At the moment Paddington has 13 platforms, 2 of which in the off-peak are used solely by TfL Rail. It is obviously the terminus of the GWML although some would argue its one of the most distant London termini compared to the centre. It was the 11th busiest London station last year (although likely an outlier).
When TfL Rail essentially becomes the Elizabeth Line and runs through the Central section & bypasses mainline Paddington, for anyone in the inner Thames Valley that needed to change at Paddington to get further into London, that need is removed - you could even change at Ealing Broadway if you were on a slightly faster Didcot Parkway - Paddington service. Obviously past Reading, changing at Paddington for Crossrail will be the natural course of action. The station is already a bit constrained with the TfL Rail services still running (Heathrow Express on one platform only most of the day) and the removal of these services from the NR station would allow a bit of breathing room and scope to amend the high-speed service a little. However the opening of Old Oak Common in 5-6 years seems like it would be totally different.
Old Oak Common is meant to have a number of main & relief line platform faces and I believe the intention is for every Crossrail & GWR (and HS2 for what its worth) service to stop at Old Oak Common. This should provide a much easier interchange for passengers from beyond Reading as well as HS2 and passengers from Heathrow. At this point the reason from going all the way to Paddington diminishes - the interchange to C. London is much easier for basically everyone, people want to go to other parts of London also have better connections (except perhaps the Southeastern / Southwestern part for which the Bakerloo may still be the best) and the station isn't that close to the major London landmarks, and the Relief Line service can't be increased with all the Crossrail paths.
You'll then have a 13 platform station, which might essentially become a glorified turnback. Is this fine? Will there be a more critical evaluation of the 4tph Heathrow Express paths to increase high-speed services? Will some platforms become redundant and used for other purposes? Whilst the same argument could be used for Liverpool St, it's proximity to The City I think means it is less relevant.
