Anyone know what temperature are the rails and overhead cables are stressed to, so that speed restrictions aren’t needed, there is presumably a threshold temperature that determines if any might be imposed.
Rails in this country are stressed to be stress free at 27C. However immediately after installation (ie before stressing) and following any work that disturbs the ballast, and certain local conditions can reduce this stress free temperature - often considerably.
In good quality, undisturbed track, that is straight, flat bottomed rail (109 or thicker), and on concrete sleepers of at least 26 per length or slab, Mitigations are required when measured rail temperature is 32C
above the Stress Free temperature (ie 59C) and the first speed restriction is required at 37C
above the Stress Free Temperature (ie 64C).
At this time of year, rail in direct sunlight can be up to 20C hotter than ambient. So you can see that good quality, undisturbed track of the type mentioned above that has been correctly stressed will not need any mitigating actions until air temperature is 39C.
Heat based speed restrictions occur because the track is one or more of:
lower specification (eg one or more of on timber, steel, bullhead rail, wider sleeper spacing)
curved track
not good quality
recently disturbed (tamped, stoneblown, manually ‘shovel packed’)
subject to subsidence or voiding
short of ballast
rail not stressed to 27C
each of these have factors to apply to the stress free temperature, for example a curve between 400m and 800m radius effectively brings the temperature required for mitigations down by 7C. Timber sleepers reduce it by 9C. Recent tamping brings it down by 12C.
This, of course, means you need to keep detailed records of all of this stuff, and any gaps in the records means you have to assume the worst case.
EDIT:
having done some research, I’ve found that Spain uses an SFT of 27C, France uses 25C; USA uses a variety of temperatures depending on the temperature range at the location concerned.
I’m tempted to say “it’s that simple” …. But it isn’t, really. (I’ve tried to make it as simple as possible).
OLE is not stressed to a temperature as such. You can tell it’s too hot when the balance weights are on the floor…
