At no point was a practise at the tests mentioned within this thread.
To be clear the standard isn’t two attempts. It’s two failed attempts. If someone passed and then failed they would be able to sit the tests again.
Operators do not require a candidate to resit a test they have already passed. If the operator deems the amount of time since passing to be excessive, that is ultimately the operators decision.
As referenced earlier this debate has been done for years in numerous threads. We will not debate it as this would be advertising. We simply point out the standards, and incorrect statements regarding the process.
Wish you all good luck with your applications.
You are incorrect. You are allowed to fail twice. After the 2nd fail, it's game over.
It's never been based on attempts. It's failures that count. Passes do not count at all towards lives.
You can pass three times and then fail, and you'd still have one life left.
Ok - well if that is the case then I’m happy to admit that I’m wrong - but can we please have chapter and verse on that? In terms of some actual ORR/RSSB guidance/regs?
If we can iron it out, maybe it could be made a sticky thread, because this question has come up over and over for years, as you both say.
So if you passed to national standard at attempt one, and failed at your second attempt, you’d be allowed a further attempt?
I’m also aware of instances over the years where TOCs have split the tests, so that candidates might face the computer based tests then, assuming they passed, they would face the DMI. If they failed the DMI they wouldn’t be invited back to take the MMI. Would that count as a life lost?
Chapter and verse is needed please!
@RCG is best placed to do the legwork to provide it, since he’s monetising it?
My advice stands - don’t pay for anything - simply apply to TOCs, read the practice materials, buy the book on the Group Bourdon test that helped me (if anyone wants to know which book, PM me and I’ll tell you).
It’s much easier just to pass at your first attempt and get the job for free.
That's an interesting document regarding testing centres.
However, whilst adopted industry-wide, I've still not located a document that specifically states you need to have passed these tests to undertake driver training and get a train driving licence. It's a bit like the 'pirate's code' - Merely guidelines.
I suggest you have a read of this. I’d like others to provide chapter and verse, and make their positions clear (I’ve already digested it, but I’m not earning any money by regurgitating it on here)...
These Regulations implement, for Great Britain, Directive 2007/59/EC of the European Parliament and of the Council of 23rd October 2007 on “the certification of train drivers operating locomotives and trains on the railway system in the Community” (Official Journal No. L 315, 3.12.2007, p.51).
www.legislation.gov.uk
My personal view is that the tests should be more reflective of the job, and therefore made much tougher. One attempt. Fail that, you’re out on your rear end.
