What are these? (Metal cylinders next to track)
jnjkerbin
25 Apr 2012
Down south
I went for a walk a few days ago, and saw these tanks next to a railway line (this was taken from the bottom of the embankment with the railway line behind the tanks). This is a section of relatively high speed, gently curving track. There were some sidings nearby many years ago. Does anyone have any idea what these might be?
FGW_DID
23 Jun 2011
81E
Wheel flange lubricator. There’s one similar on the Didcot Avoider IIRC.
Edit to add photos of above which I remembered I had taken from a static train.
1396B2E2-FDA0-4F82-9493-54E44C34943C.jpeg 9EC9A3DB-7435-4726-95DF-F22A96D0122F.jpeg
TheEdge
29 Nov 2012
Norwich
They are indeed flange lubricators, grease pots and whatever other name they go by. They just, as the name suggests, lubricate the inside of the rails and wheels to reduce wear and tear and quieten the squealing down.
Sir_Sheep
15 Jun 2014
I’ve been asking the very same question about this on platform 13 at Manchester Piccadilly! Thanks for answering :D
EssexGonzo
9 May 2012
hehehehehehehehehehehehehehehehehehehehehehe - flange!
my favorite bit of railway equipment. I had to order some once and it was VERY hard to keep a straight face and remain professional while on the phone!
PS i knew without looking this was either a question about a datum plate or a flange greaser
I am so glad that someone else was sniggering at the back.
Quite possibly the best piece of transport-related equipment I've ever heard of. It has displaced the Grease Nipple.
The Lad
22 Jan 2015
In the photo on post 4 the lubricators are for the back of the flange against the check rail.
They are more common for the other side of the flange.
TheEdge
29 Nov 2012
Norwich
I don't think any true railwayman won't be giggling at the thought of a well oiled flange.
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Of course, the S&DJR's "Leaking Cocks" sign is another classic, but drain cocks seem to be a thing of the past on the UK network...to the dismay of satirists everwhere, probably
