155341/155347 working in Leeds
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
Are 155341/155347 specially designated units or in some way different to the other Class 155s?
I only ask because, while I know the trains are predominantly found on local services out of Hull, the York service in particular, almost every day for the past two weeks I have noticed one of these two on Knottingley services (RTT)? But that’s not a one off - this was the case when I looked up the 155s back when Northern units first came onto RTT, a 155 would often stray onto Leeds Knottingley but would always be one of these two.
And then when I went to Leeds in January and June of 2020, it was exactly the same. I found 155347 on Knottingley turns both times, with 341 the first time.
Why is it always these two? Are they stabled at Neville Hill whereas the others stable at Hull? Or is it just pure coincidence? Thanks
Neptune
29 May 2018
100% pure coincidence. 155’s these days are diagrammed on Hull based workings but as they are based at Neville Hill there is nearly always one on the depot as a maintenance spare. If it is required to cover for anything it will generally replace a 158 on the Knottingley runs as it is local to Leeds (in and out every 90 minutes) and all Leeds crews sign them. If they were kicked out on a Sheffield for instance then it could cause problems as Sheffield crews don’t sign them.
Again it is pure coincidence that you see 341 & 347 regularly. In my 20+ years as a guard at Leeds I found some units always seemed to follow me around whereas other units I seemed to rarely work (144004 was a particular stalker as was 333010).
