Doesn't help if you value through London journeys. Still I suppose it might increase the use of East Midlands Parkway if people from Langley Mill etc travel there instead.
Every chance they probably do already....
What's the big benefit to the majority that's worth making airport journeys require two changes or reversals?It's all done to create the maximum benefit for the majority of Passengers, and not slowing everything done for the few.
Well, of course not.But this isn't an ideal world
Unless Langley Mill is a settlement of a dozen people they are not travelling to East Midlands Parkway at present...Every chance they probably do already....
So will the intercity services still call at Market Harborough and/or Wellingborough?
And to clarify going between Bedford and the north passengers would change at Kettering?
So is it Kettering where you change going from Bedford to the north?Market Harborough and Kettering
So it's only Wellingborough and Bedford that loose out on the IC services
Yes. And Leicester if you want Sheffield, which is a right faff.
Leeds wasn’t explicitly mentioned in the original either, as we discussed a few days ago.Doesn't seem to be any reference to services to / from Leeds or HST services between Nottingham and Sheffield in the revised document that I can see.
However, the consultation FAQs explains just why they aren't doing that:...I think the bigger problem will be the 2 changes to get to Sheffield and Derby, though depending on the timings that *could* be addressed by stopping 1 Sheffield at Kettering instead of 1 Nottingham...
“Q. Is it possible to stop one of the Sheffield services at Kettering, rather than both Nottingham services?
A. Unfortunately not. The Sheffield and Nottingham trains have to leave London St Pancras International quite close together and therefore stopping a Sheffield service at Kettering would add significant journey time, as the Nottingham service would have to wait behind it.”
Yeah blame Thameslink for that one
Not really, there are 2 pairs of 125mph paths which can fit out of St Pancras every 15 minutes so it would be a case of moving one or other around the clockface and adjusting the Electric service to fit. It may well be that the timetable wouldn't work somewhere else if they did that, it's ultimately a compromise.
Well they used to be every 15 minutes, but when the Thameslink timetable was recast, when the Nottingham got moved to 3 minutes after the Sheffield!
I didn’t think anyone would count that sort of obvious error as an actual reference to Leeds...There was a pink Leeds written in the previously published document as a title with nothing underneath it and now nothing at all unless I've missed it.
A new version of the document has now been uploaded, with all the mistakes / issues removed. Apparently it's not supposed to be public until tomorrow.
https://www.eastmidlandsrailway.co.uk/december2020
It’s confirmed:
I asked EMR whether they planned to keep Leeds services they said:
It is a franchise requirement when they were awarded it.
Thanks for the link, useful.
I see that a comparison is made between present and proposed journey times for the services to St Pancras from Kettering and stations Northwards, but not for stations to be served by the electrics. I think I can guess why.
The map implies that, in the standard service, all trains that call at Harboro will also call at Kettering and journey time to St Pancras from Harboro is 59 mins, from Kettering, 55 mins. So that's 4 minutes for 10 m 72 ch and station call. Wow.
No that’s a separate discussion between that member and EMR, it’s not referenced in the consultation.Perhaps this?
Well, I'd presume the Kettering time is the average of 2 x fast and 2 x slow journey times (given that today is c55 mins with 3 stops)...
