Loppylugs
Spot on. Over to you.A-rley and A-MBE-rley
Of course! Last station on the alphabetical list.Ystrad Rhondda
Abbey Road?Diolch @Caboose Class.
Seeing as I have been hogging this a bit, here's a nice easy one.
1B Thoroughfare.
Absolutely correct @d9009alycidon. Wonderful memories of Duchesses, Princesses and Scots. All yours.1B was Camden so Camden Road?
Yes.One of the rules which was established (by Quizmaster @transportphoto) in the forum General Knowledge Quiz was that "if a question is answered correctly and accepted by the question setter, but then no new question is set within one day (twenty-four hours) by the successful contestant, on expiry of this period, the floor will open for any member to set a new question". Do we need the same rule applied to this forum?
Taking you up on that, let's start the ball rolling again with:-Sorry guys, was otherwise occupied, open floor.
Isabella loves dancing with picadors |
Sorry, not Islip. Let's say it's Midlands-ish!Couldn't be Islip, could it?
I'll kick off my intervention with "Lapworth". As in Isabella thought a picador may be worth a lap with.Sorry, not Islip. Let's say it's Midlands-ish!
If there is no station called Leopard's Basilica there jolly well should be, it's a magnificent name.Taking you up on that, let's start the ball rolling again with:-
I agree - anagram of Isabella and picadors! Sadly, however, the Lady Isabella only loves dancing with picadors - not flirting with them in anagrams!!If there is no station called Leopard's Basilica there jolly well should be, it's a magnificent name.
Good try - but sorry no.I'll kick off my intervention with "Lapworth". As in Isabella thought a picador may be worth a lap with.
I could be - but I aren't! I must admit @Calthrop that I am truly amazed that no one can work out this simple anagram clue. Any joy with the Dead Sea clue? If not, think of a frail old lady like Lady Isabella going off to take the waters, in order to revitalise herself to go off dancing WITH PICADORS.I'm having crazy thoughts about a now closed station (though on a still-open passenger line) in the Republic of Ireland; but you wouldn't be that evil -- would you?
You and every one else I suspect! Open floor at your behest, Sir!It's Droitwich Spa, isn't it? (If I'm right there, open floor, please; have had to be told the answer, all-but.) I totally had it into my head, that "Isabella" was a more integral part of the clue, than your explanation suggests; was imagining it likely, part-and-parcel of the anagram.
Anyone fancy a quickie?You and every one else I suspect! Open floor at your behest, Sir!
Obviously you do like a quickie. Your turn...Tain ?
Shot in the dark - Codsall? Col surrounding Odsal (former home of Bradford Bulls).Sadly, quickies are now just memories!
Not renowned for it's sporting connections, you will find a smooth surface here surrounding a pitch.
Silkstone Common?Sadly, quickies are now just memories!
