Railperf
- Joined
- 30 Oct 2017
- Messages
- 2,943
Is there any concrete news on any changes to EPS/nonEPS speed limit changes in advance of the Class 397's entering service?
This thread overlaps (and conflicts with) that on WCML New Rolling Stock Discussion:
https://www.railforums.co.uk/threads/wcml-new-rolling-stock-discussion.188847/
There seem to be two completely divergent views (easy/hard).
Shortly after the 221 Voyagers first ran in tilt mode (Beardy did a lot of advertising around this), I was on one with the passenger information system showing the speed - the PIS showed a speed of 130 mph on this stretch! It was definitely fast - but maybe not quite that fast!An example is the almost dead straight Wolverhampton to Stafford section which has EPS and MU differential speeds of 125mph. This means a non TASS fitted Voyager can travel at this speed through the area.
In theory they could, but on the busiest section south of Birmingham the plan is to have a train every 3min, so each slower one will eat up a large number of paths. The other problem is that platforms on HS2 won't be compatible with existing British gauge stock. Even if they are the right height they will be further from the track to accommodate wider Euro-standard stock (which won't be used initially but probably starts running in Phase 2). Northern Powerhouse Rail and Midlands Connect plan to run regional trains on parts of HS2, which can probably get by with a lower top speed as there will be fewer other trains and they only share for a relatively short distance.I wonder if these new trains will use HS2.
If they are fitted with ETCS, as they are designed to do, there's nothing to stop them running at 140mph or whatever their max speed is.
That would make a difference to the journey time to bi-mode destinations.
They never did introduce TASS anywhere specifically for XC, but did intially use it in areas shared with Pendolinos that had already been equipped for the WCML route modernisation. The original plan I worked on would have seen TASS balises along the route between Birmngham and Reading via Oxford. There were plans for limited stop services on this axis using 221s that would have used TASS for very marginal speed improvements in a very limited number of places. The limited stop idea was abandoned before introduction however, and it turned out that the 220s on the standard stopping patterns could easily equal the heavier 221s performance so the lineside TASS equipment was never installed. Once the WCML Glasgow routes were removed from the XC portfolio, there was no longer any need for tilt at all on the XC network, so it was disabled on the 221s they retained.Shortly after the 221 Voyagers first ran in tilt mode (Beardy did a lot of advertising around this), I was on one with the passenger information system showing the speed - the PIS showed a speed of 130 mph on this stretch! It was definitely fast - but maybe not quite that fast!
Then or soon after. Arriva's 221s have had the tilt equipment isolated, as they use very little of the WCML and it was a source of unreliability.TASS was fitted on the Oxford - Banbury line from Wolvercote Jn to Aynho Jn (both exclusive) and allowed a small but useful uplift in speed (on one section from 90 without tilt to 110 with tilt). Was it de-commissioned when Virgin lost the XC franchise?
I was involved in the study, but wasn't around during the actual implementation. I clearly remember the simulated performance graphs for the two classes though, produced by the Railway Technical Centre (whoever owned that at the time I can't recall!) for the proposed new speed profile. The 221s could only actually gain overall on the 220s if they didn't stop at Banbury, which alternate trains were originally intended to miss. Once that pattern was abandoned there was no benefit at all on the route.TASS was fitted on the Oxford - Banbury line from Wolvercote Jn to Aynho Jn (both exclusive) and allowed a small but useful uplift in speed (on one section from 90 without tilt to 110 with tilt). Was it de-commissioned when Virgin lost the XC franchise?
I suppose once that tiny section on the Oxford - Birmingham was the only useful fitted mileage on the whole franchise, it just wasn't cost effective to maintain the equipment on track and train.Then or soon after. Arriva's 221s have had the tilt equipment isolated, as they use very little of the WCML and it was a source of unreliability.
That would have been sometime during the AEA Technology years.I clearly remember the simulated performance graphs for the two classes though, produced by the Railway Technical Centre (whoever owned that at the time I can't recall!) for the proposed new speed profile.
Well the XC units clearly cannot take any advantage of those today! My strongest recollection from the study generally was that without very long non-stop segments (as VXC originaly had on the Glasgow runs) there was very little, if any, journey time improvement to be gained from tilt, as the extra weight of the 221 compared to the 220 led to slower acceleration that was not compensated for by the small sections of marginally higher speed possible. The study I worked on was sponsored by VXC and we had no influence over what was done on sections being modernised under the west coast programme such as Stone - Cheadle Hulme.Are you saying there was/is no point in the Stone-Cheadle Hulme TASS? There are some significant EPS sections on that route.
WoW ! that’ll enable a huge time saving on a tiny number of services it may ultimately be deemed beneficial not to stop thereAlso speed improvements along other sections (to go fast, avoid going slow strikes again), such as Carlisle station, with its 20mph PSR upgraded to 40mph.
There's irony in the end result of this, that the standard timings were based eventually on heavier 221s operating without tilt, rather than more sprightly 220s. Those 221s have all been lugging around an additional eight tonnes per car needlessly for the last decade.I think another issue with the Cherwell Valley TASS area was that they never successfully guaranteed that any particular services would be operated by 221s, so timetables allowed for a 220 turning up anyway.
HS2 is expected to have platforms far enough from the track so they don't foul European-gauge stock, although I think there is still a debate about how high they will be. The classic compatible will need to safely serve these platforms and also UK-standard platforms on the classic network. The 373s had a similar requirement, hence the rather complicated extending steps, though they no longer serve UK-standard platforms since completion of HS1. 395s only serve UK standard platforms, which are provided on separate tracks at the HS1 stations.Will they not? I thought that due to classic compatible stock they'd have to be
No the HS2s 'classic compatible' units will have to be compatible with both platforms on the new line which will be either 915mm or around 1100mm above rail, but set back to UIC clearance, and traditional 915mm platforms on the conventional network that are closer to the rail. Modern trains usually cope with such variability by means of a moving gap filler step that extends as required below the external doors.Will they not? I thought that due to classic compatible stock they'd have to be
Apart from (especially) 11-carriage trains being able to clear the speed restrictions at a faster rateWoW ! that’ll enable a huge time saving on a tiny number of services it may ultimately be deemed beneficial not to stop there
There will need to be a lot of work done in certain areas to make it worthwhile.Not too many years back Virgin Trains wanted to be able (or were discussing) to run Class 390 at a top speed of 135 mph EPS without in-cab signalling on the West Coast Mainline in parts. Nothing came of that. Was that down to Dft or Newtwork Rail on costs grounds. So it amazes me that they are looking into introducing 125 mph running on certain parts of the mainline, as there will be big infrastructure costs involved.
