Blackpool - Manchester Electrification
LDECRexile
30 Jan 2014
Southport, UK
For each concrete base that is poured, is concrete additionally poured into 5 tiny moulds for compressive testing purposes?
Is every one tested on every pour?
I don't know the answer to your question, but to give an idea of scale, the testing cubes, from my layman's impression and memory, had sides of about 6 to 8 inches.
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Every batch of concrete would be my guess but not necessarily every pour. Industry standard is 2 inch cubes in the USA and 50 mm cubes everywhere else - the molds should be brass. In addition as Dave points out sometimes larger samples are also poured if for example the engineer wants slant-shear bond strength tested also.
For intrinsic concrete strengths for published results etc then 150 mm cubes are used. As was pointed out this minimizes the effect of large aggregates.
John Boy
23 Jan 2016
Pictures of the masts at P2 Salford Crescent, Yippee indeed!!
John Boy
23 Jan 2016
Forgot to mention, Bolts and some steel work in the glazed brickwork retaining wall on P1 at Bolton
reg
15 Mar 2015
Bolton
Bolton-more masts up in the Newport St area and some wall mounted brackets (with danglies) in the Bullfield area.Pics later
LDECRexile
30 Jan 2014
Southport, UK
Yo! This knocks off my point "The location of the base and mast-to-be somewhere near the same bridge over Platform 1 track remains a puzzle." in Post #7522 and earlier. Splendid.
GRALISTAIR
11 Apr 2012
Close study of your fine shots also shows an earth wire. In one bound SCP2 goes from zero to hero!
In fact if I were a betting man I would put money on the fact they could do a wiring run in the next 5 weeks, it would run from Ordsall Lane Jct to the Atherton line over run. That would make Salford Crescent effectively live unless there is going to be a neutral section in the vicinity.
LDECRexile
30 Jan 2014
Southport, UK
I've wanged John Boy's very welcome shots onto his album here:
https://www.flickr.com/photos/127646831@N03/albums/72157669031974018
and onto the Combined Volume here:
https://www.flickr.com/photos/127646831@N03/albums/72157661069863633
Thank you John Boy.
I confess to being green with envy, It will be Saturday at the earliest before I can get out and about, and maybe not then. Still, with the calibre of contributions we get from people like Reg, Wrinkley and John Boy, among others, we're keeping abreast of events.
LDECRexile
30 Jan 2014
Southport, UK
I hope you are right, but the missing biggy is the whopping gravity pad base whose rebar cage has been standing opposite Platform 1 for a while. Does anyone know if it has been poured?
GRALISTAIR
11 Apr 2012
Hmmm - so let’s say it gets shuttered and poured by this weekend that would make it mid July before mast and endanglied so wired by end of July more likely in that case.
LDECRexile
30 Jan 2014
Southport, UK
If any of our intrepid photographers goes to Salford Crescent in the near future could you please record progress or lack of with the immediately above and also go to the south end of the station, beyond the lift, and record what has been attached to what. For ages it has looked as if a short mast was being installed under the road bridge, the likes of which I've never seen before.
furnessvale
14 Jul 2015
2" cubes! What happened to the 6" cubes of my youth?
I am not doubting you for a second, but how does a 2" cube take account of the aggregate content of a single cube when using larger aggregate?
Chrisyd
16 May 2015
I am 99% certain I was sat opposite this, this morning, and it was poured! I was sat further back on the train than usual, so couldn't decide if this was genuinely new, or if I was just looking at it for the first time.
Addendum: Just been past again and certain it is in, unfortunately did not have chance to grab a photo!
GRALISTAIR
11 Apr 2012
The problem with 6 inch cubes is they are huge and require an absolutely huge cube compressor to crush them and cure them in a curing cabinet. Incidentally you also generate more heat from cure which in itself skews the results. That adds enormously to lab costs and machine costs. If you look again at
https://www.flickr.com/photos/127646831@N03/albums/72157669789788098 you will see they are 50mm cubes. You are absolutely correct if you have huge aggregates you will get discrepancies in a 2 inch/50mm cube so from time to time larger pours are done to keep yourself honest. Slant shear bond strengths are always done with larger pours.
To get published results for papers and research for intrinsic concrete strength 150 mm ( approx 6 inch cubes are indeed used)
Ploughman
15 Jan 2010
Near where the 3 ridings meet
Just as an aside on concrete cubes.
On the Drax branch near Selby, I think it was the old Camblesforth station.
The resident there did cube testing, well I think he did because of the amount of walls he has built out of left over cubes.
LDECRexile
30 Jan 2014
Southport, UK
Good News
I'm hearing from various sources that Lostock to Wigan electrification is ON.
Nowt in writing, but said by people with no reason to fib.
GRALISTAIR
11 Apr 2012
Good News
Outstanding and total common sense. It is a quick win for politicians too imho. Btw it should, again in my opinion, have its own thread. I nominate you Dave to start it. If you prefer not to, I will.
LDECRexile
30 Jan 2014
Southport, UK
Nice story; was the station at Camblesthorpe called Carlton Towers, of have I got my wires (lines) crossed?
Silverdale
14 Apr 2018
My recollection is that cubes were 150mm and that a set of three was prepared from each batch of fresh concrete. It would be quite difficult to fill and tamp a cube as small as 50mm with fresh concrete and obtain a representative sample given the size of aggregate in most mixes.
When we took samples of cured concrete, it was usually by means of coring and in that case the samples were of smaller dimensions.
Edit: The photos linked to in #7550 seem to show the standard 150mm cubes.
Excellent article, thanks for posting. Mr Grayling should take note. Although I doubt he will... :(
The beacon of hope is Scotland. The article demonstrates that things are still going largely right there, with nothing much different from England except that one goverment has a sensible rolling programme and a small but technically competent team to act as an informed client. The other, er, doesn't.
