Happens at quite a few places on the network. Birmingham New St and Man Picc are both RA Dispatch to all services.Can someone tell me why Avanti and beforehand Virgin would use 'RA' indicators instead of the Train Manager giving the driver 2 on the buzzer? The only other time I have seen them used is on driver only services.
Only for some services.Oxford uses RA indicators as well
Only for ECS movements.Derby has them as well.
They are there to stop a ding ding and away accident the RA will only light up if the signal has a proceed aspect, if platform staff press the RA button when the signal is red it will not light up and train will not move.
(Non-facetious answer - it dates from the time of loco haulage when bell buzzers were not fitted. As RA is linked to the aspect of the signal and cannot at most locations be given against a red it was deemed safer to keep the method of dispatch as is when the 390s were introduced. Why a 9 car 390 needs an RA when a 10 car 221 or 12 car 319/350 can be happily dispatched on bells at certain locations I couldn’t tell you, but such is the railway)
Never liked dispatching a slam door HST with an RA. As of course no interlock and in theory you could be left on the platform, if the platform staff muck up with or without doors unlocked/open.....which has happened.They are there to stop a ding ding and away accident the RA will only light up if the signal has a proceed aspect, if platform staff press the RA button when the signal is red it will not light up and train will not move.
I would imagine so.We can presumably look forward to HS2 high speed stock doing the same at WCML stations when it comes in then...
Right Away and Close Doors. However CD RA are the correct terms."RA" indicators?
"CD" indicators?
Excuse my ignorance...
Correct. They are light up signs operated by platform staff.Thanks. So are these signs to that effect on the platforms, operated by platform staff? Or am I misunderstanding? (Not unlikely!)
Particularly on stations which are sited on curves, there is also the 'OFF' indicator:"RA" indicators?
"CD" indicators?
St Mary Cray, Brighton, Sevenoaks
As is Brighton (hence corresponding hand signals, although oftentimes on the South Central the so called disco bat is now used)St Mary Cray (IIRC) and Sevenoaks are bat and flag.
I'm not sure that's correct universally. Dispatch staff have given RAs on reds before and been disciplined accordingly.
It isn’t possible to give an RA indication unless the signal is off, because the indicator is interlocked with the signal.
Never seen them unless they are in the same box as the OFF indicators?Derby has them as well.
They were originally used and installed for loco hauled stock and as they operated alongside 390s for many years I assume they were dispatched in that manner for consistency. The 221s however use the bell buzzer away from RA compulsory stations.
At New St and Man Picc they're used to mitigate the signalling system not meeting the usual standards of overlaps etc, in theory it prevents a train departing with a red signal.
All very interesting, Thank you. Any idea why the 221s are different to the 390s at most locations? Could this be something do do with operating to North Wales and Shrewsbury where 390s don't go.RA indicators are used for all services at New Street, Manchester Piccadilly and Glasgow Queen Street High Level, also Reading 1-3 and all London termini except for Kings Cross and Paddington (DOO stock only) and Waterloo (empties only) (possibly not used at London Bridge for 171s either).
390 trains only use bell buzzer dispatch (under normal circs) at Tamworth, Lichfield, Warrington, Wigan, Oxenholme, Penrith, Lockerbie and Haymarket (and possibly Motherwell). RA everywhere else. 221s bell buzzer except for Euston, New Street and (should they ever end up there) Piccadilly.
There are several places where DOO trains are only ever started with the RA or sometimes CD/RA indicator (or corresponding hand signals) but they’re probably too numerous to list. Slough, Reading, Oxford, Colchester, East Croydon, St Mary Cray, Brighton, Sevenoaks and Gatwick to name but a few.
As for why Avanti use this method, the roots go back to the ancient Egyptians. As we all know there is a substantial complex of sacred pyramids in the Runcorn area, and to fend off the marauders from the north, the charioteers used to offer a blood sacrifice to the sun god Ra, a tradition that carried on into BR days. When Dr Beeching (a High Priest of the rival sacred house of Anubis) came on the scene, he decided that hiring a large contingent of platform staff, revenue protection inspectors, station contracts managers etc solely for the purpose of human sacrifice was a bit of a drain on the training budget so he had the Grand Visier develop the RA indicator as a low-cost substitute (it was originally meant to be a hieroglyphic but they’re quite hard to do in LEDs) Ironically the badlands in the north were among the last to adopt this method, and it’s still said at Tamworth and Penrith an additional staff member is kept in readiness to carry out the divine ritual once again, in the event of a bell buzzer failure.
This indicates to platform staff that the signal at the end of the platform is showing a 'proceed' aspect and they can set about dispatching the train.
They operate the 'CD' indicator to tell the driver or guard to close the doors:
and then the same unit is switched to 'RA' for Right Away:
The above are part of the collection at the St Albans South box and will eventually be set up as one of our demonstrations.
The above photos were taken while we were experimenting with 3.5Watt LED lamps to replace the original 55W filament lamps. Quite bright enough for our use at short viewing distances and a lot lighter on power and cable sizes!
I always assumed those were individual LEDs. How does the actual switchover work, then? Is it mechanical using a sliding mask?
What is it with you and bloody masks .
