You would prefer it to be cancelled?Why they put this on the last train from Sheffield I don't know.
I appreciate it's far from ideal but if the choice was a train but no toilet or no train at all I know which I'd choose!
Leeds, presumably.You failed to mention the destination of the train. How far was it going?
Absolutely hate the term “bog.”
I mean at least it’s booked to have a loo, plenty of much longer journeys out of London don’tIt'll be an hour and a bit when it gets to Leeds. Too long for a no-facilities train.
Okay, so what alternative do you suggest; do you really think they’ve put it on deliberately? Clear more space in the crowded Northern units for another toilet?If people know a train is booked not to have toilets then they can more easily plan for that.
OP is wound up that the train ran when the toilet was out of service.Am I missing something? a 195 has a toilet, so why is it a problem there's not two toilets?
So do 350s. At times both are out of order presumably as the retention tanks haven't been emptied.You wouldn't normally have the issue on a 158. It has two loos.
(God, I never thought I’d be crossing to the railway's side )
I think the 2-car 170s that TPE had only had a big toilet, but it's been a while.Is the CAF Civity the only post-privatisation 2 car DMU built with only one toilet?
We're in the Speculative section, so here goes: how about removable tanks not too dissimilar to those used in motorhomes or touring caravans (known as "cassette toilets") though obviously larger? The pros would be that they could be easier to swap out at termini compared to running to and from a depot... the downsides would be that it wouldn't be a pleasant job, so the crews doing it wouldn't come cheap. They'd also be new staff because good luck getting unions to agree to existing staff taking this extra rather nasty work without a hefty premium. There's also issues with hygiene, smells, what you actually do with the contents from the tanks (does it just go into local sewers? Can the sewers cope?)... on balance I suspect it's a neat idea until you actually think about putting it into practice.The train running is better than a cancellation, but it should not be beyond the wit of the railway to keep the toilets sufficiently watered and emptied. A rapid refil/empty process for selected terminii perhaps.
They had/have two, all 170s have at least two.I think the 2-car 170s that TPE had only had a big toilet, but it's been a while.
Some 158s have only one. Those originally sponsored by WYPTE have only one.You wouldn't normally have the issue on a 158. It has two loos.
A spectacularly subjective statement which is very definitely route dependent.Yes, it's about time those were standardised with two loos.
That aside, the 158's are still very much the gold standard of DMU's.
They ought to really though.
Care to explain how you'd fit toilets into tube profile stock ? End to end journey times on both the Piccadilly and Central lines easily exceed 1 hour.
For long journeys they are fine. For anything shorter the door positions and size become a serious issue very fast. You only need a couple of people with cases to bring exit/boarding to a shuddering halt.Apart from the dodgy hand driers, they tick all the boxes, even for a long journey like Leeds - Carlisle.
But is the solution here not to make the loo actually work rather than limit space in the cabin by fitting an extra loo in case the other one breaks?You wouldn't normally have the issue on a 158. It has two loos.
