Id be interested to know the technical reason why the exhuast manifolds stick out as much as they do on these, and then drop down before bending back upwards towards the outlet/exhuast pipe...
I think it is because the bogies have inside frames, ie the frames are within the wheelsets, like on 220s. On older DMUs eg 158s the exhaust passes over the bogie, between it and the underside of the coach, where there is room available for it. So on these the only room is outside/above the wheels.
Be interesting to see the real thing close up but I'd expect the horizontal pipe is still within the bodyside limits, and the drop down before bending up will be to form a smooth curve for the gas flow, I think.
So now you might ask where does the exhaust go on a 220? Up through the carriage at the inner end of the bogie, and the inner end of the lobby. You can see where it comes out on the roof...
