starrymarkb
It is a ZF Automatic - most european units use a similar setup
Torque converter changing to fluid coupling? Same as on 15X's and 170's? Which would make it Diesel Hydraulic wouldn't it?
There is no gear changing, just the TC is drained and the flywheel filled. Happens anywhere from around 40mph (75mph types) to I think 70 on the Turbostars and 175s
The chiltern ones better not have the same rock hard seats as the LOROL ones?! as I live on the line where they will stop and if they have got those seats Im going to be using the greenford line to get into london! all there turbos will be refurbed by then so yay
I have driven a diesel-mechanical shunter, and it had from memory a clutch facility by hand to engage the gears..probably air-operated. Gear selection was mechanical.
So what is the difference between mechanical and hydraulic transmission?
Note the conventional clutch and gearbox used in a road vehicle has not proved reliable for railway work, except possibly at very low speeds. I've been told that with a road vehicle the rubber tyres provide damping to relieve the stresses,
I thought the plan was for the Greenford line to become a self contained Chiltern shuttle to Acton (or Ealing - apologies - can't remember), freeing up platform space at Paddington for FGW. This may have changed in the Cross Rail plans, of course
What livery?
Hmm sounds interesting. No gens or rail sites have posted news on 172 001 leaving Derby. Last I heard it had returned to Derby.
Could have been a test run, however that's what Old Dalby is for. This is really interesting. Did you not have a camera on you to take a picture.
Swear I just saw a 172 going on the down slow. Under its own power too.
First delivery from Derby?
5Z72
Derby Litchurch Lane - Willesden
The unit is apparently due out testing tomorrow too
5Z72
Nice !
LOROL 172s are due to do milage accumalation on the WCML slows to Bletchley and back. LM ones on Stourbridge to Whitlocks End/Stratford.
When do the LM ones start?
When they're built
