father_jack
- Joined
- 26 Jan 2010
- Messages
- 1,143
Flooding Alderton Tunnel between Bristol Parkway and Swindon.
Flooding one track Dauntsey between Chippenham and Swindon.
Flooding Athenley between Taunton and Westbury.
Planned engineering work Bath to Westbury stuffs everything completely.
Climate change or Network Rail cutbacks to preventative drain clearing ?
Live Train Times and Journey Updates | Great Western Railway
See the Great Western Railway TrainTracker for live departure times and up-to-the-minute train journey updates.
www.gwr.com
Due to flooding between Swindon and Chippenham the line towards Chippenham is blocked.
Impact:
Train services running through these stations may be cancelled or delayed. Disruption is expected until 12:00 18/02.
Customer Advice:
We're sorry for the delay to your journey.
Owing to flooding in the Dauntsey area one of the two line between Swindon and Chippenham is closed.
Flooding is also affecting the alternative routes which we would have used to divert services along.
A very limited train service will be running between Swindon and Bristol Temple Meads via Chippenham and Bath Spa, in both directions.
You are advised not to attempt to travel at this time.
We will update this message with more information when we have it.
Due to flooding between Swindon and Bristol Parkway the line is blocked. Disruption is expected until 12:00 18/02.
Impact:
Train services between London Paddington and Cardiff Central via Bristol Parkway may be delayed or diverted.
Customer Advice:
Owing to flooding in the Alderton area the line between Swindon and Bristol Parkway is closed.
Flooding is also affecting the line between Swindon and Chippenham, which is the alternative line we would use when the line between Swindon and Bristol Parkway is closed. We can only use one of the two lines on that alternative route so only a very limited train service will be running between London Paddington and South Wales in both directions.
Due to flooding between Taunton and Castle Cary the Reading line is blocked. Disruption is expected until 12:00 18/02.
Impact:
Train services between Taunton and Westbury may be delayed by up to 60 minutes.
Customer Advice:
Owing to flooding in the Somerton area the line between Taunton and Castle Cary had been closed. The water level has reduced and the line is now being inspected by Network Rail. When it reopens trains will have to run at a much reduced speed which will extend journey times.
