Woking - Basingstoke (near Hook) landslip (15/01/23)
Bristol
Doesn't the crossover between the fast lines face the wrong way which will require a double reversal to access the up fast from the down fast?
As the landslip is on the Up side, you could route Up trains onto the Down fast at Basingstoke then back over to the Up fast at Winchfield without reversal, although the crossover at Winchfield may need staff to secure it, and you wouldn't be able to get to the Up slow until Farnborough.
vikingdriver
11 Mar 2010
Down side
RPI
6 Dec 2010
No doubt it will be essential to run 2 hourly on the West of England line again..... (sarcasm)
strimmer
29 Jan 2010
The trailing crossover at Winchfield has been used many times, for SLW in connection with engineering work. It used to require a flagman, but now has the benifit of simbids.
Omnishambles
13 Jul 2019
Top of the head thought, Farnborough slightly easier.
probably easier to put a quick new half-set in tonight and clip it up
IslandLine101
8 Dec 2022
Shropshire
It’s a real shame that this has happened - SWML passengers have really suffered the last few days. However it will be very interesting what timetables SWR manage to think of and decide to run tomorrow and for the following weeks. Without reversals it will be a two track railway Woking - Basingstoke.
Hopefully by Wednesday they will have sorted out a way to run 2tph on their remaining two lines…. And in the meantime if they can get 1tph from Salisbury into Reading from tomorrow morning that would be a way to minimise the damagel
Omnishambles
13 Jul 2019
Hopefully the DF can be reinstated reasonably quickly and would be good to see some joined up inter-regional thinking to divert to Reading where needed to offer a further connection to London
ABDeltic
3 Oct 2018
SLW was fairly common on the SW Main line until about 5 years ago but almost non existent now. Would be good if something could be sorted though, it's been terrible these last few months with strikes, covid timetables etc.
Nicholas Lewis
9 Aug 2019
Surely on the DS they can run unrestricted the DF will presumably used for SLW and 2tph should be manageable although Winchfield will be too close to site of works. DF looks like a bit of fettling and 5ESR could make it runnable depends on how stable the rest of the embankment is but does look like its the add on for four tracking thats failed and not the original embankment from the video.
At least it happened whilst the line was under a T3 could have caused a nasty incident if it had failed under traffic.
30907
I imagine the DF will be part of the worksite even if it is passable.
Nicholas Lewis
9 Aug 2019
Initially they will have to stabilise the embankment with a cofferdam at the toe before they restore the formation so could use it for several days but with planning being such a constraint these days easier just to put in place a plan using SLW over the DF for the duration and see what else they can divert.
It’s the down side that has the landslip, the down slow is in mid air and it will be the down fast that’s not fully supported. Both down lines are blocked with an engineers train (6G14) parked on the up fast according to the opentraintimes maps at the time of this posting.
TSG
10 Aug 2020
Somewhere in the South of England
It's probably a push button motored ground frame now, but I'm pretty sure there's no bidirectional signalling, simplified or otherwise, between Basingstoke and Woking unfortunately.
fandroid
9 Nov 2014
Hampshire
Is there the capacity to send the Salisbury stoppers up to Reading as per the weekends to connect in to GWR?
Sending all the Salisbury line trains to Reading would be a good idea. The only problem might be platform availability for longer Exeter trains. I'd guess the shorter ones could use platform 3.
Nicholas Lewis
9 Aug 2019
there isn't have to be ticket working i guess
Bristol
Do SWR sign that route to Reading?
Yes. It was first done during the 2017 Waterloo remodelling, but there’s been a Sunday morning and afternoon service since, and some late evening route learners during the normal weekday timetable.
Whether enough drivers are in date would be another question though.
moley
12 Jun 2011
Basingstoke stoppers are gone completely.
Southampton/Pompey via Winchester loose Fleet, Hook and Winchfield but retain Farnborough.
Weymouths look to remain on the Main as Pompey line said to be running normal service tomorrow.
So looks like an attempt at 4tph in each direction.
I don't know the area well, but I have a vague recollection that many years ago I was on a service disrupted by planned works which left Woking platform 2, and went wrong line down the up fast all the way to Basingstoke. I know its not signaled to do it but is it physically possible? or my memory playing tricks again!
TEW
16 May 2008
The route has been learnt by some Salisbury crews recently in addition to the Basingstoke crews who already sign it so it should be possible to crew a decent service to Reading, especially with the Basingstoke stoppers cancelled.
Omnishambles
13 Jul 2019
…the whole timetable is really quite dependent on the local TME (No pressure!) allowing the DFL reopening with an ESR in the morning. More than sure I will find out when my other half wakes me up at 530 to help her navigate her journey to work !! For me, being totally selfish, I’m fine until later this week
moley
12 Jun 2011
The pictures seem to show a fair bit of the ballast missing from under the DFL. There is also the possibility of more rain...
Nicholas Lewis
9 Aug 2019
this is a screen capture from video above shows reasonable support
should be good for a 5ESR if the rest of the embankment is stable. Once the stabilisations works are complete will obviously have to be shut to restore the US.
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
I can remember leaflets out at Taunton in the 1960s (!) about a "Hook Landslip", even more severe than today's and which I think went on for weeks. It had a grainy black & white photo of track suspended over the void which looked very like the current one, apart from having a Bulleid Pacific creeping past on the far side.
That picture featured in 'British Railway Track', the handbook produced by the Permanent Way Institution.
Pat
mrmartin
17 Dec 2012
In this case seems slightly OTT for SWR to avoid against all but essenital travel tomorrow for eg Basingstoke to Waterloo given only a handful of trains are cancelled (looks like 4tph to me?), unless NRE is not up to date right now?
Omnishambles
13 Jul 2019
I would advise same as can’t see DFL open tomorrow to be fair.
NRE won’t be up to date as Control staff are busy rewriting timetable currently which will upload in its entirety in the early hours as well as VSTP (very short term) changes thereafter.
Class 170101
1 Mar 2014
Could services not run SLW over the Up Fast From Woking Platform 2 to just approaching Basingstoke (5105 Shunt signal?) the points all seem to face the right way so no double reversal moves needed. Up Services to us Up Slow all the way?
