BBC News is reporting the South West region is the English region with the most rollout to over 40s (94%) with London being the worse (83%). They are also reporting Wales, Scotland and Northern Ireland are vaccinating under 30s routinely. However, their chart shows only 89% of over 40s have been vaccinated in both Wales and Northern Ireland. A friend of mine who lives in the Republic of Ireland says they are only up to the 45-49 age group, while BBC reports NI are vaccinating anyone over 25 so that's a huge difference from one side of the Irish border to the other.
A look at progress made in vaccinating the country, as more than 52 million people have received at least one dose and 38 million have had a booster or third dose.
www.bbc.co.uk
I wonder if anyone else in the younger age groups is (like me) considering deferring the vaccine until they can get the J&J jab?
I doubt you'll be offered any choice beyond being able to opt out of AZ.
At my local vaccination centre you this week if you're going for a 1st jab you would have got AZ if you're over 40 unless there's a reason why you can't have it e.g. if you're over 40 and pregnant. If you're under 40 or pregnant you get Pzifer, unless there's a reason you can't e.g. an allergy.
Moderna isn't being offered in the area as it's reserved for the areas where administrating Pzifer would create logistical difficulties. The situation would likely be the same with J&J as it's an easy to store vaccine so will probably be reserved for more rural areas which could be hours from a suitable storage facility.
Added to which, if you're in the tail end of the vaccination programme then they'll probably reduce the wait time for second jabs quite significantly.
The 2nd Pfizer vaccine can't be administered until at least 3 weeks after the 1st but as you say it would be the shorter end for those who get vaccinated last, as delaying the 2nd to 12 weeks was to speed up 1st doses.
While it's great to see the advertised age ranges now dropping every couple of days I do wonder if that speed is reflecting more vaccine reluctance amongst younger people?
One thing worth remembering is people in their 30s are more likely to have work and childcare commitments than those in older age groups, so might be less likely to accept the 1st available appointment. They also want to ensure some people are ready to book a last minute appointment if someone else cancels their appointment for whatever reason.
