Will the Newcastle services stop at Stalybridge once electrification is complete?
darylyates17
8 Nov 2015
St Helens
Moderator note - split from:
Will the Newcastle services stop at Stalybridge once electrification is complete? to allow the 802s to run on electric between Manchester Victoria and Stalybridge.
Class 170101
1 Mar 2014
Don't think they would need to stop to change from electric to diesel and vice versa
superkev
1 Mar 2015
west yorkshire
Didn't I read on here somewhere that no electric capable trains were to be timetabled to run from Vic to Stalybridge all going to Picc.
K
507020
23 May 2021
Southport
K
That can’t be right. Both the 769s and 802s that will be using the wires serve Victoria.
3RDGEN
6 Mar 2023
Hull
K
The proposed timetable means the current two hourly 802 operated Manc Picc to Newcastle service is cut leaving only the Manc Picc to Hull TPE service using 185's from Picc to Stalybridge. There maybe an odd early/late services going that way but no regular electric service for now, still allows Northern to move electric units from North to South Manchester via Stalybridge if the west side is blocked.
Not sure if the 802's actually run on electric Picc to Guide Bridge now, is it worth it?
AndrewE
9 Nov 2015
If you are at all concerned about - or just want to get brownie points for - getting diesel exhaust out of a city centre then it certainly is!
SuperNova
12 Dec 2019
The North
it’s a recovery timetable. Not permanent.
PTR 444
22 Aug 2019
Wimborne
Isn’t that Stalybridge to Picc rather than Stalybridge to Vic?
3RDGEN
6 Mar 2023
Hull
From the December timetable the Liverpool - Newcastle services do call at Stalybridge so presumable will changeover diesel/electric there once its all signed off. Manc Vic to Staylbridge should therefore see electric services from TPE & Northern in the near future.
The TPE services to Manc Picc will in general be the Hull services using 185's so Stalybridge to Manc Picc will see few electric services in the short term.
