Ashley Hill
Well if you can bury a 27 I’m sure you can drown a 60 .I'd like to take that and extend it to dumping them in the ocean to create artificial reefs.
I hope one or two eventually get preserved.
Aren't some already preserved? I know of at least one that's at Margate.Well if you can bury a 27 I’m sure you can drown a 60 .
There's 60 086 at the Wensleydale isn't there? ( Though I have a feeling I read something about it moving on a few months ago ).Do you? which one would that be? you probably mean 081 which is still rotting in Toton Yard
Isn't there a 60 on a short length of track in an industrial estate somewhere? I've seen photos of it parked next to a couple of other locos on short lengths of track.
Depends on your definition of ’preserved’!Aren't some already preserved? I know of at least one that's at Margate.
Off the beach at Dawlish to create a barrageI'd like to take that and extend it to dumping them in the ocean to create artificial reefs.
When's a loco not a loco. EWS and Thence DB are subject to these regs after chopping up locos at Wigan and thus not making them available to competitors I would imagine the requirement to offer them for sale would have some sort of regulation about not selling the key components separately as that would have the same effect.
Does that regulation still apply though ? I doubt it
No allegedly about it, it is indeed heading off to Margate (to the 1:1 collection with 47501, 47841 and others). Though Toton will have to do a few repairs to the bodywork first, not just to repair the corrosion from several years sat outside, but from the time it threw a leg out of bed and chucked a piston through the side.Allegedly 60081 is off to LSL's display collection in Margate.
It needs a replacement engine room door at least, one was damaged when it put the leg out of bed. Shame that they are not rebuilding it to working order but so be it.
AFAIK, the rules are different if it's a rebuild/re-engining exercise - the class 69 rebuilds are witness to that (their engine doesn't meet emissions requirements for new build locomotives).if so what engine? how will they get over the environmental hurdles unless it's a brand new engine?
“We looked at fitting a twin-engine Caterpillar design, an MTU V16 engine or even two Cummins engines, before settling on the EMD12N-710. These are what’s fitted in a Class 66, and these are ten brand new engines.”
Despite the engines being brand new 3A emissions-compliant, they are still of a design that had been discontinued due to emissions regulations imposed on the industry. This meant that GBRf 66779 Evening Star, which arrived in the UK in 2016, was the final brand new ‘66’ to be built for this market.
However, GBRf was able to prove that their emissions were an improvement on what had been in the locomotive previously. Furthermore, because the Class 56 retains Grandfather Rights on the network, the approval process is a lot quicker.
One other issue is fuel consumption: the Mirrlees MB275 in the Class 60 uses less than the EMD 710 engine. So a swap to the 710 would be a downgrade in that sense.AFAIK, the rules are different if it's a rebuild/re-engining exercise - the class 69 rebuilds are witness to that (their engine doesn't meet emissions requirements for new build locomotives).
Quote below re. the class 69 project from RAIL magazine: https://www.railmagazine.com/news/fleet/exclusive-the-gb-railfreight-class-69-project-explained
All locos are polluting! Need to be more specific on emissions and exactly what those emissions are. Ok, some have higher emissions than others but that's a general term as lots of different pollutants to consider.It's a deliberately created/tolerated loophole. The question is what would happen if it were closed?
Would it force the development of a proper, emissions-compliant new diesel loco for the UK market?
Would it force TOCs to concentrate their existing diesel fleets on work that actually needs to be diesel hauled, instead of habitually running diesel on electrified routes?
Would it encourage further development and use of "last mile" hybrid locos?
None of these outcomes would seem to be negative ones to me. Of course, the FOCs will say that unless they can continue using cheaper, outdated, polluting locos, a portion of rail freight haulage will become nonviable and traffic will revert to lorry transport.
What if the FOC's aren't lying about this?It's a deliberately created/tolerated loophole. The question is what would happen if it were closed?
On an ops level, I’ve heard mixed reports about the Class 69. So unless there’s a serious weakness in the Class 60 that could be addressed by re-engineering, this is why I’m also sceptical.One other issue is fuel consumption: the Mirrlees MB275 in the Class 60 uses less than the EMD 710 engine. So a swap to the 710 would be a downgrade in that sense.
If they're going to re-engine, then personally I'd like to see them put the Caterpillar C175-16 (as used by the 68) in...
I didn't say they are or would be lying.What if the FOC's aren't lying about this?
I agree, but I suspect a 710 is the most likely choice if GBRf go down the 're-engining' route (just because of spares and servicing commonality with most of their diesel fleet).One other issue is fuel consumption: the Mirrlees MB275 in the Class 60 uses less than the EMD 710 engine. So a swap to the 710 would be a downgrade in that sense.
Because of the noise? (gets 'dieselhead' hat out of cupboard ).If they're going to re-engine, then personally I'd like to see them put the Caterpillar C175-16 (as used by the 68) in...
I meant the engines themselves. Some older engines sometimes have lower emissions in certain areas and higher in others. NOx is an example due to lower compression on older engines.Emission Standards: Europe: Nonroad Engines
dieselnet.com
My answer to what we should do if it's the case that imposing emissions regulations meant rail transport started shifting to more polluting road transport is that we should have transport policy that ensures this doesn't happen.
Yeahh its a shame the 710 is an obvious pick if this re-engineering thing actually happens (perhaps could do with a separate thread for the topic at this point).I agree, but I suspect a 710 is the most likely choice if GBRf go down the 're-engining' route (just because of spares and servicing commonality with most of their diesel fleet).
Problem with going for a high-speed diesel engine (e.g. Cat/MTU/Cummins) I assume would be incompatibility with the existing cl. 60 alternator, which is designed for a medium-speed engine. New alternator or a reduction gearbox between the two?
How about using an ex-HST power car MTU R4000 and alternator, combined with a set of batteries to create a diesel-battery hybrid?
In theory the same engine as the Class 99s + batteries might be an idea. But Longport is Progress Rail = Caterpillar and the 99 engine is Cummins I think?I agree, but I suspect a 710 is the most likely choice if GBRf go down the 're-engining' route (just because of spares and servicing commonality with most of their diesel fleet).
That could be part of it!Because of the noise? (gets 'dieselhead' hat out of cupboard ).
Latest info I have seen is that the 99 will use a Cummins QSK50 engineHowever, I'm starting to wonder if the existence of the class 99 order (with their proposed cat engines) would make GBRf more likely to opt for a cat engine.
The 60's (with 'Sepex' individual axle motor control) have probably the best wheelslip control of any of the BR-era diesel locos.Don't 60s have really aggressive traction motors as well that cause (or used to cause) a ton of slippage?
Ooo interesting - hadn't noticed this come up. Fair enoughLatest info I have seen is that the 99 will use a Cummins QSK50 engine
Ahh fair enough, must have heard some dodgy infoThe 60's (with 'Sepex' individual axle motor control) have probably the best wheelslip control of any of the BR-era diesel locos.
