WCRC loses judicial review in High Court
paul1609
28 Jan 2006
Wittersham Kent
As has been previously mentioned, other TOCs have successfully fitted CDL to Mk1 stock and also significantly improved the crashworthiness of that stock so I don't see why Mk1s should be retired as you suggest.
As has also been previously mentioned those have tended to be DMUs which have a completely different electrical supply or coaches that were supplied or modified in BR days as either ETH or DualHeat. The crashworthyness is inherent to the original design of the coaches it can be mitigated to an extent by stuff like overide protection but they will still lack the crashworthyness of MK2 with their hybrid construction or MK3 with monocoque construction. Im afraid I dont think that you can make a financial case for the majority of the remaining VAC/ Steam heat mk1 stock to be CDL fitted.
23 Nov 2015
Not trying to go OT, but wouldn't that be viewed as problematic given if coaches derailed and (partly?) tipped over, evacuation from such a kitchen car might be even more difficult?
Not if you fit emergency door releases.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
In an accident as serious as that opening coach doors above one would be very difficult! I would suggest smashed windows would be used instead, and passengers would need assistance to climb out of coaches whether through a (narrower) door or window.
Ayrshire Roy
8 Feb 2019
I wonder if there is reason they can't use vacuum actuators for the door locks.
It would solve the lack of electricity problem straight away.
43096
23 Nov 2015
You’ll need an electrical feed regardless, as control would be electrical, even before you get to things like the door indicator lights.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
Maybe you could even put all the doors out of action (except for said emergency release) on half the passenger coaches. Strictly speaking do they have to have non emergency doors? This could be a lot cheaper than fitting them all with CDL.
And if that is acceptable... don't forget to put the emergency release on the outside too and make it easy to reset
Wyrleybart
29 Mar 2020
South Staffordshire
I guess this is basically what was done to the class 117 and 121 DMUs. Half the doors were welded up and the remaining ones fitted with magnetic CDL
If you look at "Flora" in this video there appears to be just one "public" door on this side and the guard's door where it always used to be.
12LDA28C
14 Oct 2022
The back of beyond
As I mentioned upthread, the CDL system on 'FLORA' is a bolt, not an electromagnet arrangement as fitted to the other two ex-Chiltern bubble cars.
357
12 Nov 2018
I don't know if these coaches are only fit for scrap, if they are unused, or if they are raising funds for work on the Mk1s but I've seen this in an industry magazine:
Mk 2 E&F Air-Con Coaches FOR SALE
WEST COAST RAILWAYS
6151MK2F - TSO
5929MK2F - TSO
6073-MK2F - TSO
5815MK2E - TSO
5958MK2F - TSO
6009 MK2F - TSO
6134-MK2F - TSO
6154MK2F - TSO
6029MK2F - TSO
5888 MK2E - TSO
6045MK2F-TSO
5978MK2F - TSO
1252 MK2F - FO
1253-MK2F - FO
All are Based at Southall Depot and are open to Bids (lots preferred)
Closing Date will be April 19th 2024 Buyer/s will Collect from Southall
These Carriages will be sold as seen and where lying without any warranty, condition or undertaking including (without limitation) as to quality, position in any programme or cycle of maintenance, or fitness for a particular purpose.
Please contact XXXX or XXX at West Coast Railways to organise Viewings on XXXX XXXXXX (those who intend to make a serious enquiry will know where to find this info)
Peter Mugridge
8 Apr 2010
Epsom
I went past Southall yesterday en route to and from Reading.
Those carriages are, at least visibly, in an absolute state - they're visibly coated with mosses and lichen for a start...
What can't be seen from passing trains is, of course, their mechanical state but we can take a guess based on how long they've evidently been lying around to get into such a visual state just what sort of physical condition the bogies and bodyshells might be in.
43096
23 Nov 2015
Somewhat ironically, they are fitted with CDL, though.
JKF
29 May 2019
Maybe someone can buy them all and stick them in a field in North Yorkshire to rot for a decade before scrapping them?
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
They may be, but I can guarantee they are at least a little more weathertight than some of LSL’s recent Mk2 purchases…
(At least 3 of those are destined for the bin)
northernbelle
10 Oct 2018
There must be some level of confidence that something will run this year - WCRC 37676 moved to Fort William this week.
D365
29 Jun 2012
Is that not just a standby loco that WCRC provides anyway?
Sentinel
8 Dec 2019
Macclesfield
West Coast Mk2s and Riley’s Black 5 44871 (air brakes of course) on the RTC Stratford Flyer from Manchester to Stratford this Saturday.
Towers
30 Aug 2021
Didn’t they also catch fire at some point in recent history? I’ve often wondered if they’re there to form some sort of supposed security barrier between the outside world and the working heritage stuff in the shed.
WCRC looking to raise money from scrap to help fund the inevitable CDL fitment perhaps? Doesn’t appear to have been any inclination to sell this lot for the past few decades!
Iskra
11 Jun 2014
West Riding
I note that the usual summer Dalesman/Scarborough Spa services are now advertised on the WCRC website. With what stock will these run and how will WCRC ensure the rolling stock is compliant, does anyone know?
12LDA28C
14 Oct 2022
The back of beyond
They have a compliant rake of Mk2s, or they could hire in from elsewhere, eg Riviera, dependent on the steam loco being dual braked.
22 Jun 2023
Croydon
I think its their own set they are mostly using atm. They have quite a few air brakes locos to pick from including the black 5s of jacobite fame so that's not a problem
anothertyke
23 Jun 2023
But once the three black 5s are at Fort Bill they do have a problem assuming they need air braked locos. According to Trackside magazine they are in conversations with ORR. Maybe they will have demonstrated enough progress with the Jacobite and Northern Belle sets to be granted an exemption similar to Vintage to see them through summer '24.
Iskra
11 Jun 2014
West Riding
This was my thinking too. Presumably, there's a reasonable chance of non-Jacobite operations being curtailed at the expense of keeping that lucrative service running, if it comes to it?
anothertyke
23 Jun 2023
Possibly but ORR need to be even handed. They have been willing to grant exemptions to Vintage and SRPS on the basis of a plan for CDL fitment and progress towards delivery on the plan. Fairly soon, at least by the time of the GB tour, things should be clearer.
22 Jun 2023
Croydon
As mentioned before Rivera are currently making a Mark 2 set with Mark 1 style windows in the coaches. Maybe that is long term plan for the Jacobite
12LDA28C
14 Oct 2022
The back of beyond
That's more likely a plan to mitigate the effects of air con failure which seems to happen fairly frequently on the Riviera air-con rakes. It would cost WCRC a fair bit hiring in a rake of stock for months on end.
