Mikey C
- Joined
- 11 Feb 2013
- Messages
- 4,079
And previously the Voyager, Super Voyager and Meridians, the Javelins...Paragon
Nova 1
Nova 2
Nova 3
Aurora
Castle
Azuma is quite a silly name.
Nova 1
Nova 2
Nova 3
Aurora
Castle
And to those who claim that a humble third rail suburban EMU has never had a brand name displayed on it I give you:And previously the Voyager, Super Voyager and Meridians, the Javelins...
Will the guard be closing the doors?The only door release buttons are in the drivers cab. There is one door close/signal bell panel on each side per coach with a PA and C2C. There’s a TMS feature that will allow the guard to secure each coach from the inside using the door open button
Will they have carpets?
Sadly only a matter of time.701012 has had a new livery applied, courtesy of some “artists”.
Agreed. More trains lying idle and with less supervision, and awful scrotes travelling on otherwise empty trains.Graffiti attacks, inside and out, are way up all over the UK during the lockdown.
It's the one part of their spec I don't like. Odd decision especially as the bays have small fixed tables.The 701s don't appear to have any seat back tables, any chance of those getting retrofitted? I suppose it's not a requirement by the DfT since neither the 707s, nor 455s have them either.
Same here. Yes, leg room could be better and we'll have to see about the seats, but in most ways these do appear to be an upgrade compared to the 707s and certainly the 455s.It's the one part of their spec I don't like.
I believe the seats are the same as Northern and Scotrail use (without armrests) so in relative terms an upgrade from the 707 and reasonable for suburban work.Same here. Yes, leg room could be better and we'll have to see about the seats, but in most ways these do appear to be an upgrade compared to the 707s and certainly the 455s.
Not much of an upgrade in terms of seats if they are the exact same but with different padding. Could have at least put arm rests in?I believe the seats are the same as Northern and Scotrail use (without armrests) so in relative terms an upgrade from the 707 and reasonable for suburban work.
Have you tried said seats? They're better than standard ironing boards.Not much of an upgrade in terms of seats if they are the exact same but with different padding. Could have at least put arm rests in?
comfort wise we will have to wait and see though compared to the 455s especially
Although one point is that the 458/5s have very few airline seats so not many pull down tables.Personally I think it’s all relative, let’s assume you travel into London from Wokingham each day, your usual rolling stock is 10.458 with the odd 8.450 standing in.
let’s for a second assume 458s are straight off a deep clean and all the aux equipment (toilets, PA, PIS, WiFi, HVAC) all work as designed.
701s are going to be a downgrade.
now let’s assume you’re on the Cobham/Letherhead/Woking Bay line and your commute is a similar journey time, 701s are going to be a massive improvement because of the facilities they add to your commute.
You're absolutely right, though having been on various Aventras (345s, 710s and 720s), the ride-comfort is also probably going to be better (compared to the 455s and 456s at least and possibly even the 458s).Personally I think it’s all relative, let’s assume you travel into London from Wokingham each day, your usual rolling stock is 10.458 with the odd 8.450 standing in.
And since they have no impact on capacity or aisle space, it is a little frustrating that we don't appear to get any this time.
In theory, yes, there's always some sort of theoretical draw-back, but in this case I would argue that the effect is minimal (and the benefit to passengers significant enough) to justify them being fitted. Personally, I've found them to a very welcome addition on commutes lasting 30+ minutes, but that is of course entirely down to personal preference, maybe they can be done away with as far as most people are concerned.What they do impact though is 'churn' - seatback tables slow people getting in and out of seats, and given that churn was one of the higher priorities in the suburban rolling stock design process it's not surprising to see they've not been fitted.
This was stated on this very forum as to why the 700s would *never* get seat back tables. Until they did.What they do impact though is 'churn' - seatback tables slow people getting in and out of seats, and given that churn was one of the higher priorities in the suburban rolling stock design process it's not surprising to see they've not been fitted.
But only some of them. It's not something that ever really happened in significant numbers.This was stated on this very forum as to why the 700s would *never* get seat back tables. Until they did.
But they are not just working the inner suburban services, they are also working the outer suburban Reading line where journey times are similar to the Basingstoke/Alton routes.What they do impact though is 'churn' - seatback tables slow people getting in and out of seats, and given that churn was one of the higher priorities in the suburban rolling stock design process it's not surprising to see they've not been fitted.
That's right. The negotiations on the retrofitting stalled. It was only new later-build ones that came with tables.But only some of them. It's not something that ever really happened in significant numbers.
Exactly. Reading isn't and never has been inner suburban. In fact in NSE days and before it was classified as main line.But they are not just working the inner suburban services, they are also working the outer suburban Reading line where journey times are similar to the Basingstoke/Alton routes.
Agree the seat back tables would be relatively cheap to add to the spec, I suspect they would add significantly to the cleaning costs. No idea how many tables it would be, but maybe 300 seat back tables per set being cleaned twice a week, multiply by 60 sets and that is a lot of time.
Seat back tables are not much use anyway, you can never get a laptop open on them and the drinks slip and slide everywhere.
Now, cup holders, that would be a great addition.........
Or just keep 458s for the Reading line. Basically they have ordered something not fit for purpose for that route.That's probably more an argument for giving Reading some 450s than changing the spec on the 701s though, particularly as Reading is the outlier in terms of route compared to the others. In the same way the core became the defining factor on TL and the design of the 700s, Clapham (and to a lesser extent Waterloo-Wimbledon) is the defining factor on the 701s
Funnily enough I havent since the trains are not in service yet meaning nobody has travelled on themHave you tried said seats? They're better than standard ironing boards.
I wonder if a halfway house could be to fit seat back tables only to window seats?The decision to retrofit the tables doesn't change the fact that they negatively impact churn.
Shepperton has always been "inner suburban", but journey times are comparable to Ash Vale, Micheldever, or AscotBut they are not just working the inner suburban services, they are also working the outer suburban Reading line where journey times are similar to the Basingstoke/Alton routes.
