EMR mass cancellations on Liverpool-Norwich, 19/04/25
Warrior2852
27 Oct 2018
EMR has at apparent short notice last night cancelled all but 4 of the Liverpool to Norwich trains west of Nottingham today (plus 1 Liverpool to Nottingham still running).
Stockport is closed due to engineering works, but the EMR trains were all scheduled to run in the replacement timetable, going via New Mills Central straight from Piccadilly to Sheffield. But the vast majority of them have been cancelled at short notice last night, apparently due to driver availability issues.
It's therefore created a timetable today where there is an unscheduled 7-hour gap now between Norwich trains coming out of Liverpool, which I imagine will be causing a few issues.
stuartl
10 Aug 2014
Seems to be two problems. Signalling problems between Peterborough and Ely, and shortage of drivers. Latter presumably due to end of rest day working agreement.
Thomas6187
27 May 2011
Rochdale
I wonder if there is a lack of Drivers who sign the route. There been route refresh paths in the timetable since December, and I believe they haven't been used once yet
Tram203
15 Jun 2024
Always Changing
Would seem odd if that's the case.
Indeed. I'm fairly sure there are some late night / early morning ECS workings that are booked daily to use that route, possibly even the late evening Manchester to Nottingham passenger service.
Either way, completely unacceptable and absolutely disgraceful from EMR. Shame on them.
6Gman
1 May 2012
If there's no driver available, there's no driver available.
There's only so much contingency cover you can carry.
Dogbox
9 Oct 2017
Blame the DFT, they won't sign off on the rdw agreement. I thought these problems were a thing of the past once Labour came into power.
bahnause
30 Dec 2016
bülach (switzerland)
I don't know exactly how it works financially. However, I strongly assume that the TOCs do not receive random amounts of money from the DfT, but that these are set out in a budget negotiated by both partners. And if a TOC now needs more than is budgeted, they should have solid reasons why this is the case. After all, it is not helpful if additional funds are constantly needed.
Tram203
15 Jun 2024
Always Changing
Irrespective of where the fundamental root cause and blame lies, it is EMR and EMR only who seemingly failed to advertise before yesterday evening that there would be mass disruption on the route in question today.
If the post above regarding difficulties resourcing drivers to drive the diversionary route around Stockport is correct, it's very hard to believe that this was only all of a sudden realised yesterday evening.
To leave it 12 hours or less in some cases between trains being scheduled to run and advertising "sorry we can't run these trains due to reasons we have at least strongly suspected if not absolutely known about for days if not weeks" is in itself shameful and disgraceful.
Warrior2852
27 Oct 2018
And I had a look at their website when finding out about this, they had a whole replacement timetable listed on there stating the full amended service (basically everything minus Stockport), so they had been specifically advertising a level of disruption but then not that that already disrupted timetable had been further disrupted.
At least they were able to put on a 6 coach of two 170s to make one of the few existing services less crowded.
If they are having problems with crew route knowledge running via Marple then why aren't they running to Sheffield?
If you're talking about services from Norwich, Nottingham is the "natural" turning point for services cut short on that route as it's where the units split, where the depot is, and where most part-route services start and terminate in the normal timetable. They're doing Nottingham-Norwich OK, it's west of that things fall apart.
tram21
29 Dec 2022
It just seems odd that its basically only this route affected by cancellations, and its one of the most important routes. Surely you'd be better cancelling, say, every other Robin Hood line services to divert the crew onto the Liverpool/Norwich line (they all sign everything at Nottingham so it is more or less that simple)
Peterthegreat
22 Feb 2021
South Yorkshire
I know very well that is the case. However it is because it is easier for the operator - the passenger comes last.
Warrior2852
27 Oct 2018
Wouldn't work though if the problem was indeed a lack of signed knowledge on the diversion via New Mills Central though.
Andyh82
19 May 2014
I bet it was carnage on the Leeds to Nottingham service as Northern only use 2 car units on this route
The EMR service is usually 4 or 6
tram21
29 Dec 2022
I think this might actually be the case. Tomorrow its mostly only services past Nottingham towards Manchester which are cancelled, with limited cancellations on other routes.
If so, what an absolute **** up by EMR
LowLevel
26 Oct 2013
The problem is a lack of Romiley route knowledge. The trains weren't cancelled until the day before so you can't just run to Sheffield as there is no driver allocated to run the train at all as they don't hold the route knowledge for the diagram so can't be allocated to it as the original turns had been cancelled to accomodate the diversion. Many spare guards and no spare drivers.
Rail Ranger
20 Feb 2014
It's not as if the Stockport blockade hadn't been planned for quite a while.....I know that TPE did route learning on the diversion route.
Warrior2852
27 Oct 2018
Northern does sometimes make it a 4 car on that route, particularly if it's busy. I have been pleasantly surprised before by expecting 2 coaches and 4 turning up.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
My understanding is that this isn’t wholly accurate for drivers. Drivers knowledge is link based. Guards do sign pretty much everything.
