Another one coming on Thursday.Eastleigh looked full up with 701's yesterday.
One was supposed to come last Friday but was cancelled last minute.Another one coming on Thursday.
How would you test software on a 455? It’s an almost 40 years old design with no train management system.I just cant understand why lessons have not been learnt from other orders, and why software can't be tested in advance..ie installed on a 455 test train for example. it stinks
I'd agree it stinks that they still haven't got them working, but at the same time I don't think you could test the software on a different class from what it is written for - it'll usually be created for the specific characteristics of that class.I just cant understand why lessons have not been learnt from other orders, and why software can't be tested in advance..ie installed on a 455 test train for example. it stinks
The traction system is bog standard MITRAC, braking bog standard, safety systems bog standard - thats why they have a certificate to run on the main line. The only software change they may have needed was for the ABDO system but even that must just be a subset of whats on the 345's. It remains a mystery as to how Bombardier managed to screw this up so effectively.I'd agree it stinks that they still haven't got them working, but at the same time I don't think you could test the software on a different class from what it is written for - it'll usually be created for the specific characteristics of that class.
How could you do that? A 455 doesn’t have any of the bits and pieces the software needs to talk to. As a test bed it would be useless unless you fitted all the hardware of a 701 to it at which point you’d have a test bed that looked like the real thing to the software but performed completely differently which would probably be just as completely useless. It would also cost an arm and a leg. And you’d still then need to integrate the software on the real thing.I just cant understand why lessons have not been learnt from other orders, and why software can't be tested in advance..ie installed on a 455 test train for example. it stinks
Clearly, if you break it down into its component parts then different subsystems may be able to be developed and tested on testbed vehicles with the relevant hardware fitted. That would only work for some of the bits, though, those that didn’t depend too much on the equipment and software in the rest of the vehicle. The problem is that that only takes you so far down the test route. Full integration test and development still needs the full vehicle at the end of the process.I actually think some software could be tested using older stock ie 455s, but yes probably a LO class 710 or something wouldve been better
That's a bit like suggesting microwave software can be tested on a toasterI actually think some software could be tested using older stock ie 455s
the software needs to be tested on the actual hardware. It will have been tested on a virtual machine, but deploying it to the correct hardware configuration (which is the class 701, and nothing else) can highlight issues that the VM cannot. I work with complex computerised heavy equipment and have to test new software versions, I can't stick it on a vacuum cleaner and test it thereI actually think some software could be tested using older stock ie 455s, but yes probably a LO class 710 or something wouldve been better
It'll be a staff limit, not a stock limit. Granted, some of the 707s having left will cause a degree of reduction but nothing like what's happened in practice. Reduced demand (and therefore revenue) and staff availability will be why the timetable is suffering, not so much the lack of 701s.Yes and no. I see your point and I realise that I don’t actually know what the maximum service capabilities are with the current stock.
I’m assuming a need for additional units in the hope that we can get back to something like the service we used to have. The 66% peak reduction we’ve had here means issues for the family members who have no choice but to travel. If it’s just a timetable limit rather than stock limit then I agree that this isn’t the solution.
Bombardier opening the Bangalore software office a decade ago has been an unmitigated disaster. (quality and workload)The traction system is bog standard MITRAC, braking bog standard, safety systems bog standard - thats why they have a certificate to run on the main line. The only software change they may have needed was for the ABDO system but even that must just be a subset of whats on the 345's. It remains a mystery as to how Bombardier managed to screw this up so effectively.
Has it been the case where all the 2nd Gen Aventra software has been copied from the 345s?Bombardier opening the Bangalore software office a decade ago has been an unmitigated disaster. (quality and workload)
701 is a small evolution of 710/720/730 (effectively second generation Aventra) rather than 345 (first generation Aventra) which is where the copy from 345 may be coming a cropper. In reality ABDO uses ETCS functionality with few cleaver tricks added and is rather simpler than what the 345s do.
The new cab was needed though, due to length restrictions.rather than design a whole new bespoke cab and unit when it's not needed (gangway or emergency exit)
I thought that, at least until recently, the 345s were running on a heavily modified version of the Electrostar software just to effectively get them into service until the main 345 / Aventra software was ready to take them into the core?Bombardier opening the Bangalore software office a decade ago has been an unmitigated disaster. (quality and workload)
Yes, we have been through this so many times on this thread.The new cab was needed though, due to length restrictions.
Yes isn't that because swr wanted the doors of a 5 and 10 car in the same place?The new cab was needed though, due to length restrictions.
Do the railways do the equivalent of iron birds? Get all the electric and mechanical bits in a hangar, wire them together, and make sure it all works in a place where it is easier to see what is and isnt working and why? I read that the modular signalling is done that way by at least one company, with the installation put together in a warehouse and tested before it goes out to the worksite.I'd agree it stinks that they still haven't got them working, but at the same time I don't think you could test the software on a different class from what it is written for - it'll usually be created for the specific characteristics of that class.
Yes, it was very important in the context of meeting the dwell times in the specification but I really can't be bothered to explain why yet again. If you do a search it's buried in the thread.Yes isn't that because swr wanted the doors of a 5 and 10 car in the same place?
which is hardly important when they could have just used platform graphics to show where the specialist doors were going to open
Hardly a bespoke cab when according the illustrations the same cab design will be used on the hydrogen units.All this could have been avoided if they just went for a variant of the 345/710/720 rather than design a whole new bespoke cab and unit when it's not needed (gangway or emergency exit)
And from what I've read they also have plenty of problems!At the time, back in 2017, it was bespoke though!
It did seem to be the basis of the gangwayed cab as later rolled out (the first time around!) on the 730s
These trains wouldn't be running up and down the SWML in traffic if they hadn't already been through this stage. This core software running traction, braking and safety systems must be standard Aventra to have got a certificate to run so its whatever they've written for SWR needs that is causing problems in the way it interfaces with it perhaps.It rather depends on what the virtual machine is.
If it is a set of production wiring looms with the parts plugged in (but sitting on the floor of the test hall, instead of being in the physical train bodyshell), then ought to be able to test majority of it.
Software is a set of tasks, usually worked through in sequence (many times a second), controlling different parts. So if don’t actually test it driving / connected to modules then you won’t know until too late if it works.
Yes, we should remind ourselves that the ORR granted authorisation in October 2020 for them to be used in passenger service.These trains wouldn't be running up and down the SWML in traffic if they hadn't already been through this stage. This core software running traction, braking and safety systems must be standard Aventra to have got a certificate to run so its whatever they've written for SWR needs that is causing problems in the way it interfaces with it perhaps.
They aren't concerned with reliability though or whether the train crew think the cab is workable only compliance to relevant group standards. However, given reports of doors opening whilst on the move you would have to question the integrity of this authorisation.Yes, we should remind ourselves that the ORR granted authorisation in October 2020 for them to be used in passenger service.
ORR have a reputation for being ultra-cautious in matters of safety.They aren't concerned with reliability though or whether the train crew think the cab is workable only compliance to relevant group standards. However, given reports of doors opening whilst on the move you would have to question the integrity of this authorisation.
