Grand Central train stopped due to fault near Welwyn
Bristol
Given the length its passed the signal by there doesn't seem to be anything amiss. Signals are usually replaced to red by the leading end of the train passing the signal, not the rear. The train itself has failed mechanically, I believe.
DanNCL
17 Jul 2017
County Durham
What I suspect happened is that the signal was showing a proceed aspect when the train passed, changed to danger (as designed) once the first couple of vehicles have passed the signal, and the train has stopped for a completely unrelated reason, most likely an issue on the train (after all, it is a 180!)
Bristol
Yet it is blocking the line and not moving. Normally the driver would stop before the red light unless there was a problem. At least it is only several coaches beyond the light as you say.
From what I can see the driver didn't have too much choice where the train came to a stand. The route would have been set for the train to pass the WGC fast lines, and either the train replaced the signal to red as per normal or the signaller cancelled the route after speaking to the driver.
dakta
18 Jun 2008
If you're in the rear coaches of a train you will find signals are already red or well in the process of switching as you go through, probably a case of just where you happen to fail
800001
24 Oct 2015
That also had the rescue train attached by the looks of the picture.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
The OP has inadvertently implied that a signal has been passed at danger, at this stage there appears to be no information to support either way.
As other members have highlighted it is entirely possible that the signal was passed with a proceed aspect and has switched back to red as the train occupies the next section. Stopping under the signal gantry being a complete coincidence.
I can’t see any tweets or suchlike as yet about this.
800001
24 Oct 2015
It was a total loss of power from the unit, and also unable to release brakes.
Internal Information​
TIME TRAIN HAS BEEN STOOD SINCE:
1200
REASON/COMMENTARY:
Loss of power, unable to release brakes - set declared a failure 180107
vtiman
12 Dec 2009
Whirlwind Gdn City and Windermere sometimes. Previ
I didn’t imply that it was a SPAD indeed until just now.
I didn’t imply that it was a SPAD indeed did not use the word until now.
craigybagel
25 Oct 2012
You might not have meant to, but given this thread was originally entitled ""Train stopped UNDER red light", I think it's fair to say many readers will have thought of the same implications in your post.
800001
24 Oct 2015
Been there some time see attached
If passengers were on it hope they got evacuated safely
They got evacuated to another GC unit brought alongside on Down fast, taken to Stevenage where they boarded other services. That unit the returned and is now attached to the failed unit.
Update at 18.45 unit is about to move into the sidings at Welwyn Garden City.
I see it's had the route for ages but isn't budging and is causing a queue of trains.
Edit: it's finally shifted out the way.
DanNCL
17 Jul 2017
County Durham
These 180s seem to be causing more and more issues. Not to mention that they’re the last diesel trains into Kings Cross. I think the last few incidents just further reinforce the point that the 180s need replacing.
800001
24 Oct 2015
All the problems they’ve had lately can’t be many left.
They've been cancelling multiple services daily due to unit shortages.
The unit that failed near Newark, carriage that ran away at Crofton and now this today.
Thankfully todays stopped in a position to not cause to much issue, if it had occurred one signal section previous, the line would have been completely blocked heading south, and services would have had to divert - where possible - via Hertford.
DanNCL
17 Jul 2017
County Durham
Been cancelling multiple services daily due to unit shortages.
Thankfully todays stopped in a position to not cause to much issue, if it had occurred one signal section previous, then Like would of been completely blocked heading south, and services would of had to divert where possible for Hertford.
Indeed. The 91s look reliable in comparison to these things!
70014IronDuke
13 Jun 2015
It may not be a fair comparison, but I remember that the SRA (was it, at the time?) forced the TOC at the time to withdraw the one Leeds - Appleby - Glasgow Central through working in the late 2000s because - as I remember - it didn't want to risk 75 mph (?) DMUs working Carlisle - Glasgow in case they messed up the super new WCML trains.
If that one train each way per day, using reasonably reliable units, needed a ban, it seems to me that these notoriously unreliable 180s should never have been allowed to start on the ECML. It would be stuffed enough even without these units and all their attendant risks.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
They weren't so bad when Old Oak Common maintained them for Hull Trains and Great Western. Unfortunately, as unreliable as the mechanics of a Adelante are, I don't think having Crofton (a Bombardier now Alstom) depot have been much of a great help to them. At least the OOC staff knew the ins and outs of them.
..., it seems to me that these notoriously unreliable 180s should never have been allowed to start on the ECML.
I have created a new thread to discuss whether or not they should be banned from the ECML, as follows:
DanNCL
17 Jul 2017
County Durham
The GC units weren’t too bad when Heaton did most of the work on them. Now Crofton seem to have more of the work they’ve gone down the pan just like the Hull Trains units did when they went to Crofton. Almost as if the problem is Crofton…
fgwrich
15 Apr 2009
It's almost as if Bombardier didn't enjoy looking after someone else's units...
It's a shame though that the OOC staff couldn't transfer over to another London ECML depot - but of course, that transferred to Hitachi too.
(Wouldn't be the first time either, see how rapidly the East Coast HST reliability dropped after Hitachi took over Craigentinny)
Mugby
25 Nov 2012
Derby
How was it that GC just happened to have another set (to the rescue) in the vicinity? Where did it come from?
