Well, last Friday night I was on the highlander bound for Inverness and in the coach next to the club car (coach J)
As already mentioned, the car next to the club car is the accessible carriage and as such has an accessible toilet at each end.
they were both working perfectly well for the whole journey. We had a lovely Inverness crew who were pleasant throughout.
Could the problem be the op attitude? If I have ever had a problem, I have always found an attendant/host and made them aware and asked for advice. 90% of the time they will bend over backwards to help.
I’m not saying the staff were correct in their handling of the situation at all, but to suddenly come across a passenger from another part of the train must raise all kinds of red flags.
i didn’t see any dialog mentioned in the posts above so could be wrong but wouldn’t an “excuse me, I wonder if you could help…….” be better than thinking “I’m automatically entitled to…….” Especially when you are perfectly aware you would be passing through the club car where the hosts are.
I can imagine that at the end of a long work day/night staff will be a bit near the end of patience. My assumption is either the staff member had started the night before from Euston or will have started in the far North and be in the later stages of returning there.
If the OP was way past the staff member then the staff member is going to have to shout loud enough to attract the attention of the OP as they walk further away with the back turned - so no visual clues to attract attention possible. I can imagine a sense of urgency.
As for the OP going the wrong way - like any train it is a 50:50 decision which way to start looking *. If I am starting at one end I know 100% which way I am going of course. If I judge I am no where near the centre of the train I am going to head away from the nearest end. If the first carriage I enter has no toilet (working or existing) I am not going to turn around and go back through my original coach unless I have reached the end of the train.
* = a danger here is to conclude that the simplest solution is to use the sink.... Won't get shouted at that way. CS ought to bear that risk in mind.
Sorry, but I think I know now what I was doing wrong.
The way I feel treated here reminds me of how I was treated aboard the train.
I had to explain the same incidence 3 times here.
And my lesson is - ..
This kind of hyper-sensitivity by rail staff is simply questionable in my eyes. This is my opinion. A sleeping car passenger dared to walk through the dining car during breakfast time.
In the UK it is apparently common sense that a passenger from a more premium cabin - standing between Car 3 and Car 4 right in front of a free toilet and a closed glass door - is being yelled away - and instead should have deduced himself to walk instead to Car 1 to the toilets.
Yes, train attendants in the US or Russia can behave in a very rough way. But with a 90% probability they would have allowed me to use the free toilet.
Not so on Caledonian Sleeper - no, the are insisting on policy, regardless of the fact that the toilets in the own Car 2 have not been working.
Why am I complaining to Scottish Rail Holdings ? Well, I want this policy changed.
Danger of being sensitive I am afraid.
Chances are you got hit with a Glaswegian accent - maybe ?.
Seems likely the seated coach toilet is kept exclusively for seated passengers for the reasons stated up thread - they are allowed no other choice and it follows that the toilet in their coach should not be overused by others. For both sets of passengers there is a need to avoid people moving round the train overnight disturbing each other.
How the above is handled is always going to be down to the people on the front line. The people higher up in the ivory tower need to understand that the reliability of toilets is perhaps not good enough. Good luck getting a message across to those higher up but that is what needs to happen.
I will mention the level of information elsewhere in this reply.
How it was handled sounds pretty poor - no one should ever be barked at - that does seem worthy of a complaint.
On the point of principle - in the sleeping cars there are two toilets for normally 10 people, several of whom have an en suite.
In the seated car, there is one toilet for 30 odd people, none of whom have an en suite.
Whilst there is a connecting door between seated and lounge, from the launch of the Mk5 - CS have effectively tried to describe that as a wall, more to emphasise Seated passengers cannot use the lounge, and by extension vice versa. There are additional sensitivities to people trying to sleep, and I suspect for example if the staff were to see “messing about” in the corridors of the sleeping cars, they might be similarly direct.
Therefore I can follow the logic of suggesting someone uses the toilet closest to their berth / seat, even though the tone is obviously indefensible.
Personally having seen the complaints process in a big corporate once or twice, I doubt this would go very much further than someone in a call centre on minimum wage sending you a copy and paste sorry you were poorly treated, we will look into this, maybe here’s a voucher.
In my experience specific complaints requesting specific responses almost never got that desired response, let alone a change in policy. Unfortunately that is the kind of generic customer service handling we have come to expect. “Sorry and Dismiss”. And actually that is a shame. Many of the complaints I read actually made valid points and could have made positive impact on the business, had anyone had the time or capacity or seniority to implement them.
I don’t doubt the level of frustration you feel about this, and you should obviously pursue the complaint as you see fit, but given the scale of the challenges facing CS / ScotRail / Scottish Rail Holdings / Transport Scotland / Scottish Government - with huge projects in the pipeline, service still not fully restored post Covid and ongoing staffing difficulties, doubts over the continued suitability of their main intercity fleet, the balance of electrification in the context of capital funding cuts, and mass fleet renewal, I suspect a complaint about toilet access policy on a Caledonian Sleeper service will be very much put in the category of “bigger fish to fry”, regardless of whether they see the merit of your complaint.
This post really sums it up.
Modern companies have plenty of complaints procedures but they only serve as box ticking processes. Fobbed em off, case closed.
In this case it really is a minor problem in the grand scheme of things. I agree with this.
BUT anyway :-
Could it be that the real problem is that the toilets are unreliable.....
Why do formations get disrupted - is this unavoidable and therefore a design/specification defect ?.
Perhaps the number of toilets it not good enough.
Also it seems that people from both sides of the divide can see information about toilets they cannot use - if so then that is bad design.
How about a clear sign or two.
"Sleeper passengers must not pass this point" - at/on the doorway to the seated coach.
"Seating passengers must stay in this coach" - dotted about in the seating coach.
How about making sure the door between the dining coach and the seated coach does not open except for staff ?.
