freetoview33
Oh my god and a new service 72 Centre-UWE service as well!. Quite a different route though, via Redland and Lockleaze! Good stuff!
Romney Ave bus link?
But traveline does say the 70 is also changing from the end of August! looks like it is going to every 15mins (so deckers must be on the cards)
BIG NEWS
Also shows the X74 stopping at U.W.E hourly
and a 71 and 72 towards the cente!!! from U.W.E Yes!
X74: Centre - U.W.E - Bradley Stoke (Willow Brook Centre) - Hourly
70: Temple Meads - U.W.E - 15 mins
71: Temple Meads - U.W.E - 15 mins
72: Centre - U.W.E - 20 mins
Given the new 71 making a combined 8 bph with the 70, against the current 5 bph, I suspect deckers are fairly unlikely, given First's current fleet.
Long may 46603 continue. It sometimes strays off the 161 onto the X75 and has been to Yeovil at least twice this year on 377.
It is certainly much more comfortable to ride on than Alexander Darts 42730/31/38 which have no legroom.
With services 1, 2, 8, 9, 38, 39, X39, 50 & 51 already linking the Centre with Temple Meads I question if adding 3 more services between City Centre and Temple Meads can be justified. Hope the new services do not damage the use of the trains from Montpelier to Bristol TM and back.
Also, ran a TT lookup for 70 - 73 on Traveline SW: no new timetable came up in the results.
Dave
Dave
Dave
Looks like we got our wish of more buses to Ashley Down and U.W.E plus a bit more! Going on at First does seem to work
Actually a bit of a decrease in buses/frequency to Ashley Down to be fair. The 70(the only service that serves this area) being reduced from every 12 minutes to every 15 minutes. But it doesn't matter, as the new 71 via Filton Avenue to UWE and the 72 and X74 also to/via UWE will help ease the over-crowding on the 70.
The X74 is interesting for me. As I did suggest on here a new Centre-Bradley Stoke service via Filton Avenue, Gloucester Road, and Aztec West. Another alternative suggestion which I didn't get round to mentioning would have been a service which took the exact same route as the new X74!
Good on you for your comments and suggestions you sent to First Freetoview33. Some other people may have sent their comments to them as well, including some residents in Bradley Stoke asking for a regular faster service to the Centre instead of the 73 which takes ages. I'm really impressed and pleased the actions First have taken on this with their changes/new services they are introducing.
Hi All,
Can anybody confirm that 67600 is still based at WSM and is there any particular route it gets used on as heading down that area this Saturday and was hoping to see it.
Thanks, Mike Russell [henairs]
AFAIK, it's still there. Think it does 7 and X4
It was on the W1 on Tuesday.
With regards to the new UWE services (I'm still so thrilled at this!), it looks as if the 71 and the 72 are more or less identical to Wessex's 11 and 19! Brilliant - think most people will switch to First when they see they have other options available! I can see quite a few people getting First bus passes as opposed to Wessex's when they see how rubbish they are!
And some of these services will HAVE to be double deckers, as (presuming Hengrove will run them) there won't be enough singles!
Maybe the Streetlites at Hengrove are for these new U.W.E services?
So the pvr on the 73 will remain the same even though one less bus an hour? Well seems Hengrove have enough buses for the new services, maybe the 20 got axed just due to lack of buses and it not being profitable. Will the extension to the 82 increase the pvr? An improvement but still means old stuff has to carry on another year at least. And at this rate of First introducing lots of new services probably will be a few years, although what about what was being displayed on the X2 and X3 where are they going? Or they might be for X74?
X74 is actually half hourly! Mondays-Saturdays. I expect it will actually be limited stop(unlike some other X services which stop at all stops enroute). Calling Centre, The Haymarket, UWE, Filton Church(Gloucester Road North), then all stops to Bradley Stoke.
Had a go at establishing the PVR now and in future. Apologies if it might be a little out but here we go...
The new requirement is....
- 70 - 7 Single Decks (usually Eclipses) from HE
- 73 - 11 Double Decks (usually Geminis) from LH
- 20 - 4 Single Decks (usually Darts) from HE
- 70/71 - 13 Single Decks from HE
- 73 - 11 Double Decks from LH
- 72 - 4
- X74 - 3
So that makes an increase from 22 to 31
You could crudely say that the 72 is a swap for the 20, so 4 x SD from HE? The X74 is perhaps a bit trickier but assuming that it's a new route, you might just see some of the 2006 Darts on there, at least at the beginning? Who knows?
What we probably do know is that the 70/71 will be single deckers. Aside from the canopy issue, the increase in capacity negates the need for deckers. Note that the PVR is 13 and HE is getting 13 new Streetlites - mind you, that could almost be too perfect!!
I'm with baza585 - I can't see who'll be wanting to release decent deckers. Even Taunton has had to deal with getting hammered W reg Tridents. Fine in the flatlands but not in Bristol, and again, there are a number of areas that are looking for newer deckers to replace their ageing Olympians. Given the fact that singles appear on the 1 and 2 semi regularly, I can't see deckers appearing on these new routes, if any route might then it could be the X74!!
I think the overall increase in PVR is correct, but I think 70/71 will be 12 and 72 will be 5. Not sure though. This, I think will be an overall increase of 9 buses (from 22 to 31 as above). So if we get the intended Streetlites (47551-47572) for Hengrove, the Marshalls should still go!
