Which I guess means they got unlucky, compared to somewhere else.And given an infection rate almost as high as last Christmas, but staying at that level for a couple of months, it isn't surprising.
Except that now it is only those with positive tests who should be off work - last year it was also anyone pinged by test&trace as a close contact.And given an infection rate almost as high as last Christmas, but staying at that level for a couple of months, it isn't surprising.
Oh well best to be prudent although TLk having a normalish day today with capes and the Sutton services showing very few cancelled so interesting how they expect it to be worse next week that they need to reduce by 50%? Im also surmising those drivers won't sign L.Bdg nor ECML so how much assistance would they be?This is a Covid reduction. Huge number of drivers off.
Another issue to add to the list and hopefully GBR will be charged to get on top of resourcing across the industry although it doesn't look like it was a specific goal of Williams-Shapps and with private sector seemingly the preferred operator there maybe no incentive to get it sorted.I imagine that - as ever - the leave position gets tighter as December progresses, and the willingness of drivers to come in RDW also diminishes as they (understandably) have more important things to do on their lives. Happens every year, but those operators that are already tight for resource will suffer most.
It's been done to death but perhaps relying on rest day working to enable a full service to be provided is not a sensible solution.I imagine that - as ever - the leave position gets tighter as December progresses, and the willingness of drivers to come in RDW also diminishes as they (understandably) have more important things to do on their lives. Happens every year, but those operators that are already tight for resource will suffer most.
There is a connecting line from Whifflet to Coatbridge Sunnyside but difficult to see how much use that will be. Trains from Larkhall and those from Motherwell via Hamilton or Carmyle will have to use Glasgow Central High Level or terminate short.
When Rutherglen to Cambuslang was shut in summer 2018 they extended the Glasgow to Newton trains through to Larkhall and Motherwell. I can't recall what happened with the line via Carmyle to Whifflet. Buses perhaps?
Difficult to see a way round it.It's been done to death but perhaps relying on rest day working to enable a full service to be provided is not a sensible solution.
If this new strain of the virus is more transmissible then it might help to have more trains running but if not many people are travelling then it might not matter.I can certainly see a move to lower levels of RDW, potentially elimination. That is, usually, more expensive though. And cash is not something the railway is particularly flush with at present.
Except if they suspect its the Omicron (spelling) variant you have been a close contact of, you have to isolate regardless.Except that now it is only those with positive tests who should be off work - last year it was also anyone pinged by test&trace as a close contact.
Broadly the same as today - Newcastle-Liverpools, plus the increased Edinburgh-Newcastle service. There will also be one diagram a day - except on Sundays - on the Edinburgh-Manchester Airport route.What services will be Nova 1s be operating for TPE?
Thanks - any idea what diagram it will be on the Edin - Man route?Broadly the same as today - Newcastle-Liverpools, plus the increased Edinburgh-Newcastle service. There will also be one diagram a day - except on Sundays - on the Edinburgh-Manchester Airport route.
Based on the empties from Craigentinny...Thanks - any idea what diagram it will be on the Edin - Man route?
Would prefer if came to Glasgow
The second train is currently timed at 17:59 ex-Redhill which is allowed under the 5-minute minimum connection.I sometimes make the following journey:
17:11 Guildford to Redhill 17:54
1758 Redhill to Horley 18:08
18:16 Horley to Haywards Heath 18:31
However, from the new timetable, it is no longer showing up. Have any modified the minimum connection time at Redhill?
I appreciate it could be a struggle to make the train if the first train is late, due to the poor layout at Redhill station and lake of decent passenger interchange facilities but it was a handy set of services, as it enabled one to depart not too long after 17:00.
I wonder why they felt the need to do that? Do they ever take into account connect trains when amending timetables?The second train is currently timed at 17:59 ex-Redhill which is allowed under the 5-minute minimum connection.
In the new timetable it is advanced to 17:58.
You can still get there for 18:43I wonder why they felt the need to do that? Do they ever take into account connect trains when amending timetables?
At it is, there is only 1 train an hour to Gatwick Airport, so anything that helps, such as this, is a bonus.
If I use it in future, I shall just have to run along the platform faster.
18:06 Redhill to Gatwick 18:15
18:31 Gatwick to Haywards Heath 18:43
Sometimes, if it is pointed out. Especially at busy places with relatively frequent services, planners won't have eyes on all the previously possible connections. If you point it out to GWR or Southern, someone might be able to get the timetable changed. Possibly a long-shot in this instance, but it is far from unknown.I wonder why they felt the need to do that? Do they ever take into account connect trains when amending timetables?
Would an e-mail to customer services get such a request forward on to the right departments for them to look at it?Sometimes, if it is pointed out. Especially at busy places with relatively frequent services, planners won't have eyes on all the previously possible connections. If you point it out to GWR or Southern, someone might be able to get the timetable changed. Possibly a long-shot in this instance, but it is far from unknown.
I haven't done it myself, but it's either that or approaching a local rail users group to see if they'll take up the case on your behalf.Would an e-mail to customer services get such a request forward on to the right departments for them to look at it?
Well, surely it is something they can rectify in the future if not now. I mean sometimes services get introduced mid timetable. I appreciate these things are planned. So I'm not talking about something happening overnight.I haven't done it myself, but it's either that or approaching a local rail users group to see if they'll take up the case on your behalf.
Most likely the response will be "it's too short notice", but only one way to find out.
Worked by Manchester crews, or Wigan signed up on 195sFor those interested, a 195 will be on the following Leeds - Wigan diagram from Monday...
2R82 0617 Leeds to Wigan North Western
2I07 0854 Wigan North Western to Leeds
2R92 1117 Leeds to Wigan North Western
2I17 1353 Wigan North Western to Leeds
2R82 1617 Leeds to Wigan North Western
2I07 1853 Wigan North Western to Leeds
First booked 195 on the Atherton line
