Why can't they use UDS at the other stations, then? Is it because they hang over junctions if they actually call, but it's OK to run through? I genuinely did think those ones went up the mainline, but you're correct that they don't.
UDS has to be authorised for each station.
At Alsager I've not really sure why it can't happen to be honest as EMT stop meridians with sdo and they block the crossing so not totally sure on that.
Kidsgrove on the up (towards London) the problem there is with the stopping point so far back due to the signal the front cab of the rear unit where the UDS is operated from is actually not in the platform and so it can't be safely operated.
On the down at Kidsgrove the back.set blocks the mainline so isnt used.
At Stone on the up has the same problem as Kidsgrove where the set blocks the junction but even worse as it would foul the I up and down line towards Hixon. On the stoke bound platform at Stone it was originally due to a foot crossing situated right behind the platform and the fear that people would walk behind a stopped train and get hit by an xc running through. The foot crossing is now removed so shouldn't be an issue now altho there is also a neutral section and I think that if an 8 car did stop and it had the pantograph ib coach 7 it could well be in the neutral section which has obvious consequences.
There are Loads of stations where UDS isn't authorised it'd Just most aren't a problem as never see any 8 cars.
