Collision and derailment near Salisbury (Fisherton Tunnel) 31/10/21
RPI
6 Dec 2010
Saw something on Facebook last night of two class 159s at Exeter st davids. Could exeter depot maintain them?
There appear to be more than 2 units doing the Exeter Gillingham shuttles, 2x6 car sets it would appear. Exeter can and do fuel the 159's (though it stopped for a while)
RPI
6 Dec 2010
On the Exeter Side of Salisbury are 159106+108 in a pair and 011+015 in a pair
Signal Head
26 May 2013
Early 1980s era Salisbury ASC has a very early automatic route setting installation to assist the signallers in operating the NX panel and relay interlockings, using an experimental Southern Region system known as ERSE (electronic route setting equipment). My fear is that if sufficient of the first train had left the track in order for the track circuit to clear, then the automatic route setting could have stepped in to set the route for the following train immediately before anyone had any time to think, and because the track circuit was still showing clear, the signal would have cleared straight away as commanded.
Pictures of the signalling panel here:
Interesting. I wasn't aware ERSE had been used to implement ARS, or even that it had that capability, I've only ever seen it used as a button processor/route selection & point calling system.
Incidentally (probably), the original ERSE kit here has been replaced with a Delphin system in the last couple of years.
alxndr
3 Apr 2015
Oh, so we can rule out a SPAD then (of either train).
Nothing that suggests that has been said. There's simply not enough information (and probably won't be until the RAIB report). I haven't even seen any photographs clear enough to support the comment that the points were still set for the first train.
spyinthesky
17 Aug 2021
Bulford
Would it be possible for someone to summarise what we actually know at this stage, please. It would be nice to separate actual known fact from speculation.
I would summarise
1. There has been a collision between 2 trains.
2. There has been thus far no fatalities and injuries received are classed as non life threatening. Several casualties have been treated at SDH.
3. Everything else however true is still speculation.
Dan17H
14 Nov 2020
Essex
To explain the route, attached are the Track Diagrams, to help dispel any untruths about layout.
moley
12 Jun 2011
The question should be, “Who initially claimed an object was hit?”.
It came from the initial log reported shared on twitter. There are now known inaccuracies in this as it refers to 1F30 on its side - which isn't the case based upon photos.
norbitonflyer
24 Mar 2020
SW London
Indeed, it shows the SWR unit (which would be 1L30) at 45 degrees, but the GWR unit appears to be upright.
Wilts Wanderer
21 Nov 2016
This is what Salisbury signalling panel looked like 30 years ago, for anyone interested.
thejuggler
8 Jan 2016
Less than 24 hours since the incident why the rush for facts by media?
BBC reporting as fact the 7 minutes between the first unit being derailed and the second hitting it, but caveating the train hitting something by using the word 'believed'.
Is the 7 minutes now proven fact?
Suraggu
23 Oct 2013
The Far North
Indeed, although reading that screenshot it appears that was the first report. From my time in control when information was given you put out what had been advised to yourselves. Then afterwards clarification and corrections can be made in separate log posts. This is crucial in investigations such as this.
MarkyT
20 May 2012
Torbay
I haven't any proof and could be entirely wrong, but a vague recollection of a conversation decades ago came to mind. Yes 'panel processor' functionality was certainly a significant benefit of ERSE, saving countless relays and wires, but equally, electronic or processor-based systems are a prerequisite for any form of automation.
Even without ARS functionality, signallers become accustomed to setting routes very quickly, often 'oversetting' into occupied sections once the points are free to move (which is allowed by the systems) and fully trusting track circuits and interlocking to prevent any dangerous early clearing of signals.
norbitonflyer
24 Mar 2020
SW London
It would appear that it was 1L53 that was tilted over. I have seen no phoots of the GWR train in its side
bnm
12 Oct 2009
And another 159 parked up at Yeovil Junction. Unable to be utilised as low on fuel.
357
12 Nov 2018
Those of us who work in the industry or are familiar with the transportation sector, or any sector that deals with major incidents (or on the railway even major disruption) will know that the initial reports tend to have inaccurate information in them and are updated as time goes on. Considering the chaos in the control room at that time, it is to be understood. The person giving the information on the phone might also not have been the easiest to understand given the situation.
I said to someone the other day that if a staff member making an emergency call remembers to say "This is an emergency call" then they have done more than 90% of emergency calls I have dealt with.
JamesT
25 Feb 2015
BBC news reporting the driver of the SWR has suffered ‘life-changing’ injuries.
norbitonflyer
24 Mar 2020
SW London
The photo of where the trains ended upwould indicate to me that the Waterloo train was going quite fast, it has almost completely entered the tunnel. Maybe it was fortuitous that the derailed train was leaning over so as to give more room inside the tunnel in effect. Or maybe just the kinetic energy of the colliding train had to go somewhere.
In the pictures the GWR train is upright - it is the SWR train which is leaning over. As to whether either train was off the rails before the collision, there are only unsubstaniated assertions.
357
12 Nov 2018
Do you have a link. The article I am reading says minor injuries. ( https://www.bbc.co.uk/news/uk-england-wiltshire-59116800 )
BBC also reporting "We know both trains weren't going too fast" but does not cite a source.
Martin Frobisher, Network Rail's safety and engineering director, said it was too early to say what had caused the collision and they were "hugely relieved" no-one was seriously injured.
He said they could not say if the first train hitting an object caused the collision.
2192
16 Aug 2020
Derby UK
1. If Clapham yard has no fuelling facilities for 158/159 DMUs, is Stewarts Lane or Selhurst a possibility?
2. 158's and 159's are much the same, apart from paint. Could one good unit be made out of the two damaged ones?
snookertam
22 Sep 2018
Even if signals were black, you’d expect the SWR service to have reacted to the AWS magnet warnings it will have received? Something still doesn’t sound right about this.
This is what I’m thinking. A lot definitely still missing here.
HamworthyGoods
15 Jan 2019
There 3 damaged units - 2 GWR 158s and 1 SWR 159. Time will tell what the future holds for those and how many of the vehicles are repairable etc.
Sleepy
15 Feb 2009
East Anglia
ITV lunchtime bulletin also stated this about driver.
backontrack
2 Feb 2014
The UK
Awful news. I have to admit that when I saw the photos, my initial reaction was that people must've died, so that they haven't is an incalculable relief, but a traumatising event nevertheless and I hope that all involved (especially both crews) are in good hands. Although the reports that the SWR driver is seriously injured is awful to hear.
