What happens when you press the compressor speed up button whilst the train is in motion?
TeeEfDub
23 Jan 2024
Cheshire
So from what I believe the compressor speed up increases engine rpms, used to build up air faster when a unit is taking a while to build up air.
But what would happen if you press it during motion?
WF4HA5HE
17 May 2022
Sheffield
If its turned on whiles in motion on a 15x class of unit the brakes will apply to the equivalent to full service braking and will hold the brake at full until the compressor speed up is switched off. I've heard numerous stories of train crew flicking the compressor speed up as on 158 for example by accident and bringing the train to a sudden stop as it's directly above the cab light switch. In the dark its an easy mistake to make.
TeeEfDub
23 Jan 2024
Cheshire
Thank you for the thorough answer! I had an idea that it would probably bring on some sort of brake demand. I was confused however because on TS3 (on a class 150/2) when I tested it nothing happend, maybe it's a setting or maybe it's not as realistic.
1D53
2 Apr 2006
Doesn't sound realistic. On a 150 you'll be stopping very quickly!
