I think that was originally planned for December this year. Having all 5 units dedicated to the one route will make that possible, 4 in use and the other one spare, assuming staff are available.No sign of a more frequent service yet then?
Or maybe 009 coming back after being fixedA movement from Long Marston today which I assume would be 230010 and the last one
www.realtimetrains.co.uk/train/K28203/2021-02-26/detailed
A bit of a concern that it left Long Marston 39 minutes early and was 47 minutes late at Norton Junct. Am waiting to see a report at Worcester
What was the problem with 009 that required the mentioned attention?Or maybe 009 coming back after being fixed
No idea what the fault was, but it went back on the 19thWhat was the problem with 009 that required the mentioned attention?
Did anyone have visual of it and can say whether it was 009 or 010?
Did 009 only go as far as Wrexham or all the way to Birkenhead?
Thanks very muchThere was no movement shewn in RTT and nothing planned yet
Ok this is interesting. Ultimate plan is Wrexham to Liverpool four trains an hour.
Major upgrades on cards for train services on ‘Cinderella Route’ from Wrexham to Bidston
MAJOR upgrades have been outlined for train services on a line dubbed the “Cinderella Route” which links north east Wales to the Wirral.www.leaderlive.co.uk
Yep, but specifically mentioned Liverpool not Bidston
Hinting that the current 50mph line speed is too slow. Not got a lot of wriggle room with their "brand new trains" have they.Ok this is interesting. Ultimate plan is Wrexham to Liverpool four trains an hour.
One of them did the full length of the line using just batteries on a test run a few weeks ago.Has anyone seen anything about the range of the Class 230s running on batteries. They will have to run on batteries through the Mersey tunnels.
With an average of only 2.5 miles between stops, would anything above 60mph really make much difference? (Accepted some will have fewer stops.)Hinting that the current 50mph line speed is too slow. Not got a lot of wriggle room with their "brand new trains" have they.
If the Wrexham to Liverpool via Bidston plan is serious, I'm sure a method of third rail operation could be worked out for the D-TrainsHas anyone seen anything about the range of the Class 230s running on batteries. They will have to run on batteries through the Mersey tunnels.
The received wisdom at franchise award was that the 230s were a cheap stop-gap to show there was a case for faster/more frequent services, before buying proper (new) units that would be suitable for the Liverpool loop. (e.g. a bi-mode add-on order to Merseyrail's new fleet.)If the Wrexham to Liverpool via Bidston plan is serious, I'm sure a method of third rail operation could be worked out for the D-Trains
Absolutely agree, I'm just pointing out that it won't be a showstopper. Viva has experience with third rail; has been developing a third rail-based fast charging solution, and of course the 484s.The received wisdom at franchise award was that the 230s were a cheap stop-gap to show there was a case for faster/more frequent services, before buying proper (new) units that would be suitable for the Liverpool loop. (e.g. a bi-mode add-on order to Merseyrail's new fleet.)
I suppose a third-rail trial on the 230s might be something Vivarail would be interested in pursuing with TfW, but they're old enough that they'll need replacing in the medium-term anyway.
They would not be permitted to run through the Liverpool Loop line as they carry diesel fuel, regarded as an unacceptable fire risk. Any future running through to Liverpool will require new stock, most likely battery equipped Class 777.Has anyone seen anything about the range of the Class 230s running on batteries. They will have to run on batteries through the Mersey tunnels.
I assume the Network Rail 73s that do the measurement run every 4weeks from Derby are allowed to use the loop line as its done in the late night / early hours outside of service hours?They would not be permitted to run through the Liverpool Loop line as they carry diesel fuel, regarded as an unacceptable fire risk. Any future running through to Liverpool will require new stock, most likely battery equipped Class 777.
