Which junctions would you grade-separate?
Zomboid
2 Apr 2025
Oxford
My pick for grade seperation would be Skelton Jct above York, if a flyover was constructed running parralel to the outer ring road then the Harrogate line could connect with the Scarborough line and avoid the need for services to and from Harrogate to use the ECML.
Since we've got the crayons out, how about resignalling the York - Northallerton line to be paired by use (fast lines to the east). The 3 track bridge at Skelton Jn would complicate it, but the platforms at Thirsk are in the right place at least, and it would match the 4 tracks south of York.
I don't know when ETCS is due up there, but that would be the ideal opportunity to start from a cleanish sheet of paper.
8 Feb 2021
York
The current paired by direction works pretty well for that section. Means freight is out the way and can use the Longlands diveunder to get to and from Teeside without having to go through Northallerton station.
It also allows for the Teeside TPE & Grand Central services to run on the fasts York - Thirsk before swapping to the slows to call at Thirsk without blocking the whole ECML
Legolash2o
27 Sep 2018
I wouldn't bother with Micklefield.
If the highspeed bypass is built as proposed by HS2 but connected to Crossgates instead as some would like, then it would be much more sensible to install a new chord to connect Micklefield to South Milford for the slow services and dispense with the junction at Micklefield altogether.
That makes sense, thank you for the insight.
fishwomp
5 Jan 2020
milton keynes
Not going to happen. If we keep believing we're waiting for HS2, powerhouse, etc then nothing will happen.
Although I am aware of plans to create a 3rd line, ECML & Harrogate services will still conflict. I would rather see them fully segregated.
Or, put the Harrogate on the avoider, freight line, and (re)build the third side of a triangle west between the station and the Holgate bridge. All without flyover and diveunders.
duffield
31 Jul 2013
East Midlands
Going back to Newark flat crossing on the ECML, I've seen vague talk about removing it to increase capacity on the ECML, but what I'm not clear about is whether that translates into reality. That's to say, we have the soon-to-be four passenger service paths (two in each direction per hour) and the two freight paths (one in each direction per hour - I think, haven't checked). If all of those six crossings per hour were removed, would it actually create more usable capacity on this section of the ECML or would it not actually be usable due to constraints elsewhere?
I'm *guessing* that the answer is it probably doesn't create significant extra *usable* capacity, otherwise it would have been done by now, but maybe it is useful but the DfT/NR just blanch at the sheer cost.
I must say I was surprised when extending the Newark Castle terminator to Lincoln and beyond was given the go ahead, adding 2tph to the crossing.
I suppose that's maybe also an indicator that it's not a critical constraint by itself?
MarkyT
20 May 2012
Torbay
What's the extra capacity/flexibilty for? To create new capacity or better manage that which exists today. I'd argue that at critical junctions like Newark the main line has absolute priority and the intersecting line must be managed accordingly. That means pathing time allowances and effective speed advisory systems to prevent heavy freights having to stop and slowly get underway again.
A small local train can nip across the junction in a small margin of course.
DynamicSpirit
12 Apr 2012
SE London
Perhaps it's a question of that junction being one (of several?) constraints that would need to be removed if we are to ever get many more trains on the ECML. But yes, my instinct is to agree with you. I'd imagine that, for example, the Welwyn viaduct must be just as significant a capacity constraint.
On the other hand, that flat crossing must be an utter nightmare for timetable planning and for reliability. I could imagine that alone being considered a good reason for grade-separation.
By the way, on a quick check of the Nottingham-Lincoln timetable, it looks to me like the trains are timed so that a train in each direction crosses the flat crossing at about the same time. If that's done with all the other paths, then even with the higher frequency you mention, you'd only have three times per hour that the crossing is blocked to the ECML, not 6 times.
duffield
31 Jul 2013
East Midlands
Yes, it hadn't occurred to me that the crossings were timed to be the same, because although I've been over the crossing many times and I always pay attention at the flat crossing, strangely I don't ever remember seeing a service passing in the other direction at that point!
Maybe I'm always on the wrong side of the train (I do tend to sit on the left on those services).
I suppose I'd guess each pair of passenger services would need a 2-3 minute slot and the freight maybe 3-4? So that would mean a total of somewhere between 7 and 10 minutes an hour when the ECML section was blocked?
I expect that it won't take too long before a 'definitely-not-HS2-guv' emerges to bypass Colwich and Stafford once the southern section is open, because as you say that will release paths into London.
Westerleigh I'd grade separate to speed it up, it certainly feels damned slow for the diverging route. I'm pretty sure it is on a couple of shopping lists but no idea where it falls on the priority ranking.
Yes that's basically what I'd do. Get as close to the viaduct as you can and build through smoothest curve possible.
If possible taking advantage to put the freight connection in the middle and including a single track chord towards Chipping Sodbury would be very much nice to haves.
If it were possible I'd realign the link towards Cheltenham to diverge off the up main before it passes over the freight line, such that the link joins the freight line on as smooth a curve as possible, which is then upgraded to become the mainline. The link to the down line would then pass underneath the mainline on a different alignment (so it doesn't close for as long while being constructed), but with cant allowing higher linespeed through this link.
No one’s mentioned Lewisham and Park’s Bridge Junction yet. Stunningly expensive.
What I'd do here is try and realign the junction complex so any spur/crossover can be traversed faster, thus services don't block the area as long. For starters, if Bertrand St bridge was replaced with one that allowed a crossover to be on it, the crossover here could be elongated, allowing the 15mph linespeed to be increased, maybe to 30-40mph. The link to Ladywell maybe harder to increase as the alignment can't really change, which IIRC is currently 20mph, and the link from Hither Green to Lewisham I strongly doubt can be increased from 20mph either, otherwise they'd have probably done it by now.
Zomboid
2 Apr 2025
Oxford
Newark would probably not on itself create a huge amount more capacity on the ECML (though it probably would help with the Nottingham - Lincoln line), but it would remove a timetabling constraint on both lines and reduce the impact of disruption.
There's probably a few things that would be needed to enhance the ECML, and that would be one of them - and unless you take the first bite, that elephant isn't going to be eaten
Well, that has been the strategy for the past few decades, incremental improvements.
Just on the ECML proper in the last 20 years we have had the Allington Chord, two rounds of new platforms at Peterboro, Hitchin flyover, Shaftholme flyover, several rounds of power upgrades, Kings Cross Platform 0, the Thameslink connection, Kings Cross remodelling and resignalling, new platforms and uprating of the ‘outer’ slow lines south of Ally Pally, doubling of S Yorkshire junction, adding in an extra line at Holgate Junction, Werrington dive under, and the new platforms at Darlington on the way.
Added to that are various uogrades to branches and other lines which have helped the ECML (such as resignalling the GN/GE via Sleaford), and it is a significant long term investment.
