it worked light back to Darlington before heading north to Tyne Yard. It then worked 0s40 to Millerhill where it is now!
395010 is working:Can anyone provide today's booked workings for 395010 and 395023 please? Many thanks in advance.
Fantastic, many thanks for the gen. Sadly I cannot cover those (am off to Sittingbourne today) but it saves me sitting around in the hope it appears.395010 is working:
1J31 1219 Ashford - St Pancras
1J38 1412 St Pancras - Margate
1J49 1555 Margate - St Pancras
1J54 1812 St Pancras - Margate
Can’t see 395023 out anywhere.
2S01 - Doesn't exist according to TRUST!Morning all, any ideas on the following Sheringham to Norwich services please:
2S01
2S03
2S05
2S07
2S11
2S35
and the following presumably a RHTT run: https://www.realtimetrains.co.uk/service/gb-nr:H16856/2021-09-22/detailed
Many thanks again in advance!!
2S03 - 755402
2S05 - 755334
2S07 - 755420
2S11 - 755327
2S35 - 755333
373C pathed as 3S01, RTT shows as running on that date but nothing from trust, sorry! (Last time I was down at the boxes in that area it was 57s hauling the jets, I'll see if I can get any numbers for you next time I'm down there but it may be a few weeks!
021 - not allocatedGood morning
Would anyone know what services 800021 and 800033 are allocated to today?
Thanks in advance
Stoke Gifford | 05:28 | 5Y03 | ||
Bristol Parkway | 05:31 | 05:40 | 5Y03 | |
Bristol T Meads | 6 | 05:56 | 06:05 | 2Y03 |
Weston SM | 25 | 06:33 | 06:52 | 1A07 |
Bristol T Meads | 44 | 07:24 | 07:30 | 1A07 |
London Paddingtn | 162 | 09:08 | 09:32 | 1C08 |
Bristol T Meads | 280 | 11:06 | 11:30 | 1A18 |
London Paddingtn | 398 | 13:08 | 13:32 | 1C16 |
Bristol T Meads | 516 | 15:08 | 15:30 | 1A26 |
London Paddingtn | 634 | 17:08 | 17:32 | 1C25 |
Bristol T Meads | 752 | 19:05 | 19:14 | 1C25 |
Taunton | 798 | 20:14 | 20:30 | 5C25 |
Bristol T Meads | 843 | 21:02 | 21:23 | 5C25 |
Bristol Parkway | 849 | 21:35h | 21:48 | 5C25 |
Stoke Gifford | 850 | 21:51 |
