357
- Joined
- 12 Nov 2018
- Messages
- 1,376
I was on about the luggage area. The cab is not a crumple zone!Guards aren’t permitted to remain in the rear cab? Are you sure?!
There’s a few other TOCs who didn’t get that memo!
I mean in terms of working the train; certainly people shouldn’t be taking breaks in them I agree!Cabs aren’t great to sit in for eating etc. Plus there’s always the risk of the emergency brake being knocked.
It looks like the area shown above is for sitting/relaxing. I don’t know where the idea that they’re leaving equipment there has come from(?) - that could indeed be securely stowed in the cab behind the seating area if they weren’t using it.
It’ll be fine for leaving guards’ kit in though! And of course you’ve got to pass through it to get in or out of said cab!I was on about the luggage area. The cab is not a crumple zone!
Indeed, I was on about expecting staff to take their break in there! It's not prohibited to pass through that area but you it is not advisable to remain in there.It’ll be fine for leaving guards’ kit in though! And of course you’ve got to pass through it to get in or out of said cab!
This is a bit of a non-thread. As noted above there isn’t a separate galley/area on 180s, so it seems quite reasonable to partition off a few seats.
God forbid staff should be able to take a break away from the travelling public - that won’t go down at all well on here!
I think we’ve got wires more crossed than the OHLE on a windy day!Indeed, I was on about expecting staff to take their break in there! It's not prohibited to pass through that area but you it is not advisable to remain in there.
I agree.While the idea of a staff compartment (DB label them Dienstabteil on old compartment stock) does make some sense, I think it also makes sense to partition it off properly. Staff do need their proper break, but the optics of them lounging across two tables, one each, on a busy train as I said isn't good. If GC wanted to do this properly they could have a proper partition added and it wouldn't be as visible.
It might have nothing to do with anyone taking a break, and simply be an arrangement that has been put in place to guarantee space for any colleagues who need to travel on the service as part of a diagram - I’ve no idea if that’s a feature of GC’s usual operations? If trains are consistently full to capacity it may have been seen as a necessity, albeit a very clumsy one.It likely won't be the guard who is having their break as they "shouldn't" be having a break on a train that they are actually working at that particular moment, they will likely have a break scheduled "off" train, it will likely be other train crew who are not safety critical and can have a break onboard (personally don't think that's right either though) as it's other crew they won't have cab passes so they wouldn't be allowed to take a break in the cab hence why it's in the train compartment
I'm have a cab pass and I would refuse to take my break in a back/middle/front cab.It likely won't be the guard who is having their break as they "shouldn't" be having a break on a train that they are actually working at that particular moment, they will likely have a break scheduled "off" train, it will likely be other train crew who are not safety critical and can have a break onboard (personally don't think that's right either though) as it's other crew they won't have cab passes so they wouldn't be allowed to take a break in the cab hence why it's in the train compartment
Depends on the company. Until the 360s came in the EMR train managers took their breaks on the trains they were working as time allowed as part of a pay deal from years ago and didn't have rostered PNBs.It likely won't be the guard who is having their break as they "shouldn't" be having a break on a train that they are actually working at that particular moment, they will likely have a break scheduled "off" train, it will likely be other train crew who are not safety critical and can have a break onboard (personally don't think that's right either though) as it's other crew they won't have cab passes so they wouldn't be allowed to take a break in the cab hence why it's in the train compartment
Must be a bizarre method of work to have guards leaning out a tiny window that I would be unable to fit my shoulders through instead of having a door where they would at least be able to step onto the platform.the method of work required them to have access to the buzzer.
The original method of work, when on the Western, required the driver & guard to return a buzzer code before the doors were released, dispatch then took place from a door panel.Must be a bizarre method of work to have guards leaning out a tiny window that I would be unable to fit my shoulders through instead of having a door where they would at least be able to step onto the platform.
180 cabs do not have any external doors. I believe there is a guards panel at every passenger doorway.
On some open access operators breaks are taken on service trainsWhy aren't GC staff taking breaks at allocated break locations. E.G stations/mess rooms?
Or on their legal requirement break perhaps? I'm sure that everyone would agree staff should not have to sit next to customers while having their break.
I find it strange that they don’t take break on train when it has terminated, prior to its back working.If staff can take their break whilst on the train, does that mean the train is over-staffed or they are under-worked?
I just think that if I could take a break I'd be worried about my job security.
What a bizarre attitude.If staff can take their break whilst on the train, does that mean the train is over-staffed or they are under-worked?
Last I checked, breaks were a legal requirement. Are you seriously suggesting that any job where someone can take a break means job security is at risk?I just think that if I could take a break I'd be worried about my job security.
Piffle. What about the person up front?That area is called a crumple zone. I hope I don't need to explain why people aren't permitted to remain in that area.
Because they wouldn't get a break! Every entitled Herbert among "the great unwashed" would be demanding their attention every two minutes.Eh? Why on earth not? Heaven forbid they should sit next to the great unwashed!
8 seats. For two people. Come on...
I think you've misunderstood my point.What a bizarre attitude.
Staff are rostered breaks on trains because that is operationally most efficient for diagramming purposes, i.e. requires the lowest number of staff overall. Why would that mean the train is over-staffed or they are under worked?
People would also agree that they shouldn’t have said break in passenger accommodation then.Or on their legal requirement break perhaps? I'm sure that everyone would agree staff should not have to sit next to customers while having their break.
I meant in the context of working on a train and taking a break on the train. Clearly my job isn't important enough to be required for the whole journey so is it required for any of it?If that's the prevailing view at your employer I'd suggest you should probably consider changing jobs!
It’s not passenger accommodation though, it’s crew seating as per the signPeople would also agree that they shouldn’t have said break in passenger accommodation then.
As previously stated I'm talking about the luggage area.Piffle. What about the person up front?
Good for you, and neither have I! Indeed I recently needed to speak to a CrossCountry conductor prior to the departure of a train but seeing as he was obviously on a break (enjoying some fish and chips which is what gave the game away) in the 1st class compartment of the train I left him alone until he was finished. But I have zero doubt that many other people would not be so considerate as you or I.Nonsense. I must have travelled on trains where there are also uniformed staff travelling a million times and never once felt it necessary to interrupt them.
If this is standard (i.e. the case on all trains) perhaps they should have had designed and installed a proper partition so it was hidden from the passengers, rather than a notice done in M$ Word and a piece of sellotape which really belongs back in 2020 never to be seen again?
If a paying customer did have the absolute unfettered nerve to want to ask a uniformed member of staff a question about the journey, that bit of sellotape's hardly going to put them off is it?Because they wouldn't get a break! Every entitled Herbert among "the great unwashed" would be demanding their attention every two minutes.
