Brighton - Banbury 4-6 June cheapest fare?
gray1404
3 Mar 2014
Merseyside
Can anyone recommend any splits or advances for a cheap Brighton to Banbury return. Outward on evening 4 June returning evening 6 June. 26-30 railcard held.
Trying to undercut the £33.30 Super Off Peak Return fare.
Thanks so much guys.
Nunners
19 Oct 2018
I don't think it's possible do without advances.
For the Sunday, Chiltern hasn't released advances yet and I don't think Southern is doing any as there's engineering works around Victoria so everything's diverted to London Bridge.
I've done a search for a one-way journey on the 4th June and have come up with:
Hove (I assume that would be ok?) to Victoria advance single £3.30 (most direct trains have this available). Oyster to Marylebone £2.40. Marylebone to Banbury Advance £4.20 (21:43 Marylebone to High Wycombe 22:30, 22:34 High Wycombe to Banbury 23:11).
This comes to £9.90.
For the way back, I would buy an advance from Banbury to Marylebone when they are release (don't know when).
I would do Oyster across London (£2.40) and then buy a London Thameslink to Brighton Super Off-Peak Single for £8.60.
As long as you can do Banbury to London for under £12.40 you're saving money.
I hope this helps.
If it wasn't for those Southern engineering works it would be at least £5 cheaper!
Wolfie
17 Aug 2010
I hope this helps.
Could, if you have a Railcard that you could get added to your Oyster and are travelling off-peak, get the cross-London fare down a bit....
gray1404
3 Mar 2014
Merseyside
Decided to opt for the Super Off Peak Return. Gives the flexability all round. Thanks so much.
Wolfie
17 Aug 2010
If the cost is competitive and it potentially offers more protection that seems a no-brainer.
W
What have you found so far?
Have you tried Trainsplit?
gray1404
3 Mar 2014
Merseyside
W
Trainsplit offered the Super Off Peak Return so I ended up booking this. On a non engineering works weekend I reckon it would have been possible to save about £10 with Brighton to London Zone 1 and London Marylebone to Banbury Advances.
