xc hst to brighton
hello
10 Jun 2008
is there any truth in the rumour i heard that axc are planning on having the first ever hst work into brighton, for the last ever xc service out of brighton in december??
David
9 Jul 2005
Scunthorpe
I didn't think that HSTs were passed for the route to Brighton. IIRC they don't have short swing-link bogies which means they can not travel along most of the 3rd rail network.
Some do, and are labelled as such... however I have heard that the labels are not always accurate as bogie swaps have taken place and the labels not changed. So I would imagine a full inspection would need to take place and probably some swapping about of vehicles to ensure the entire rake was short swing fitted.
xc170
9 Feb 2008
My dad drove the last HST out of Liverpool Lime street under Virgin XC
5872
28 Jan 2007
A6-EHF
Somone told me that FGW had most if not all swing bogie sets, why not use one of those sets?, be immensly hellfire to have valentas on one of those sets again.
5872
28 Jan 2007
A6-EHF
Because FGW are going to lend a set for what reason exactly?
It was only an idea, I would have thought XC would do Bournemouth, Bit easyer seeing as its Reading - Basingstoke - Winchester - Southampton - Brockenhurst and Bournemouth <D... But we will probably only get Voyagers sadly :(
thefab444
27 Oct 2006
The New Forest
Yes? Brighton is Kensington Olympia > East Croydon > Gatwick Airport > Haywards Heath > Brighton... or Guildford/Redhill instead of Kensington and East Croydon.
I doubt HSTs will work down to Bournemouth, despite the obvious frothing value.
Turbostar
15 Aug 2006
Plymouth, Devon
IIRC, I think HSTs did run briefly at the start to Bournemouth & Poole when Virgin won the XC franchise many moons ago, but soon went over to 47 haulage.
hello
10 Jun 2008
apparently they are going to do it as it was the last ever crosscountry service out of brighton, but the first ever hst to work into/out of brighton, would be hellfire
Julian G
9 Jun 2005
I heard there was some gossips through the net about a HST going that way before
A loco-hauled train would be more appropiate as that what INTERCITY, Virgin XC has been using on the Brighton runs
class 313
10 Dec 2005
St Albans
All seems like froth to me.
I mean, by the time it happens (if it does) It will probably be an MTU set. (Good I hear some of you say!)
But yes, LHCS would be a better choice.
Jim
11 Jun 2005
Wick
You mean SHORT swing link? I belive FGW do have most, but they are dotted all around, and I belive as already mentioned XC only have LSL.
thefab444
27 Oct 2006
The New Forest
HSTs worked to Bournemouth regularily prior to 2003/2004. They are definately cleared. There was also a run with the NMT last year.
The problem is they need to use Short Swing Link sets to, in theory, protect the passengers from being fried. I think the problem with the normal sets is that there is a danger the bogie will come into contact with the 3rd Rail. Same reason why 14x units are banned from SR 3rd, although that is because they bounce too much. Interestingly, they are not banned from Mersey 3rd which IIRC has a lower voltage.
thefab444
27 Oct 2006
The New Forest
Someone more technically minded will probably explain it, but I presume the SSL bogies are shorter - and as such don't swing out so much.
Jord
21 Jun 2007
Aberdeenshire
I'm sure I saw a picture somewhere of a Virgin Red HST on the Aberdeen - Bournemouth or Bournemouth - Aberdeen run, would this be true?
Yes it is true. I travelled to Bournemouth in October 2002 and got a HST, although that must have been one of the last times a HST did it as it was just after 'Operation Plastic' and I am sure there would not have been any IC livery still around then!
