Sounds rather like the 769 "first class" then. What have they done with the flooring in it - is it still carpeted or have they stuck the Lino in there?
Did they always have those tiny tables?Here is the First Class in 165109 as of this morning.(also the light switches in the seat work finally)
View attachment 122602View attachment 122601
They used to have those in all the seating bays in standard class as well, not just in first class. The 166s were also built with them in standard class, although replaced by the triangular tables in the first year or so.Did they always have those tiny tables?
They're there to rest your packet of Tic Tacs onDid they always have those tiny tables?
They just vibrate off onto the floor.They're there to rest your packet of Tic Tacs on
The triangular tables are a lot more robust.They used to have those in all the seating bays in standard class as well, not just in first class. The 166s were also built with them in standard class, although replaced by the triangular tables in the first year or so.
100%. This unit in particular was the first Turbo I have seen in many, many years to have all its tiny tables still intact! (for now)The triangular tables are a lot more robust.
Still did when I went on one of the FGW liveried ones on Tuesday, and yes the refurbished ones are keeping them I believe; I'm yet to travel on one that has been done but this photo from a contractor suggests they do.The 166s actually [used to] have full-sized tables in First I think. Are those being kept?
Indeed it is and it's in an interesting state. I've noted the following so far:166205 is the preview unit.
That's the prototype 166.Still did when I went on one of the FGW liveried ones on Tuesday, and yes the refurbished ones are keeping them I believe; I'm yet to travel on one that has been done but this photo from a contractor suggests they do.
166s had first class at both ends, while 165s had it at one end with 3+2 at the other like in the rest of the train.Unless they changed it, when I’ve been on it the original refurbished 166 it had grey leather seats where First Class was with green headrests similar to what was in the HSTs
In 2015, the first class end was declassified on 165s, making them standard class only trains, and one of the two first class ends was declassified on 166s. This was why the prototype 166205 received green moquette at the end that was declassified (seen above), and leather at the end that remained first class to match the HSTs.
When 166s moved to Bristol in 2018, first class was declassified at both ends. To make up for the loss of the 166s which had retained first class, first class on 3-165s was brought back into use as they took over from 166s on Bedwyns, Gatwick fasts and some Cotswold services.
At this point, 2 car 165s remained declassified as they were predominantly used on branch lines, but then as they began to join the 166s in the West, the first class seating was removed from these and 3+2 seating installed. At the same time, large luggage racks were installed at the opposite end.
Now, we have 2 car 165s with entirely 3+2 seating, 3 car 165s with one end of first class which is in use on Gatwick fast services (maybe Basingstoke too but I don't know) and declassified on Redhill stoppers, Henley, the rest of LTV and the west, and 166s with declassified first class at both ends.
The guard on my NDL service the other day informed me that it was declassified on Redhill services, but it may have been misinformation. It definitely was like that a few years ago though, and there was a conscious effort to keep Gatwick fasts as 100% 166 operated around about 2016/2017.The only Thames Valley turbo route with First Class is North Downs, and that’s all services not just Gatwick trains.
Thanks for clearing that up.He was misled, First Class is on all North Downs services as per the timetable on GWR’s website. Although in reality often isn’t enforced.
Check Train Times and Timetables | Great Western Railway
Check train times for routes across the South West and GWR network. Find current timetables or create your own personal timetable online.www.gwr.com
When the reduction of First Class started in the Thames Valley, the Redhill stoppers did become Standard Class only. I'm not sure when that changed back, quite recently possibly?He was misled, First Class is on all North Downs services as per the timetable on GWR’s website. Although in reality often isn’t enforced.
Ahh, I see, sorry about that. I thought it wasn't the demo as it wasn't leather, as I didn't realise the other first-class end has fabric instead.166s had first class at both ends, while 165s had it at one end with 3+2 at the other like in the rest of the train.
In 2015, the first class end was declassified on 165s, making them standard class only trains, and one of the two first class ends was declassified on 166s. This was why the prototype 166205 received green moquette at the end that was declassified (seen above), and cream and emerald leather at the end that remained first class, to create a more consistent first class product alongside the HSTs.
When 166s moved to Bristol in 2018, first class was declassified at both ends. To make up for the loss of the 166s which had retained first class, first class on 3-165s was brought back into use as they took over from 166s on Bedwyns, Gatwick fasts and some Cotswold services. At this point, 2 car 165s remained declassified as they were predominantly used on branch lines.
As the 2 car 165s began to join the 166s in the West a little later, the first class seating was removed from these and 3+2 seating installed in its place. At the same time, large luggage racks were installed at the opposite end.
The 166s in blue with pink doors still have an enormous "1" and a yellow stripe adorning one end of the train, despite both first class ends having been declassified for about three years at a minimum.
A shame, as carpet also gave a certain sound deadening property to it as well as a slightly more luxury feel.Lino
This confused me further up the thread, as I had the impression that the preview unit had the fabric seats at both ends and that I had travelled on a different unit with leather seats.Ahh, I see, sorry about that. I thought it wasn't the demo as it wasn't leather, as I didn't realise the other first-class end has fabric instead.
Definitely wear and tear as the original handrails were a much smaller upside down L shaped affair, with the shape visible by the blanking circles above the bin. These were only fitted fairly recently (when the new PRM compliant loo was fitted) as the refurb kept the original ones. Sadly I'm not surprised either way, everything about them internally is looking tired and worn out - the tables are a similar shabby affair, often sticky, scratched and with a similar varying paint fade. But it's fine... they've got new Green Carpets!Just been on a green (repainted) 166 212, thought I would take a picture of interesting quad colour (pink, cream, brown, silver) grab poles by entrance doors.
I guess this is just wear and tear, and makes you wonder why the refresh was delayed so they can get in this condition
The ridiculous saga of first class on the NDL route makes it unsurprising that even the staff don't know what the latest situation is! On top of that the appallingly lax application of adequate first class labelling, interior and exterior, for many years has led to a complete mess.Thanks for clearing that up.
"Intact" maybe, but firmly fixed? Refurbished units I have been on lately have had rapidly-loosening tablettes yet again. It seems to be beyond the wit of modern engineers to fix a small table securely enough to withstand being sat on by kids, etc.100%. This unit in particular was the first Turbo I have seen in many, many years to have all its tiny tables still intact! (for now)
It is my understanding that only one refurbished 165 with the first class bit is in service at the moment?"Intact" maybe, but firmly fixed? Refurbished units I have been on lately have had rapidly-loosening tablettes yet again. It seems to be beyond the wit of modern engineers to fix a small table securely enough to withstand being sat on by kids, etc.
The second set (104) returned to Reading just over 2 weeks ago but unsure if it is back in service yet.It is my understanding that only one refurbished 165 with the first class bit is in service at the moment?
