December 2022 Timetable Changes
Glenn1969
22 Jan 2019
Halifax, Yorks
Which requires Northern Powerhouse Rail, unless you're willing to close Whiston, Rainhill*, St Helens Jn**, Lea Green, Earlestown, Newton-le-Willows, Patricroft and Eccles to allow Chat Moss to only be for fast trains.
* This could never happen, given the historical connection it'd hit the Press just as hard as images of a certain viaduct in the Yorkshire Dales did. It's not an important station in particular, but it would be the heart of a campaign.
** You might get away with keeping one, probably this one.
And given that I don't think Core NPR includes Liverpool, I don't see it happening
I believe, though it is hard to tell from the maps, that Core NPR involves using the freight-only Fiddlers Ferry line from Liverpool to Warrington (hence an upgraded line, not a new one), then a new line from Warrington to Manchester. Thus even that would relieve the CLC of express services, allowing it to be used for more local services. That fits with most of the maps showing it curving north to reach central Warrington - if Chat Moss or the CLC was used, it'd curve south.
Liverpool 507
17 Jan 2018
Merseyside
It is extremely frustrating that Liverpool - Warrington Bank Quay has been given the axe. The number of passengers using the currently hourly service between Liverpool and Crewe via Manchester means most services throughout the day and well in to the night time have passengers stood in vestibules and gangways.
AMD
6 Dec 2017
Tbh the WBQ service wouldn't relieve the Chat Moss services much, as a large proportion of traffic on this route is through traffic from Liverpool to Manchester; the only real benefits of the WBQ service would be to give Whiston to Earlestown another stopper each hour (as they are down to 1tph). Another indicator of this is that the WBQ service was at the bottom of the pile in terms of revenue vs cost to run in the whole of the west side of Northern so unless Merseytravel want (and fund) this service there's not much likelyhood of it coming back any time soon in any frequent form.
What really needs to happen is for TPE to sort themselves out as they are meant to run 2tph Liverpool to Manchester, and for Northern to get the semi fast to the airport via CLC running every hour.
geoffk
4 Aug 2010
There are two in the December timetable, but one is via the CLC of course. Did you mean two via Chat Moss? I'm aware that the Scarborough was the second. Is that supposed to return to Liverpool. If not then surely there's a path for the Warrington BQ stopper.
AMD
6 Dec 2017
There may be a path, but unless Merseytravel pay for it, it's not happening.
Bikeman78
26 Apr 2018
When I first read that the Liverpool-Oxford Road stoppers were to be split at Warrington Central I'm pretty sure I read somewhere that the decision was taken to allow an all-day hourly service calling at all stations towards Manchester rather than just at peak time. There was least some logic behind that as the stations you've mentioned above are in the middle of areas with a sizeable suburban population who would definitely benefit from a more frequent service.
However the currently proposed changes won't give any of the benefits of a more regular service to those stations and instead just shafts other stations like Hunts Cross, Halewood and Warrington West which will now lose their direct service to Manchester whilst other stations on the Liverpool end which previously enjoyed a half-hourly service to Manchester will see that halved beyond Warrington.
Urmston and Irlam are served by the TPE train to Cleethorpes but I wouldn't risk using that if my journey was at all important.
I still question the wisdom of having built it.
I can't believe that it's not half hourly. All that money spent and one of the stoppers doesn't stop. As discussed previously, 195s would be ideal on there.
adrock1976
10 Dec 2013
Being as the Liverpool - Warrington BQ is the only passenger train to use the left hand side of the triangle at Earlestown, if the passenger service does not ever get reinstated, would there have to be a formal closure process?
berneyarms
26 Nov 2013
Dublin
You’re forgetting the morning Liverpool Lime St to Ellesmere Port and evening return workings.
cle
17 Nov 2010
** You might get away with keeping one, probably this one or Earlestown.
I think a reasonable service could be pathed, the WBQ at least dropped off, vs a Manchester slow. It only needs 1tph more (one to Sheffield/Nottingham) - Cleethorpes could begin at Picc.
Starmill
18 May 2012
Bolton
That's an interesting crossover to the Portishead thread where it's being argued people won't use hourly services into and around major cities. This is two-hourly...
Funding is in place to run 2tph with this service, and it started running hourly in 2019. It also took just a small amount of capital spending to put a new crossover in to enable it, and that was that.
