Contactless on GWR and barriers at Paddington
zero
3 Apr 2011
Can contactless to Reading be used on any GWR train including those going to Cornwall and Wales?
I haven't been to Paddington for 3+ years but I have read about the issue with some TfL/GWR trains using the Heathrow Express platforms which causes incorrect charging.
I seem to remember that there were no barriers on the low-numbered platforms - have any been installed now? If not, is there somewhere to touch in with contactless?
That issue was about times of the day when TfL Rail runs to Heathrow from platforms 2 to 5 and the Heathrow Express fare is charged specifically for travel between Paddington and Heathrow.
The fares to anywhere else will be charged at the appropriate rate, so fares to Reading will be charged at the rates shown on the single fare finder regardless of which ticket gates are used.
There are stand alone readers on platforms 1, 8 and 9 near the buffer stops / concourse buildings and at the bottom of the stairs to the overbridge. The GWR direct award mentions proposals for a barrier scheme for platforms 8 and 9 being brought forward. Platforms 2-5, 6-7 and 10-14 are gated. There is no out-of-station interchange when using the platform 6-7 barriers - eg touching these barriers will split the journey.
79. Paddington Platform Ticket Gates
The Franchisee shall use all reasonable endeavours to procure by no later than 31 March 2021 (and in any event by no later than 31 October 2022) the installation of commissioned and operational automatic ticket gates at platforms 8 and 9 at London Paddington station. The Franchisee shall ensure that such ticket gates are staffed for eight (8) hours during any Weekday and four (4) hours during any day that is not a Weekday from the date of completion of installation and commissioning for the remainder of the Franchise Term. The Franchisee’s obligations under this paragraph 79 are conditional on all applicable consents (including listed building and other planning consents, Network Rail consent, and station change at London Paddington station), which the Franchisee shall in each case use all reasonable endeavours to obtain.
I have started a different thread in the appropriate section about these gates
https://www.railforums.co.uk/thread...ms-8-and-9-at-paddington.216051/#post-5076031
zero
3 Apr 2011
That makes sense. Thanks for the info
matt_world2004
5 Nov 2014
Is contactless valid to Reading on all GWR services, including the fast services?
Yes except the ones that are pick up only at reading when coming from Paddington and the ones that are set down only at reading when going to Paddington.
davetheguard
10 Apr 2013
As an aside to the question of Contactless acceptance on GWR services between Reading & Paddington, how do on train ticket staff check that you've touched in at your origin point? I can see with Oyster that they would have access to some sort of back office information, but would they really have access to the same sort of information from a credit card company/bank?
zero
3 Apr 2011
They scan your card with a device that records the card number as a standalone reader would. At the end of the day the back office processing works out whether you were touched in. If you weren't, a maximum fare or penalty fare may be charged.
johncrossley
30 Mar 2021
How could a Penalty fare be issued?
Hadders
27 Apr 2011
They don’t issue a Penalty Fare is you’ve not touched in, but a maximum fare.
Too many maximum fares in a set period of time results in the card being blocked.
MikeWh
15 Jun 2010
Crayford
They don’t issue a Penalty Fare if you’ve not touched in, but a maximum fare.
Correct, but it is a special kind of maximum fare known as a revenue inspection charge.
Only if they're revenue inspection charges. If you get a maximum fare because you forget to touch out at the end of a journey then that has no bearing on whether your card will be blocked.
