Class 701 'Aventra' trains for South Western Railway: progress updates
Nogoohwell
14 Aug 2020
Two different units at the same platform, a 701 and a 458.
Got to say, im surprised when they extended platform 1, that they never realigned the track and extended the platform at the London end. Would have got rid of the huge gap between the train and the platform.
Its not as if there is not the space for the new alignment. The embankment is wide enough for at least 150 meters.
Cant see a platform like P1 at Raynes Park being built now
willontrains
29 Jan 2025
Epsom
701017 failed at Raynes park on 1D14 this morning after a passenger alarm was set off by accident; which broke the interlock.
NSEWonderer
5 Dec 2020
Wonder if it's the usual one in the toilets. They have started to modify the toilet ones by covering them up, last I knew.
willontrains
29 Jan 2025
Epsom
they weren't able to locate it, but did lock a door out of use, which didn't seem to solve the fault so it went out of service and empty to Wimbledon I believe.
Nimbus020
7 Mar 2025
SW London
re. the 458 that had door problems earlier this week, these look to have started earlier in its journey (5 mins stop @ Worcester Park etc.) - probably made sense to get it to Raynes Pk so people could de-train & then get on to other services (i.e. crushed on to 8-car Class 455s!)
NSEWonderer
5 Dec 2020
they weren't able to locate it, but did lock a door out of use, which didn't seem to solve the fault so it went out of service and ECSed to Wimbledon I believe.
That's a shame but yeah Aventras have always had some issues with passcoms messing up the trains. Used to plague heavily the Elizabeth Line 345s, bring the service to a complete hslt if it occurred in the COS, door issues were rampart and no surprise the same issues appear on the 701s which are yet to apply fixes and mods as the faults come.
They'll eventually become reliable enough but for that, there will be more pain faults wise before relief.
willontrains
29 Jan 2025
Epsom
I was on this 458, reason it was late was due to the route not being set on Motspur Park Jn. From what I was told by the guard the train had a Traction Interlock Fault at Raynes Park, as we were sat there for a few minutes closing and re-releasing the doors in an attempt to rectify the issue. This didn't happen and the train was deemed faulty at 07:47am.
Nimbus020
7 Mar 2025
SW London
Many thanks - makes sense
24 Nov 2017
I was on 1D14 this morning. It was evident from the prolonged stop and repeated door cycling that something was wrong so I transferred to the first train that came into platform 2, before 1D14 was cancelled. There were no announcements on 1D14 about any problem before I abandoned the train.
nctd2306
2 Jan 2024
Berkshire
Was looking forward to catching 1D14 this morning... first ride on a 701...
... only to look on RTT and find it's been subbed for a 455! Ah well!
The Surbiton peak service (2J92) doesn't run on Fridays so the 455s aren't needed on it, therefore they can operate the full 1D05 diagram from the start without the need for the 701 on that round trip.
norbitonflyer
24 Mar 2020
SW London
This seems a bit back to front. Surely if you don't need both the 455 and the 701, you should be using the newer better, longer one?
I note that there was no crew available for the Shepperton-via-Richmond diagram this morning, meaning overcrowding on the Kingston alternative (18 into 8 won't go) and consequent skip-stopping
nctd2306
2 Jan 2024
Berkshire
With the driver training still paused, there's only enough crew for the one round trip, hence why 2J92 went over to 701 in the first place as only one driver/guard was needed for that diagram. If you tried to keep the 701 on after 1D14, you'd probably end up with more cancellations than services that run (and that would be every single day).
At least by putting the 455s back in, the passengers will actually get a train to board.
swtrains
30 May 2024
Or put back what was originally there last week, 458/5 pair.
Peter Sarf
Croydon
The Transport Secretary has committed to getting the Class 701 introduction issues sorted before SWR comes into public ownership at the end of May after questioned by Paul Kohler, MP for Wimbledon
She actually says "it is important that the issues are resolved before the trains are bought into public ownership on 25 May".
To me that is not a commitment, it is a statement of desire but something they can get out of.
I would have thought getting the mess sorted out is beyond the governments control until they (more directly) take over.
Interestingly the words infer the trains will be bought, I thought they were leased and will continue as leased ?.
My simplest take on this is it shows how little understanding of the situation (or most likely transport in general) the transport secretary has.
Peter Mugridge
8 Apr 2010
Epsom
She probably just meant to say "brought"?
I agree - it's a non-commitment dressed up to look like a commitment... but also sets the ground for them to fire a few senior people if the issues are still unresolved at the end of May... so it seems to be aimed at concentrating a few minds.
Peter Sarf
Croydon
Yes she probably meant "brought" and also should have said "services" not "trains".
I too suspect some minds needing concentrating was the tack (either at SWR or perhaps DfT). Either that or the problems are not going to go away any time soon - not too unlikely !.
Stephen42
6 Aug 2020
It's down in Hansard as "brought":
I know that the Rail Minister is seized of this issue. He has spoken to me about it, and I understand that it relates to issues with lighting on platforms, what can be seen from the CCTV cameras and the role of the guard. We are across the detail, and it is important that those issues are resolved before the trains are brought into public ownership on 25 May.
I'd also view that as no commitment, agreeing with importance is a common way of sounding like you will do something without actually saying it will happen. Even if the situation was resolved tomorrow, the amount of training required means no more than a couple of additional diagrams could run by 25 May. A resolution coming imminently also doesn't seem that likely given how long it's been going on for.
Goldfish62
14 Feb 2010
That's exactly my interpretation and would have thought most people's as well. Most importantly it's a veiled threat to those at the top of SWR to get their act together or else...
2 Jun 2023
Richmond
The managers will get away like nothing happened as usual, with an extra helping of LinkedIn slop ("#TeamSWR")
norbitonflyer
24 Mar 2020
SW London
Only four this morning - both Dorking and Surbiton operated by 455s, and 2H93 (Shepperton) cancelled so the unit can take up one of the Windsor diagrams.
