1995 stock additional trainsets?
southern442
20 May 2013
I remember reading about additional 1995 stock trains being ordered for the Northern Line extension, but I cannot find any recent discussion of this, now that the time of opening is (hopefully) drawing nearer. Are these still yet to be built? Have they already been built and are in service but nobody makes a big deal of it because they are identical to the older trains?
rebmcr
15 Nov 2011
St Neots
The project was cancelled even before the pandemic, due to lack of funds.
By the end, it was clear that any version that would have gone ahead would consist of new build (and possibly cascades), as the value-for-money of matching the older design, with vehicles slated for early retirement, would not make sense anyway.
southern442
20 May 2013
That makes sense. I suppose that timetables will be reduced on for a while now anyways so there won't be much need for them for the foreseeable future.
Mojo
7 Aug 2005
Not at all - all LU lines have been pretty much running on to their normal schedules except for Night Tube but with an early start up on Sunday mornings for several months now.
rebmcr
15 Nov 2011
St Neots
It's more that timetables can't be increased to the lines' theoretical maximum, until full fleet replacement probably starting in the 2040s.
Lewlew
15 Oct 2019
I believe the current idea (certainly not confirmed or funded yet) is to buy new trains for the Jubilee line and move the 96 stock (or some of) to the Northern line to supplement the 95s.
rebmcr
15 Nov 2011
St Neots
That was one of the pre-cancellation possibilities (rather than new-build '95 Tube Stock) but '96 Tube Stock isn't a similar design underfloor, so even that would have been less than straightforward.
Mikey C
11 Feb 2013
Yes, with the existing stock at half life, any similar new stock would have a very short life.
A bit of an issue for the Northern Line though. If the big plan to cope with future growth is to split the line once the Camden Town rebuild is done to enable increased frequencies, this needs additional stock. It's not as if they can stop more trains short to increase the frequency in central London, as masses of new flats are being built on the outer edges (e.g. at Colindale)
If the lines are eventually split and the existing stock is not due for total scrapping it seems likely that a new fleet would be ordered for one of the new lines and the other would soldier on with the existing stock
hwl
5 Feb 2012
The cancellation was one of DfT's review items scoped in the report that hasn't been published. My reading of it is they probably though other things should have been deferred to make the timing work for ordering more stock there.
Elshad
23 Oct 2018
Perhaps some of the COVID-related changes in work habits (e.g. remote working, less commuting) will become more or less permanent and mean the line will be able to cope with the existing 95 Stock for a few more decades until it's time for the whole fleet to be replaced.
D365
29 Jun 2012
As ever it’s not something that can be accurately predicted at this point.
LU_timetabler
5 Feb 2017
If the funding for new Jubilee Line fleet is approved, then the old Jub fleet goes to the Northern, ideally to one of the 2 split lines. The spare trains - whether that be rest of old Jub fleet or replaced Northern fleet then goto Bakerloo - saving the need to replace Bakerloo stock with new trains, which is best done when the line is extended and upgraded, which we know is definitely paused.
Nym
2 Mar 2007
Somewhere, not in London
And how, pray tell, do you want to fit the 1996TS on the Bakerloo Line?
philthetube
5 Jan 2016
Unless you know this is not possible, you may or may not be correct is saying that 96 stock may fit, 95 stock is the same size and replaced 72's on the northern, admittedly with a bet of tunnel widening on one or two bends so it may not need a lot of work to make them fit, I do admit that I do not know if it is possible to make them fit though.
