Arriva Midlands
Trainman40083
29 Jan 2024
Derby
Yeah, looks like they might be going into consecutive fleet numbers since there's quite a big gap between that and the current numbers
I wonder if they will track correctly as quickly as they got renumbered too ;)
Well, 3709 was out and about this morning. Even left the bus station and went down the Morledge. On what is another matter
Actually I suspect given when it left, it worked the 11.35 X38 that should have left Derby Bus Station
8 Mar 2018
Suspect so as one of the X38 buses is tracking as the spare ticket machine.
Russel
30 Jun 2022
Whittington
It may have already been covered, but why is Derby gaining Pulsars from Liverpool, is it to see off the Scanias?
Trainman40083
29 Jan 2024
Derby
There was a suggestion that Derby drivers wanted the Scanias gone, so they are getting an Arriva style upgrade.
zkyx02
26 Nov 2024
Derby, Derbyshire
No, this wasn’t the case.
Many drivers prefer the Scanias, most mersey transfers are arriving with defects, 3708 is just extremely slow & 3709s reversing ‘gear’ doesn’t work correctly, but hey atleast it’ll keep the engineers busy!
aswilliamsuk
10 Jul 2016
3006 onwards are still in use and expected to move to Arriva North East, this in turn is said to see some Stockton Streetlites move to Laird Street. Wythenshawe final month is now, the probable thing to leave play out before anything else changes.
There's a combination of various things going on at North East - believe a batch of VDL/Wright head north east, as well as 10 new Volvo B8RLE/MCV, which will release a batch of StreetLites to Merseyside and replace the very much non-standard Temsa Avenues. Either way, that's likely to require more than 20 VDLs.
Trainman40083
29 Jan 2024
Derby
Those Temsa Avenues seemed to just keep running. Were they worth buying? I.e value for money?
Trainman40083
29 Jan 2024
Derby
I presume the fire earlier in the year also had some affect on the decision as well.
Ah yes, the fire under the closed multi storey car park. Seems to recall there was another, less serious one in the bus station.
busspotter1
23 Jul 2024
NOTTINGHAM
Ah I was driving behind 3708 today and wondered why it was so slow, I thought it was a new driver being cautious.
K219UHA
5 Jan 2018
Had quite a few visits the last six years or so to sample them, photograph etc, very solid buses and reliable and the better ones climb hills on the X4 and X93/X94 better than any of the more common types. I found this year they are starting to suffer from lack of work been done to them to keep them good, one kept having a fault with overheating, kept getting sent out and playing up, rather than resolve the issue let it play up and swap it, saw three times, twice when aboard. I understand some parts are no longer available from Temsa and been non standard are the reasons cited to replace, that's fair enough. I heard locally suggestions they had looked to get another 2 or 3 years more out of them when under DB.
As for the Pulsars, I rate Pulsars highly but the ex Stockton ones at Redcar are some of the poorest examples sampled sadly, run down, lack of refurbishment and sorting the basics on them, but some have improved on later visits.
I'd say the Temsas are as solid and lasted well in comparison to the large batch of 09 plate Versas still with Midlands.
zkyx02
26 Nov 2024
Derby, Derbyshire
Unfortunately not, was talking to a friend of mine & he said it’s one of the slowest… isn’t a shock considering it’s from Merseyside.
Can on
Pretty much the same as Derbys ex Merseyside examples, pretty sure most have had the same seats since new, atleast our Scanias had a refurb around 5/6 years ago.
Snex
20 Jun 2018
It's supposedly 30 not 20 coming to the North East according to this - https://www.northeastbuses.co.uk/showthread.php?tid=4575&pid=314574#pid314574
3x Solo's (4 needed though) - Ashington
2x Enviro 300's - Darlington
1x Centro - Redcar
23x Temsa - Redcar
10x Streetlite - Stockton
That's what is supposedly going out and it all adds up.
