England top the group on net run rate.
including the first England hattrick in T20.Jordan ran through the tail, with figures of 2.5 - 0 - 10 - 4.
Got that wrong! Edited post accordingly.South Africa top the group because they won (all) 3 games as opposed to England's 2!
There have been quite a few such occurrences this tournament!Best thing about the England-USA match was Buttler smashing a 6 onto the roof, a drone then showed a solar panel up there with a huge hole in it![]()
At the age of 16, he was chosen to play for the England U-19s against a Young Lions International XI this week and batting at number 6, scored 106 from 111 balls with 3 x 6 and 8 x 4.Andrew Flintoff's son, Rocky, has been given his first pro contract by Lancs. He's still 16, congrats to the lad and all that, but as a fan I know darned well that if he's good then we will see little of him due to England central contracts and 20/20/franchise tournaments, probably mostly with the Brave Sundowners in Spring and the Krispy Krisps in summer.![]()
So no level playing fields! To coin a phrase, it's just not cricket.Ridiculously England's semi final doesn't have a reserve day in case of bad weather. A no result means India would be in the final
The other semi final does have a reserve day.
Frank Duckworth, the man whose mathematical knowledge helped to revolutionise rain-affected cricket, has died aged 84.
The Lytham-born statistician created the Duckworth-Lewis method, a model to recalculate scores when limited-over matches were curtailed by weather conditions, with fellow Lancastrian Tony Lewis.
On day 3, Lancashire took their 1st innings total to 549-9 declared, then took some wickets.In the County Championship fixture between Kent and Lancashire, in response to the Kent first innings total of 244, Lancashire lost Jennings at the score of 7-1, but an excellent triple hundred stand of 312 by Wells (150) and Bohannon (182 not out) steadied matters. At the end of day 2, Lancashire were 402-4.
There is a video of the 43 run over at https://x.com/CountyChamp/status/1805925704548089975So.
Sussex v Leicestershire
Leicestershire were set an unlikely 464 to win and slumped to 144/6
Enter Louis Kimber
Leicestershire 375/7 at lunch, the highlights of which were:
- Leicestershire scored 232 off 29 overs (and remember there are no fielding restrictions)
- Louis Kimber 191 not out off 92 balls with 16 sixes and 18 fours
- Kimber took a first class record 43 off one over from Ollie Robinson
[UPDATE]
Kimber now 203 not out off 100 balls, the fastest double century in the history ofthe county championshipall first class cricket
[UPDATE]
Kimber hits his 18th six, a new county championship record, beating Ben Stokes' 17
Kimber's was a remarkable innings, but according to Wisden it's the second fastest double century in First Class cricket, behind one in 2018 of 89 balls somewhere on the Indian sub-continent, not sure which country
The post I replied to had that bit crossed through and replaced by first class cricket! From what you say, I gather it wasn't you that altered it. Personally, I don't think anyone else should be allowed to alter what anyone else writes and I certainly wouldn't dream of doing so.So I was right first time, fastest in the county championship
Thanks for explaining - no problems.No, it was me, but when I corrected it back the edit didn't save for whatever reason (probably me, or PEBKAC * as the support documentation for a project I once delivered said). I'll change it again now
* Problem Exists Between Keyboard And Chair
Apart from one in the first Group stage against Canada, that was washed out without a ball being bowled.Up to this game, had India won all their matches?