One of the reasons the service is well used currently is because it picks up people travelling between Chester and London. This traffic will disappear when through trains between Chester and London are back.
Changing at Runcorn? Interesting, is this because it's a very good connection so the planners show it? I would have thought Crewe would be the place to change.
Well, it seems we are getting "base" NPR including the Fiddler's Ferry line, so perhaps a metro style CLC is on the cards...
68011
8 Oct 2016
There are 3 TPE workings an hour from Liverpool to Manchester, hourly to Hull, Newcastle & Cleethorpes although there's a gap of 2 hours on the latter route between the 12:19 & 14:19 as the 13:19 ex Liverpool runs as a Class 5 likewise the 09:26 ex Cleethorpes, these are the Class 68/Mk5a training paths.
Starmill
18 May 2012
Bolton
Avanti's reduced timetable generally doesn't provide a connection at Crewe, as has been much discussed here.
There are still some connections from the TfW services to Crewe.
Bikeman78
26 Apr 2018
From Chester it's a +9 at Runcorn on to the Euston train. Going the other way is a +55 so not very good at all. Catching the TfW train to Crewe is roughly a 25 minute connection to Euston with the same overall journey time as via Runcorn.
geoffk
4 Aug 2010
Oh yes, sorry I'm a long way away now and there's a lot going on in Devon!
frodshamfella
25 Sep 2010
Frodsham
Just a thought could the WBQ service run onwards to Crewe, calling at Acton Bridge, Hartford and Winsford, thereby giving these stations a link to Warrington BQ
That would be an interesting option to speed up the LNR Birmingham by removing those calls from that, as it would give them a direct service to both Liverpool and Crewe, and they could change at the latter for Birmingham twice an hour rather than once. Also means there'd be more than 1tph between Crewe and Warrington. I like that.
You would need a 29 minute gap if you were running fast line, 20 odd minutes if you popped out and in at Winsford on the slows to not get run down by anything running north of Weaver.
cle
17 Nov 2010
Perhaps! I’d support a high frequency electric route - but where to send/turn them in Manchester?! A new Cornbrook station with two bays and limited through trains (and a free Met transfer?)
Other than that, all for it. And that’s why I prefer the Met/Merseyrail split. All about frequency and uniformity for a route like this.
I like the routing but it would be incredibly slow for Hartford etc to Liverpool. Useful for heading south and north though - and Manchester Vic. Maybe a smart end to end service though, with a few purposes. The WCML does need more ‘local’ service if can be pathed.
Might we still see Birmingham-Liverpool on HS2 now NPR got the nod? Could enable the current service to remain semi.
Southport into Vic and the two TPEs onto NPR (or curtailed at Picc) and you could probably turn 4tph at Oxford Road, particularly if the centre turnback was implemented.
frodshamfella
25 Sep 2010
Frodsham
although I think those stations ( and I speak as someone who does use Acton Bridge) between Crewe and Runcorn, if the journey time is significantly more via WBQ it would not go down well, quite a bit of commuter traffic to Liverpool from the intermediate stations. What would be needed is the second Birmingham reinstated, allow one to stop and one speeded up.
cle
17 Nov 2010
Yeah that would work, we shouldn't have diesels through Castlefield really. Southport pairs with diesel (Calder) neatly.
Maybe 4tph turn at Oxford Road and 2tph go to the Airport. You could have a semi-fast 2tph and 4tph stoppers if electric, I reckon.
Leaves another 6-7tph for Castlefield...?
Yep I agree. A fast and a slow Birmingham-Liverpool make more sense. As for which of the more middle/regional stations deserve 2tph, like say Hartford, I'm not sure.
geoffk
4 Aug 2010
Have been looking at RTT for December and most of the Piccadilly - Hazel Grove and peak-hour Victoria - Wigan via Chat Moss trains are shown as diesel units. Is this just for pathing reasons, i.e. a 75mph schedule?
175001
3 Feb 2007
Between Heaven and Hell
The Vic-Wigan is down as a 319
Little snippets from our internal briefing...
331s appearing on Chat Moss working, some Crewe's, and some Stoke's
Only 158 work on the west to be seen on Leeds - Wigan Wallgate. Morecambe too of course
Diagrams for next month are available here
