Autumn refresh for GWR Class 165/166 Turbos
Of note, that area in the first photo is the former First Class area. I’ve never understood why they chose to re-seat this end with 3+2 seating, and place the large luggage rack in the other end (the former 3+2 seated area with 3 windows).
Doesn't it better equalise passenger capacity in the two vehicles - eg one gets the toilet and the other gets the racks?
It does admittedly result in a pair of seats without a window which is a bit unfortunate.
HamworthyGoods
15 Jan 2019
Allocated to a depot only means that depot holds overarching maintenance and “ownership” of that unit.
It doesn’t forbid it being outstationed at Reading for say, 2 weeks at a time and just rotating through SPM for major work every couple of weeks or so.
Not impossible that all the two cars could be officially allocated to SPM but rotate to cover the Thames Valley work.
Indeed that is exactly what is going happen and if you look at the timetable for after Dec 21 you will see there are some swap over opportunities to cycle the units back to their ‘home’ depot for heavy maintenance as appropriate.
At Worcester in the morning the arrival from Oxford then goes to Gloucester and vv
cactustwirly
10 Apr 2013
To me it doesn't really make sense.
Reading has maintained these since they were new and have the experience, which SPM doesn't have. Look at the state of 166s since they transferred west, they've gone downhill massively since they were Reading based.
Plus it seems like a massive waste of fuel transferring 165s to and from Bristol. I'm struggling to see the advantage here.
How is it a waste of fuel if the exchange of units is at Worcester with the units operating in service to that point?
2G79 0604 Gloucester to Worcester Foregate Street works 2E80 0652 Worcester Foregate Street to Didcot Parkway
2E77 0510 Oxford to Worcester Shrub Hill works 2O72 0707 Worcester Shrub Hill to Weymouth
There isn't an empty stock working from, for instance, St Philips Marsh to Didcot Parkway.
HamworthyGoods
15 Jan 2019
How is it a waste of fuel when it’s been explained the changeover take places at Worcester.
The advantage is so there is capacity within Reading Depot to maintain the class 769s which will be working on Thames Valley services - how else do you propose these are maintained bearing in mind they are longer and take up more shed space than the turbos they replace…. The front line railway doesn’t do things for the sake of it!
RE 166s, when they were at Reading most units either got back to Reading each night or stabled at Oxford. At Bristol the 166s have a tough life with over half the fleet outstabled every night at places such as Fratton, Weymouth, Westbury and Gloucester. A fleet with returns more often to its Home Depot will be by its nature more reliable.
The rebuilt Exeter depot will take over some of the works on 158s from SPM which will alleviate pressure there.
REVUpminster
3 Jan 2021
Paignton
Exeter has been built to service three coach trains (and two) with it's lifting road although the bogies look like they will be delivered by road. It also seems to favours modular replacement and not repair.Exeter Depot bogie store.PNG
Dan15812
18 Oct 2018
SW
I would expect the only difference and the reason for starting on the 165 is they don't have carpets.
Although some 166's had the GWR carpet retrofitted, so I wonder if it will all be replaced from fresh.
Also I wonder what will happen to 166205 as its green interior is already starting to age so will become out of line with the other newly refurbed turbos.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
You’d expect them to redo 205 as well, but they refused to re-livery the all blue 166s as they’d been done more recently, so will probably refuse to redo 205 for the same reason
cactustwirly
10 Apr 2013
Depends on how extensive the 166 refurbishment is. If it's new seat coverings and floors. I'd expect 205 won't be touched
Dan15812
18 Oct 2018
SW
205 was done in 2015 IIRC as part of some trial to showcase the GWR brand. Part of the reason why GWR didn’t continue with the trial was because the interior wasn’t wearing well. So it would be strange for it not to get touched.
The original cloth seat coverings were replaced by moquette ones though so to that extent they don't need to be changed as part of the current work. Clearly if the first class area were to be removed as part of this work, it will need to be included.
43102EMR
28 Mar 2021
I hope it isn’t removed as it’s the closest the Turbos will get to a 2+2 interior layout at the moment - saying that though, half the time it’s sealed off due to Covid and will likely get removed in line with the rest of the WOE fleet.
cactustwirly
10 Apr 2013
Well 165122 is in service.
The interior looks very smart, a lot better than the old FGW one.
Basically everything is the same, except there is new flooring and seat covers. Plus the interior has been repainted.
fgwrich
15 Apr 2009
Hampshire
Indeed, I happen to have It on a Padd - Oxford the other night. Not really much to write home about in my opinion, it is just a Turbo in GWR colours. Though Wolverton could have cleaned the ceiling before they returned it (Walls and seat frames repainted) and covers replaced.
43096
23 Nov 2015
If it’s not in the spec it doesn’t get done. If GWR wanted the ceiling cleaning, they should have included it in the scope!
cactustwirly
10 Apr 2013
According to RTT 165123 is out on Oxford services today. 165122 worked empty to Reading this morning from Oxford so not out today.
FLIRTfan18
11 Mar 2020
Wolverhampton
I was on 165122 today. Very nice and tidy. In my view the best job they could possibly have done whilst keeping the seating layout as it is. I always detested the First pink and blue colour scheme.
warwickshire
6 Feb 2020
leamingtonspa
FGW_DID
23 Jun 2011
81E
Recessio
4 Aug 2019
That interior looks very snazzy, looking forward to seeing these on the North Downs line!
Sole complaint is the grab handles dont contrast very well, but that might just be the lighting in the photo.
DelW
15 Jan 2015
I don't mind the blue, but I agree the lurid pink grab handles and poles are pretty hard on the eyes.
Which will be seen in service on the North Downs first, a 'refreshed' Turbo or a 769?
30 Jul 2015
Perhaps it depends whether you count Wokingham as the North Downs?
I am sure that 165122 or 165123 have already worked the booked 2-car diagram 1O55/1V39, but they have not done so within the last week.
387star
These painted (?) tables haven't lasted well at all whereas class 377 tables still look new !
