GBRF confirms conversion of Class 56s to Class 69s
25 Sep 2018
Given the determination of spotters that every item of motive power has to have a nickname, I propose it be 'Fnarr-fnarr' for the Class 69s, so that all those who are making jocular remarks about something that the vast majority will undoubtedly never have actually experienced can get it out of their system and move on... :s
Rail Blues
2 Aug 2016
Blimey the long, dark evenings at your place must fairly fly by.
And on your final point, speak for yourself :lol:
61653 HTAFC
18 Dec 2012
Elsewhere (or possibly this thread) someone suggested Ying-yangs which is both SFW and works on two levels...
DarloRich
Fenny Stratford
That is the winner. Close the internet! ;)
Mikey C
11 Feb 2013
Trying to drag this thread back from the gutter :E, is there a reason why they've given them a new Class code, rather than just making them a sub code like the 73/9?
GB
16 Nov 2008
Somewhere
Perhaps theres more modification involved in this and that warrants a new class code? I have heard it suggested that everything below sole bar is 56 and every thing above (bar body) is 66.
Cowley
15 Apr 2016
Devon
Okay I think it's time to move on from the jokes ;)
Hmm.
I wonder if they should’ve perhaps considered using class 65 instead?
Also, once you’ve gone up to 69, where else is there to go..?
30907
47543 was the first loco fitted with SEPEX, and 58050 had it from new for trials, though it was later removed. All the Class 60s have it, though.
I have heard the SEPEX/creep control on the 60s described as "earthquake mode" - an apt description I feel, having felt the vibrations at Shipley.
Having now read ainsworth74's stricture, it is perhaps a relief that the 69s won't be so equipped.
plarailfan
6 Feb 2013
56D
Sounds a great way of having a decent locomotive, with a long life, for a reasonable cost ! I wonder if these re-engineered 56's will be used on the Trans-Pennine route upgrade and HS2 projects ? I guess a lot of infrastructure trains will be running over the next few years.
43096
23 Nov 2015
Hmm.
The class number will in very large part be dictated by the availability of suitable gaps in the numbering sequence, as until the recent change to 6-digit vehicle numbers for DMUs and EMUs the same 5-digit sequence was used for unit car numbers and locos. As an aside, many of the numbers in the 56xxx series are now taken by Turbostar vehicles.
Cowley
15 Apr 2016
Devon
That’s a good point.
Actually I think you may have patiently explained that to me before on a different thread somewhere?
I definitely could do with some extra memory storage at times.
43096
23 Nov 2015
Can you still get RAM upgrades?!
:D
It does illustrate what a dumb numbering system we have, though.
And to your original point about where you go once you get to 69, surely the question should be “where do you go when you get to 10” and the answer is, of course, that you go up to 11 because it’s one louder.
Cowley
15 Apr 2016
Devon
:D
But couldn’t you just alter the numbers so that it still says 10..?
gg1
2 Jun 2011
What was the reason in choosing 56s instead of 58 or 60s?
In addition to the earlier comments, the narrower body of a 58 may make a conversion more difficult or impossible.
Would an EMD 710 (or alternative in a similar power range) even fit in a 58 bodyshell at all?
furnessvale
14 Jul 2015
I know the US has a wider loading gauge but their locos in general have a walkway each side which is wider than a class 58 walkway.
ps To further the discussion, a SD40-2 has an engine hood width of 7ft which contains a 710 engine. A class 58 has a cab width of 8' 11". If the walkways on a 58 are around 1ft wide there is no problem. Anything more would need to be looked at.
The body of a 58 between the cabs is non-structural and essentially just there to protect the internals. So I imagine it could have been replaced by something wider, losing the walkways, if necessary.
DelW
15 Jan 2015
On a minor point of order, SD40-2s have 645 engines as standard, although Wikipedia says a small number have been rebuilt with 710s. I don't think it affects your point though, since I think the external dimensions of the engine blocks are identical.
hwl
5 Feb 2012
An early 710 should fit but the later ones (UIC2 / Euro3a) have more pipe work (e.g. split cooling systems) so would without the adjusting the non structure body work. Anything fitted now would be EuroIIIA.
hwl
5 Feb 2012
710 block /engine are slightly taller
Helvellyn
28 Aug 2009
Could have gone lower given the gaps in the 53xxx and 54xxx series.
Harbornite
7 May 2016
Me likey...
