DarloRich
This can happen, and of course will be an issue when it does, but it doesn't usually happen, so I ask you, is it better to **** people off at every incident, or only the 1 in 10 where it gets much worse than normal?
I certainly accept that outwardly similar incidents can take varying amounts of time to clear, but if you can look a little more in depth at the incidents then you will see that certain assumptions can be made.
As a daily traveller on the GEML for over 15 years and someone who worked there for several years (and had access to the performance data) I know that the vast majority of "person on the line incidents" happen in the Romford area. So does the operator, NR and BTP and they've actually got reasonably consistent in the amount of time it takes to clear the incident.
Of course if the incident took place somewhere else then they might not be able to make a good estimate, but for 90% of these incidents if you say 1.5-2 hours you'll be in the right ball park. I know that and act accordingly. I think it would be helpful if all passengers had that information. Don't you?
I do - to a point.
The "informed friend" can make sensible decisions based both on this information and personal experience. Many people are unable/unwilling to do that and become obstreperous when things don't go their way or the way they think has been advertised.
My issue (from my limited time "on the ground") are the problems faced by staff in dealing with people when the delay escalates beyond the advertised period. I have seen the end results of staff being abused/assaulted by people because the delay was longer than advertised. They shouldn't have to face that.
Therefore unless there is a high level of confidence behind the delay estimation I would be cautious about giving any such estimation.
