So far as I know nothing special goes on at Rainford, I can only assume its just to keep things normal for the waste trains, things seem to go wrong fast when ever they mess about with stuff up there!
On 313s for example Full service is equivalent to the emergency brake position is this the same on 507s?Likewise. 30mph at the ramp where a full brake application was made, which I’m taking to mean ‘Emergency’.
Not sure about the Liverpool end but rainford to Knowsley freight terminal is worked by a token and rainford to Kirkby is worked by a staff.Do the trains have to go a certain distance down the single line for the signalling to work properly - e.g. do they need to be detected by a track circuit somewhere (e.g. at the entrance to Knowsley Freight terminal or something)?
Or is the issue the driver being able to change ends in non gangwayed units and needing a platform to do so?
Rainford to Knowsley Freight and Kirkby are both worked by token.Not sure about the Liverpool end but rainford to Knowsley freight terminal is worked by a token and rainford to Kirkby is worked by a staff.
A token is used as a staff.Rainford to Knowsley Freight and Kirkby are both worked by token.
For the Signalling to work the train just needs to clear the track circuit for the Points then I can move the points and clear RJ2 Home Signal for it to come back into the Up platform to work back up to Wallgate
Tripcocks, are they only used in the tunnel sections though? There's certainly TPWS fitted elsewhere, like at Kirkby.
Merseyrail uses LU-type train stops doesn't it?
You can see them working with the signals at Lime St on the Wirral loop.
Would they not be used at a location like Kirkby?
Not all of them.Northern services are running empty to Kirkby from Rainford rather than standing at Rainford for an hour.
I just glanced at RTT, so I am assuming that it's correct.You know best, I was just going off what was being said in the signing on point. If there are no freights due I guess its easy enough!
9 mins is an awful long time to do a shunt onto the single line and back into the up platform. But I suppose the train would have to pass the signal at danger.I just glanced at RTT, so I am assuming that it's correct.
They always say you believe everything you read in the newspaper until they report on an incident of which you have first hand knowledge!
Yes indeed terrifying once you realise that, for whatever reason, you are not going to stop. Goes beyond a 'brown trousers' moment into this is not going to end well.Must have been terrifying seeing the buffers approach at that speed. I hope the driver drives again.
...................... a 'brown trousers' moment into this is not going to end well.
To be fair, I can't remember any "brown trousers" moments that have ended well either!
Someone just shared that JetBlue "gear sideways" emergency landing on my Facebook - that's a good example!
Would the driver have been tested for alcohol, and other drugs, after the incident?
Also, if the accident was caused by a mechanical failure, is it still safe to use other units of the same design, until the cause of the failure has been rectified?
The driver had the sense to get out of the cab and run along the first carriage.Yes indeed terrifying once you realise that, for whatever reason, you are not going to stop. Goes beyond a 'brown trousers' moment into this is not going to end well.
Thoughts to the driver.
Agreed and known very quickly hence a big focus should be on the poor performance of yet another legacy buffer arrangement (including that concrete block...)Let's just say enough is known to allow that decision to have been made.
I can't imagine what the passengers must have thought when they saw that!
Probably nothing. Some are happy to sit in the dark/smoke filled carriage without batting an eyelid.I can't imagine what the passengers must have thought when they saw that!
