ANDREW_D_WEBB
- Joined
- 21 Aug 2013
- Messages
- 869
Several trains have recently started serving Westbury Cement Works (Westbury Tarmac on RTT). Given that the cement works is long closed, the chimney demolished, what are these trains carrying?
ThanksFreightliner are using the place to stable wagons saves paying DB access fees to the Westbury Yards.
an American owned operatorIf you told your enthusiast self fifty years ago there would come a day when a UK railway operator would stable wagons in an old cement works because a German railway operator owned the main line sidings you'd consider there to be a serious mental health issue arising.
I'm not sure that things are so different. Even back in BR's day private owner wagons could attract 'siding rent' charges if left cluttering up important yards (such as Westbury). So stabling in private sidings was incentivised.If you told your enthusiast self fifty years ago there would come a day when a UK railway operator would stable wagons in an old cement works because a German railway operator owned the main line sidings you'd consider there to be a serious mental health issue arising.
Yes, which means Freightliner get charged to use it.What is the situation at Acton Yard out of interest, is that DB-owned too?
You still require a shunter to access both the Up and Down yards at Westbury.Of course, the benefit of using Westbury yard is that it is properly segregated away from the main passenger lines and does not require the provision of a shunter (person) in order to clear the main running lines. Using the cement works means impinging on the B&H (in both directions when exiting) at Heywood Road Jcn which potentially delays through traffic.
Trains can arrive/depart from the Up/Down Reception Roads without a shunter.
I can't see why this sort of thing is such a big deal. It has long been the case that freight track access agreements require the operator to arrange to promptly clear the train off the main Network Rail system (whether into a 'yard', 'terminal', 'depot' or whatever).Indeed, and this is my point. If (for whatever reason) the Cement Works shunter isn’t available then the train will stand on the main line, blocking it, until it is admitted. One would hope that FL have a robust system whereby trains will not depart the quarries until the shunter is confirmed to be in place.
If they're owned by DB, aren't they private sidings just like the Cement Works?The complete nonsense of privatisation. In any sane world it just would not happen.
Which has led to Freightliner deploying mid-train locos on jumbo trains to avoid spending too long splitting / joining in Acton Yard. One wonders how high DB's bid was for the work if Freightliner could undercut them despite the former owning a lot of the vital infrastructure on route.Yes, which means Freightliner get charged to use it.
I know what you mean, but I think it's actually the other way round: Freightliner was able to put in a low bid because theyOne wonders how high DB's bid was for the work if Freightliner could undercut them despite the former owning a lot of the vital infrastructure on route.
I'm not sure that any facility owner can get away with charging 'punitive' rates. That would seem to be 'abuse of a dominant position' in competition law terms AIUI. ORR is, of course, the regulatory body for both track access and railway competition issues.I know what you mean, but I think it's actually the other way round: Freightliner was able to put in a low bid because they
don't own a lot of expensive to maintain 'legacy' infrastructure such as yards and depots.
But I get the feeling that they didn't realise that DB would retaliate by charging punitive fees for using those facilities!
MARK
Perhaps we should have gone down the same route as Austria where the infrastructure authority is responsible for the yards (and shunting in them) with a standard set of rates for all operators.I know what you mean, but I think it's actually the other way round: Freightliner was able to put in a low bid because they
MARK
Does that apply to locos Dead in Transit where they are effectively just part of the consist? I don't know as I'm not railway, just my impression that could be conveyed mid consist, so happy to be corrected.Didn't think locos mid train were allowed?...at least not for anything other than an emergency.
Who says it’s a “punitive” rate? Network rail base charges on weight and type of train and charge for leaving trains in stations so I guess there’s already a “going rate” and DB a have to make some money somewhere.I'm not sure that any facility owner can get away with charging 'punitive' rates. That would seem to be 'abuse of a dominant position' in competition law terms AIUI. ORR is, of course, the regulatory body for both track access and railway competition issues.
It certainly used to be the case that there was a standard (modest) fee between all of the freight operators for basic services like a run-round move or a crew change in 'somebody else's' sidings. That is slightly different to leaving rakes of idle wagons cluttering up the place, potentially for days on end.
As I have noted above, even BR could charge 'siding rent' for private-owner wagons left in its yards for lengthy periods for the owner's convenience.
I was referencing a post by @Freightmaster (who did not reveal the basis of the claim).Who says it’s a “punitive” rate? Network rail base charges on weight and type of train and charge for leaving trains in stations so I guess there’s already a “going rate” and DB a have to make some money somewhere.
In this instance the shunter is a person......
I hope this helps.
Bearing in mind that Freightliner is owned by Genessee and Wyoming, and that remote controlled operation of mid-train and rear-end Distributed Power locomotives is well established and commonplace in the USA, I wonder if they're making any moves to get that trialled here?Ordinarily not allowed, any Dead in Transit locos must be marshalled directly behind leading loco (which leads to over the top YouTube video titles like “Mega-Rare SEVEN 66s to pull 1 China clay wagon”)
Freightliner have secured ORR and Network Rail approval to marshall dead locos mid-train (in the correct position to split portions) on a trial basis for some of their Mendip work, allowing them to forgo use of Acton on some workings.
The down reception (DR) line at Westbury seems to be being used as a run-round more now too. Trains off the Salisbury line, or even from Exeter, heading for Whatley or Merehead seem to be parked on the DR whilst the loco uncouples and runs round via one of the platform lines in the station. This obviously blocks the DR for some time, so through freights have to use the platforms. Might be a case for reinstating the other island platform fully - currently just one face is used (plat 1).
